CVE-2024-47661: Linux AMD DRM Display Fix Prevents 32-bit to 8-bit Overflow
Stylized circuit board featuring Linux's Tux, an AMD chip, and CVE-2024-47661 warning.
A small arithmetic oversight in the Linux kernel's AMD display stack—tracked as CVE-2024-47661—was patched with a surgical code change that prevents an integer overflow when a 32-bit value is assigned into an 8-bit field; while the flaw is not remotely exploitable, it carries a clear availability risk for systems that expose the AMD DRM/display driver and should be treated as a high-priority kernel update for affected hosts.
Background / Overview​
The Linux kernel's graphics driver for AMD GPUs (the amdgpu DRM/display path) is a complex, hardware-aware subsystem that performs low-level register programming and resource bookkeeping. Small type-mismatch mistakes or unchecked arithmetic in this privileged code can turn into kernel oopses, driver resets, or even host reboots. CVE-2024-47661 is one of a cluster of AMD DRM fixes from late 2024 that follow this pattern: static analysis (Coverity and similar) flagged integer and indexing problems, and maintainers applied minimal, defensive patches to eliminate the crash primitives. What the CVE entry states in concise terms: the field dmub_rb_cmd::ramping_boundary is defined as a uint8_t but was being assigned the 32‑bit constant 0xFFFF in code paths, producing an obvious overflow / wraparound. The remedial change normalizes the assigned value to match the target width (for example 0xFF) or otherwise ensures the assignment cannot overflow the 8‑bit container. This resolves two INTEGER_OVERFLOW warnings raised by static analysis tools. Key operational metadata
  • CVE identifier: CVE-2024-47661.
  • Public disclosure / NVD listing date: 9 October 2024 (NVD published entry).
  • Typical severity/score reported by multiple trackers: CVSS v3.1 base score ~5.5 (Medium), primary impact: Availability.
  • Affected baseline: upstream Linux kernels prior to the stable commit that fixed the issue (mappings reported against kernel trees used by distributions; some trackers map vulnerable versions to kernels before 6.10.9 in vendor tables).
The bug explained: how a 32-bit value ended up in an 8-bit bucket​
The immediate code problem​
At its core, CVE-2024-47661 is a classic mixed-width assignment / integer overflow problem. A structure used by DMUB (Display Microcontroller Unit Bridge) or related amdgpu display code declares a field with width uint8_t (one byte), yet at least one code path assigned a 32‑bit constant 0xFFFF (decimal 65535) into that field. When a larger integer is written into a smaller unsigned container, the value truncates to the low-order bits (0xFFFF truncated to one byte becomes 0xFF on typical architectures) or triggers static-analysis warnings about possible logical errors. Coverity flagged two such INTEGER_OVERFLOW issues and asked maintainers to make the code's intent explicit and safe. Why this matters in kernel drivers: assigning out-of-range values into hardware control fields can produce invalid behavior when those values are later used to index arrays, compute loop bounds, program hardware registers, or calculate timeouts. In kernel-space graphics code, incorrect values don't merely crash a process — they can result in kernel oopses, driver resets, or hardware sequences that deadlock, producing a loss of availability for the system until a reboot or driver reload. Several distribution and vendor advisories for the family of drm/amd/display fixes emphasize availability-first impacts and recommend prompt kernel updates.
How maintainers fixed it​
The upstream change is intentionally small and defensive:
  • Ensure assignments to small-width fields are constrained to the field's range (e.g., only assign 0xFF for an 8-bit field instead of 0xFFFF), or
  • Promote the operand to a wider type where the arithmetic happens and explicitly bound-check before narrowing, or
  • Replace the magic constant with a symbolic limit that makes the code's intent clear and avoids implicit truncation.
These fixes eliminate the static-analysis warning and make the runtime behavior explicit and safe under legitimate and edge-case inputs. Kernel maintainers prefer this surgical approach for device drivers because it is low-risk and easy to backport into stable kernel branches that distributions carry.
Impact analysis: availability-first, local attack surface​
What an attacker can and cannot do​
  • Attack vector: local. An attacker or unprivileged process must be able to execute code on the host and to exercise the affected amdgpu/display code paths. Typical triggers include compositor interactions, video playback, hot‑plug/docking operations, or other modesetting operations that touch the DRM stack. In container contexts, exposure depends on whether /dev/dri devices are exposed or GPU passthrough is used.
