Few vulnerabilities in industrial software echo as urgently across both manufacturing and educational sectors as a critical remote code execution flaw, especially when it scores a near-perfect 9.8 on the CVSS v3 scale. This is precisely the case for recent issues reported in several FESTO and FESTO Didactic products—staples for automation, simulation, and engineering learning worldwide. The discovery of a heap buffer overflow in the widely used Wibu CodeMeter Runtime left systems open to unauthenticated, remote takeover, presenting not just an abstract risk but a clear and present danger to the backbone of industrial control and training infrastructure. This article unpacks the technical, operational, and strategic implications of this vulnerability and its broader lessons for both vendors and users in the digital manufacturing revolution.
A robotic arm in a high-tech control room filled with computer monitors and servers, illuminated by blue lighting.The Crucial Software Suite: FESTO and FESTO Didactic in Industrial Automation​
Before delving into the specifics of the vulnerability, it is important to appreciate the critical role of FESTO and its Didactic division in the industrial and educational landscape. FESTO, headquartered in Germany, has long been recognized as a global leader in automation technology and technical education. Its product suite—ranging from Automation Suite for configuring and commissioning factory equipment, FluidDraw for fluid circuit diagramming, to FluidSIM and CIROS Studio for simulation and education—has become foundational across factories, universities, and training centers. Special-purpose systems such as the MES-PC (Manufacturing Execution System) further anchor FESTO's footprint in Industry 4.0 deployments.
Highly modular, often networked, and equipped for remote and collaborative use, these software solutions are vital for everything from designing manufacturing lines to simulating cyber-physical systems before real-world deployment. This deep integration into mission-critical, and often safety-critical, environments amplifies any security risks, as successful exploitation can have cascading effects across supply chains and educational ecosystems.
Anatomy of a High-Impact Vulnerability: CVE-2023-3935​
The centerpiece of the newly disclosed risk is CVE-2023-3935, a vulnerability classified as an "Out-of-bounds Write" (CWE-787), specifically a heap buffer overflow. Impacting Wibu’s CodeMeter Runtime up to version 7.60b, this flaw enables unauthenticated remote code execution, allowing an attacker to gain complete control of the host system. Wibu CodeMeter is not an obscure component: it is a licensing and copy-protection technology widely embedded within FESTO’s software stack and many other industrial IT products.
Technical Breakdown​
This type of vulnerability typically arises when a program writes data outside the boundaries of allocated memory, potentially overwriting critical structures such as function pointers or return addresses. When successfully exploited, an attacker can execute arbitrary code with the same privileges as the vulnerable process—in many cases, SYSTEM or Administrator.
  • Attack Surface: The vulnerability is exploitable remotely with low attack complexity. In practical terms, this means that even systems not directly exposed to the public Internet can be compromised if an attacker gains a foothold on an adjacent internal network.
  • Criticality: CVE-2023-3935 carries a CVSS v3.1 base score of 9.8—indicating the highest propensity for automated exploitation with maximum impact. The full vector string, CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H, reflects network-based access, low attack complexity, no privileges required, and total compromise of confidentiality, integrity, and availability. This is corroborated by both CISA and MITRE’s vulnerability databases.
  • Impacted Components: This vulnerability affects the CodeMeter Runtime, which serves as the license server and copy protection interface for several FESTO and FESTO Didactic applications.
Affected Product Matrix​
Through coordinated disclosure by CERT@VDE and FESTO, the following product versions are confirmed to be impacted:
  • FESTO Didactic CIROS Studio / Education: 6.0.0–6.4.6 and 7.0.0–7.1.7
  • FESTO Festo Automation Suite: All versions up to and including 2.6.0.481
  • FESTO FluidDraw: P6 up to 6.2k, 365 up to 7.0a
  • FESTO Didactic FluidSIM: Version 5 (all versions) and 6 up to 6.1c
  • FESTO Didactic MES-PC: Systems shipped before December 2023
This list spans both legacy and current releases, affecting users across the spectrum of industry and education. Notably, the inclusion of MES-PC and FluidSIM underscores the risk to environments strictly focused on simulation and learning—with potentially vulnerable systems exposed in schools and universities around the globe.
