greenarrow1
As old as Creative Extigy external sound device is it was easy to install and set up in Windows 7 by using compatible with XP and the latest old drivers Creative has along with their player. Using 5.1 speaker set up with Artez speakers connected to the external device made it easier.
Hi everyone:
O.K., I solved this problem and got my SoundBlaster Extigy to work with Win 7 (64-bit machine). Here is what to do:
[FONT=&amp] Easy part: [/FONT][FONT=&amp]
1. Search your system for the old USBAUDIO.sys driver:
C:\Windows\System32\DriverStore\FileRepository\wdma_usb.inf_9ce240de
2. Copy old USBAUDIO.sys, (d.02-11-2006) to usb or floppy [/FONT]
[FONT=&amp]
Trickypart : [/FONT]
[FONT=&amp]
3. Go to C:\Windows\System32\Drivers
Rightclick USBAUDIO.sys (d.19-04-2008)> Unlocker >Choose Delete
4. Copy old USBAUDIO.sys, (d.02-11-2006) from usb or floppy toC:\Windows\Systems\Drivers
5. Reboot.[/FONT]
[FONT=&amp]
6. At reboot, Windows will block the Extigy from starting "because the manufacturer’s software was known to cause problems." Go into Device...
Sure, no problem, Captain Jack ... I apologize! Just wanted to give others a way to get in touch with me for the driver. 2 people have contacted me thus far and I've been able to help them out.
It won't happen again. Thanks for advising me.
Hi Twinkie,
Your Welcome. That's why we have the public forum so your answers could help hundreds of other people who are looking for an answer. We really appreciate your assistance. ;)
Regards,
Captain
O.K., I solved this problem and got my SoundBlaster Extigy to work with Win 7 (64-bit machine). Here is what to do:...................
no: midi synth in-out (reason, FL studio)
yes: play sound
yes: play sound
Please, Can anyone send me the 2006 audio driver?
I can't make my extigy sound card worl in w7
thank you in advance
Is it possible, that someone helps me to get this driver? That would be great, befor I'll became desperate, 'cause I find it not, without any suspicious downloader-binaries.