  • Privilege requirement: low in many desktop setups. Unprivileged users often influence the display stack (compositors, media players, GPU-accelerated rendering) and can therefore reach DRM drivers indirectly. Hardened servers that restrict access to /dev/dri are less exposed.
  • Likely outcome of exploitation: denial-of-service (kernel oops, driver fault, or host instability). No authoritative public proof-of-concept demonstrating privilege escalation or remote code execution tied to this CVE was published at disclosure time; therefore claims of RCE should be treated as unverified unless a credible PoC appears.
In plain terms: this CVE gives attackers a reproducible way to corrupt internal driver state or induce undefined runtime behavior, and the predictable consequence is instability and availability loss. For multi-tenant infrastructure (CI runners, shared GPU hosts, VDI) and appliances that expose GPUs to untrusted workloads, the practical effect can be severe.
Why availability is the principal concern​
Kernel drivers run with full system privilege. An unchecked numeric or indexing mistake in the display driver frequently results in invalid memory access, illegal CPU instructions (UBSAN-detected shifts), or register sequences that cause hardware to behave unpredictably. Unlike user-space processes, which can crash without bringing the host down, kernel crashes may require reboots and cause downtime for all services on the host. Distribution advisories and vendor trackers therefore emphasize availability as the primary impact—even when confidentiality and integrity are not demonstrably affected.
Who is affected and how to triage exposure​
Affected systems share two characteristics:
  • They run a Linux kernel that includes the vulnerable drm/amd/display code before the upstream stable commit that fixed the issue. Trackers generally map the vulnerable ranges to older kernel series (some distributions mapped the vulnerability to kernels prior to 6.10.9), but exact mappings depend on vendor backports and packaging.
  • The system actually loads the AMD GPU driver (amdgpu) and has workflows that can reach the DRM/display code paths—this includes desktops with AMD GPUs, workstations, and servers that expose GPUs via passthrough or device mapping. Container images inherit the host kernel: containers themselves are not “fixed” by updating their images; the host kernel must be patched.
Short triage checklist to identify exposed assets:
  1. Run uname -r across your fleet and build a list of kernels in use.
  2. Check whether the amdgpu module is loaded: lsmod | grep amdgpu.
  3. Inspect device nodes and permissions: ls -l /dev/dri/*. Note which users, groups, or containers have access.
  4. Cross-reference your kernel package versions against your vendor’s security advisory or the distribution security tracker (Ubuntu USNs, Debian tracker, SUSE bulletins) to confirm whether your package includes the upstream fix.
Patching and mitigation guidance​
The definitive remediation is to install vendor kernel updates that include the upstream stable commit fixing CVE-2024-47661 and then reboot into the patched kernel. Kernel-level fixes only become effective after a reboot.
Immediate remediation steps (recommended order)
  1. Inventory and prioritize:
    1. Enumerate kernels with uname -r and tag hosts that run AMD GPUs or load amdgpu.
    2. Identify hosts exposing /dev/dri to untrusted users or containers.
  2. Patch:
    1. Install the vendor/distribution kernel update that explicitly lists the fix for CVE-2024-47661 or contains the upstream stable commit referenced in vendor changelogs. Ubuntu and other major distributions published mapped package updates. 2. Reboot into the updated kernel promptly.
  3. Short-term mitigations (if you cannot patch immediately):
    • Restrict access to DRM device nodes via udev rules and group membership (remove untrusted accounts from video/render groups).
    • Avoid mounting /dev/dri into multi-tenant or untrusted containers and disable GPU passthrough for shared CI runners.
    • Harden container capabilities: drop CAP_SYS_ADMIN or other capabilities that could enable direct hardware interaction.
    • Add SIEM and telemetry rules to flag kernel oops messages, repeated amdgpu resets, or pageflip timeouts. Collect dmesg/journalctl logs for forensic correlation.
Why backport-awareness matters: mainstream distributions often cherry-pick the surgical fix into stable kernel trees quickly, but vendor forks, embedded devices, OEM appliance kernels, and long-tail images can lag. Inventory and confirm that the firmware/kernel image your vendors ship contains the fix—not just that an upstream commit exists.