Assessing the True Risk: Why CVE-2023-3935 Matters​
Why This Vulnerability Stands Out​
Industrial control systems (ICS) traditionally operated in physically isolated networks (“air-gapped” systems), with security centered on perimeter defenses. But digital transformation has eroded those boundaries: remote engineering, cloud-based monitoring, and vendor support require connectivity, increasing the exposed “attack surface.” In this context, a remote code execution vulnerability in a licensing service shared across most key applications becomes a jackpot for threat actors.
A successful exploit does not merely disrupt operations—it can provide a beachhead for lateral movement, allowing attackers to pivot into production networks, alter configurations, steal sensitive IP, or even cause physical damage depending on the target installation’s automation tasks.
Sector Specifics: Manufacturing and Education Impact​
  • Critical Manufacturing: Factories implementing FESTO solutions may face downtime, sabotage, or theft of proprietary configurations and process logic.
  • Education: Universities and technical colleges using affected software for teaching may unwittingly expose campus networks or sensitive student and research data.
  • Global Reach: FESTO’s presence ensures that vulnerable deployments are distributed worldwide, including in regions where industrial cybersecurity maturity varies.
Timeline and Disclosure: Coordination and Transparency​
FESTO reported the issue through responsible disclosure, working with CERT@VDE to coordinate fixes and public advisories. The vulnerability was registered as CVE-2023-3935, with the first advisories going live in early July 2025. Notably, the company provided clear workarounds and mitigation guidance even for legacy products—demonstrating a mature approach to incident response and customer support.
CISA echoed these findings in its Industrial Control Systems advisories, classifying the risk as critical and recommending immediate mitigations for all affected deployments.
Mitigation and Remediation Guidance​
Addressing systemic vulnerabilities in foundational components is never trivial, especially when legacy software and entrenched deployment practices are involved. FESTO and FESTO Didactic, to their credit, have published step-by-step mitigation recommendations.
Vendor Steps​
  • CIROS Studio / Education (v6.0.0–6.4.6, 7.0.0–7.1.7), FluidSIM (5, 6≤6.1c), MES-PC (pre-Dec 2023):
  • Immediate Action: Update CodeMeter Runtime to version 7.60c or later. The latest builds are available from the Wibu Systems support portal.
  • Festo Automation Suite (≤2.6.0.481):
  • Planned Fix: Patch will be included in the Summer 2024 release. Until then, users should monitor for security updates and apply other mitigations listed below.
  • FluidDraw (P6≤6.2k, 365≤7.0a):
  • Immediate Action: Upgrade to the most recent version available.
General ICS and OT Security Best Practices​
CISA and other authorities have echoed several universal best practices, especially for Internet-facing or hybrid OT/IT environments:
  • Limit Network Exposure: Wherever possible, ensure that control system components are not directly reachable from the Internet. Use network segmentation and robust internal firewalls between business and operational technology networks.
  • Remote Access Security: If remote control or maintenance is necessary, employ VPNs or encrypted remote access platforms—but recognize that VPNs themselves must be kept up-to-date and not be the weakest link.
  • Patch Management: Establish a formal, tested process for prompt application of security patches, prioritizing “critical” and “high” vulnerabilities.
  • Monitoring and Incident Response: Monitor for abnormal network or device activity. Ensure that detected anomalies that might indicate compromise are escalated and investigated quickly.
  • Social Engineering Defenses: Train staff to avoid phishing and spearphishing attempts. Verify links and never open unexpected attachments, particularly in environments where user workstations have privileged network access.
Longevity of the Threat and Vendor Responsibility​
As of the latest reporting, there are no known public exploits specifically targeting this vulnerability. However, the widespread deployment of FESTO and Wibu CodeMeter—both in live production and outdated legacy environments—means that threat actors could rapidly reverse engineer the patch and weaponize proof-of-concept code. This history is seen time and again in ICS security.
Organizations should anticipate such exploits by closing all known gaps as quickly as possible. More important still, they should build incident response capabilities ready to detect and contain breaches even in the absence of known exploits.
