Capital lock
msnarayanan
Well-Known Member
dear all
The cap lock pop up is not showing nor the light glowing in the cap lock button.
In the absence of this, it is very difficult to enter case sensitive passwords.
I am short of ears and unable to hear beep sound.
I shall be thankful if you will let me know how to enable pop up appears when the cap lock is on.
Thanks
M S Narayanan
Neemobeer
Windows Forum Team
I don't know if anything exists for that.
I wrote this for you though.
Unzip and copy it to C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup and it should run on start up.
On start up it will show up in your system tray like this.
When caps lock is turned on
When caps is turned off
If you want to close it, right click the icon and select exit
msnarayanan
Well-Known Member
Dear sir
I tried the method but it is not showing any thing.
This is fyi
M S Narayanan
Neemobeer
Windows Forum Team
Did you run the program?
msnarayanan
Well-Known Member
Dear sir
I did run the program.
M S Narayanan
msnarayanan
Well-Known Member
Dear Sir
I retried it and I am glad to inform you that it is working fine.
Thanks
M S NARAYANAN
