YaPaY
I installed 7052 32 bit version and setup newest geforce driver 181.22 forceware. I want to add custom resolution for my lcd tv toshiba. But I can not. I get always "custom mode test failed" errors.
Is there any solution?
I found a fix
Problem solved.
when creating the custom resolution (that you know it works under WinXP), just set the "Timing" Standard to "DMT" instead of automatic. there you go, it works :)
I'll take a stab at this......
Although you installed the "latest" drivers, they were probably not certified for Windows 7, correct?
You probably downloaded these drivers, GeForce Forceware 181.22 for Windows Vista 32-bit WHQL
No, it's GeForce Forceware 181.22 for Windows 7 32-bit WHQL
Well, you got me, i stand corrected.
By the way, I did a search for those drivers, and came up with no results for Windows 7.
Would you mind providing a link for me to try?
Link Removed due to 404 Error
it's for windows 7. You can download it from official website of nvidia
Thanks,
I appreciate it.
I went to the official Nvidia site previously and it stated to download the drivers using Windows Update, problem was there was no update for Windows 7 drivers.
I'm using latest 191.07 drivers (WHQL) official and cannot create custom resolutions in Win7 either (GeFoce 7600GS 256MB AGP). :(
I found a fix
Problem solved.