FESTO’s Response: Best Practice or Business as Usual?​
The speed and clarity of FESTO’s advisories signal a positive direction for the industry. Contrast this with the all-too-common scenario where vendors delay disclosure, minimize the scope of risk, or provide patch timelines that leave users exposed for months. FESTO’s transparency, partnership with external security researchers, and commitment to clear customer communication set a notable benchmark.
That said, not all responses are created equal. The delay in patch delivery for Festo Automation Suite (pending a Summer 2024 release) does leave a window of exposure for some customers. This underscores the challenge of balancing the need for rigorous regression testing with the urgency of field rollouts—particularly in environments where custom integration, third-party dependencies, and customer-specific modifications complicate updates.
Industry-Wide Lessons: Licensing Services as Attack Surfaces​
This incident spotlights a long-standing blind spot in ICS and OT security: the use of third-party licensing and copy-protection layers in industrial software. Often treated as low-priority or “infrastructure” components, these services can introduce critical vulnerabilities that affect every dependent product.
Comparable scenarios have unfolded in other sectors, from FlexNet in engineering CAD tools to Sentinel HASP in scientific software. For industrial vendors, every embedded runtime—no matter its origin—must be scrutinized as a potential attack surface.
Proactive Steps for the Ecosystem​
  • Vendor Due Diligence: Rigorous security testing and supply chain risk assessment of all bundled runtimes and third-party libraries.
  • Customer Vigilance: Refusing to treat “supporting” components as black boxes—requiring transparency from suppliers and regular review of embedded software versions and vulnerabilities.
  • Sector Collaboration: Real-time sharing of exploit indicators and mitigation strategies. The role of entities like CERT@VDE and CISA is pivotal, but so is broader adoption of standards like the Common Security Advisory Framework (CSAF) to facilitate automated vulnerability management.
Critical Analysis: Strengths and Weaknesses Exposed​
Notable Strengths​
  • Coordinated Vulnerability Disclosure: Collaboration between CERT@VDE, FESTO, and CISA enabled broad awareness and actionable guidance before widespread public attacks.
  • Comprehensive Impact Assessment: The advisories cover not just factory-floor products, but also those used in educational and simulation contexts, securing the full spectrum of users.
  • Clear Remediation Pathways: Specific upgrade and patch instructions reduce ambiguity and help even non-expert system administrators respond quickly.
Potential Risks and Weaknesses​
  • Legacy System Exposure: Many educational and industrial environments run old versions for years, constrained by budgets or operational needs. There is a real risk that unsupported, unpatched installations will remain vulnerable for the foreseeable future.
  • Dependence on Third-Party Components: Relying on widespread licensing servers like CodeMeter creates single points of failure. Even best-in-class vendors like FESTO are only as secure as their weakest embedded runtime.
  • Patch Lag: While patch timelines for most affected products are commendable, any delays can be catastrophic in production environments—particularly if exploits emerge “in the wild.”
  • Human Factor: Social engineering remains an attack vector. Technology fixes are necessary, but end-user vigilance and organizational discipline are equally crucial to prevent successful attacks.
Looking Ahead: Building Resilience in Industrial Software​
The FESTO CodeMeter vulnerability is a clear wake-up call: as manufacturing, education, and research accelerate digitization, no part of the software supply chain is immune from critical vulnerabilities. Vigilance, rapid response, and ongoing collaboration across vendors, researchers, and users represent the best defense.
For industrial automation professionals and educators alike, the immediate task is to identify and remediate all at-risk FESTO deployments. But the broader charge is even clearer: treat every third-party integration, every “invisible” component, as a potential risk; demand transparency and fast fixes from vendors; and ensure a culture of continuous, cross-functional cybersecurity education throughout the organization.
Those who heed these warnings—upgrading not just their software but their security mindset—will be best positioned to thrive as the smart factories and digital classrooms of tomorrow accelerate toward an ever more interconnected future.
Source: CISA FESTO Automation Suite, FluidDraw, and Festo Didactic Products | CISA
Support hub
