jaredstevens10
Ok so I recently updated my work laptop to Windows 7 ultimate (without making my company aware)
I done extensive research on the other work computers, installing software and trying to get as many applicable programs installed on my OS as the ones on the others
Note - All of the computers at work are running Windows XP
The Problem: Im able to access the internet through any wifi, and Im able to access the company inTRAnet when connecting the ethernet, but when I connect the ethernet/LAN cable I don't have access to the inTERnet and some inTRAnet links.
I've download and install many drivers, fixing some of my problems.
Recently I install GuardianEdge Drive encryption and Framework Client and now Im able to get a valid IP address when i cmd/ipconfig
10.51.xx.xx
after installing GuardianEdge i was also able to get my network printer working. (I was able to locate it prior to installing, but i kept getting the error, windows couldn't find the needed driver)
SO...at this point im thinking it's some kind of firewall configuration issue, but honestly...you guys are way smarter than me regarding this and I NEED YOUR HELP...you're my last hope. I really don't want to go back to Windows XP
WHAT CAN I DO???
10.51.xx.xx
WHAT CAN I DO???
