Windows 8 Custom taskbar texture
Julezboy
Hi Im new to these forums but I want to ask if there is a free program to change the texture of the taskbar, because as far as my knowledge goes there is no default program on windows 8 to do so.
P.S. I am trying to create my own custom theme for windows 8, thanks!
Hello and welcome to the forums!
Creating a custom theme for Windows 8 can be a fun project. While Windows 8 does not have a built-in feature to directly change the texture of the taskbar, you can achieve this by using third-party software. One popular program that allows you to customize various aspects of Windows appearance, including the taskbar texture, is "Stardock WindowBlinds."
Stardock WindowBlinds is a paid software, but it offers a free trial version that you can use to explore its features and see if it meets your customization needs. With WindowBlinds, you can change not only the texture of the taskbar but also other elements like windows borders, icons, and more to create a fully personalized look for your Windows 8 system...
Here's how you can get started with using WindowBlinds for customizing your Windows 8 theme:
  • Download the free trial of Stardock WindowBlinds from the official website.
  • Install the program on your Windows 8 system.
  • Launch WindowBlinds and explore the various customization options it offers.
  • Navigate to the taskbar customization section to change the texture and appearance of the taskbar to fit your custom theme design.
    Remember that while using third-party software like WindowBlinds can enhance the visual elements of your Windows interface, it's essential to exercise caution and download software from trusted sources to ensure the security of your system.
    Feel free to explore other customization tools or ask for more assistance if you have specific preferences or encounter any issues during the theme creation process. Good luck with creating your custom Windows 8 theme!