Wider context: why these fixes keep appearing and what they mean for operators​
Static analysis is finding the low-level mistakes​
A recurring theme across recent DRM fixes is that static analysis tools (Coverity, smatch, UBSAN runs during testing) repeatedly uncover corner-case integer and indexing issues: mixed-width shifts, unchecked indices when counts are zero, wrong constants used for array sizes, etc. Those warnings typically map to availability-impact bugs when present in kernel-space driver code. The Linux upstream team’s response pattern is consistent: apply a small defensive patch (cast/promote, bound-check, or use the correct constant) and backport to stable branches to minimize operational risk.
Practical implications for enterprise fleets​
  • Multi-tenant hosts and CI runners with GPU access are high priority: an unprivileged user or untrusted guest triggering a crash can cause host-wide outages and impact many tenants.
  • Containers inherit the host kernel, so container-focused patching strategies are insufficient when the underlying kernel remains vulnerable. Rebooting hosts into patched kernels is essential.
  • Vendor-provided appliances and embedded devices often have longer update cycles—expect a long tail of vulnerable systems unless OEMs issue firmware/kernel updates.
Verification and cross-references​
The technical description and remediation mapping for CVE-2024-47661 were confirmed against multiple independent trackers and advisories:
  • NVD (National Vulnerability Database) lists CVE-2024-47661 and describes the integer overflow in drm/amd/display and the remediation approach.
  • Ubuntu’s security tracker published a CVE page with the CVSS 3.1 score (5.5) and maps fixed package versions for various releases, providing actionable package-level guidance.
  • SUSE’s kernel update announcements and other vendor advisories include the upstream stable patch and enumerate the drm/amd/display fixes applied to their kernels (including the “Avoid overflow from uint32_t to uint8_t” entry in stable-fixes lists).
These independent sources corroborate the technical root cause (assignment of 0xFFFF into an 8-bit field), the remedial change style (narrowing the constant or adding a guard), the CVSS scoring, and the recommended operational remediation (install patched kernel and reboot). If your environment requires absolute assurance, check the vendor package changelog for the stable commit hash to verify the patch is present in your specific kernel package. Caveat / unverifiable items
  • There was no authoritative public proof-of-concept published at disclosure time that reliably escalates privileges or achieves remote code execution via this specific bug; any claim of RCE should therefore be treated cautiously until a credible PoC appears. Distribution advisories and trackers consistently classify this as an availability-first vulnerability.
Operational checklist (quick reference)​
  1. Inventory:
    1. List kernels: uname -r across fleet.
    2. Identify AMD GPU hosts: lsmod | grep amdgpu.
    3. Identify hosts that expose /dev/dri to untrusted workloads or containers.
  2. Patch:
    1. Install vendor/distribution kernel updates that include the stable patch for CVE-2024-47661. Confirm via package changelog.
    2. Reboot hosts into patched kernels.
  3. Interim mitigations:
    • Restrict device node access with udev and group membership.
    • Remove /dev/dri from container mounts and disable GPU passthrough for untrusted workloads.
    • Monitor logs for DRM/AMDGPU oopses and pageflip timeouts.
  4. Post-patch validation:
    • Confirm amdgpu module load and run a short validation workload (non-destructive) or rely on vendor test suites.
    • Check kernel dmesg/journal for repeated errors or regression symptoms.
Why this matters to WindowsForum readers and enterprise operators​
Even though CVE-2024-47661 is a kernel bug in Linux’s AMD display driver, it matters broadly because modern mixed OS stacks and heterogeneous compute footprints increasingly share GPUs across workloads and clouds. Organizations that run Linux guests on Windows hosts (or vice versa), operate multi‑tenant GPU-enabled CI systems, or support developer workstations where untrusted code can be executed must treat kernel driver fixes as operationally significant.
  • Patching kernels is an operational task that involves coordination and reboots—plan windows accordingly.
  • Containers are not a mitigation for kernel bugs—host-level patching is required.
  • Static analysis tools like Coverity do uncover real, operationally significant bugs; the upstream process of small defensive patches and backports is effective and should be watched closely in your distro advisories.
CVE-2024-47661 is a deliberate example of a seemingly trivial coding mistake—assigning a 32‑bit constant into an 8‑bit field—that can have outsized operational consequences when it lives in kernel device-driver code. The fix itself is small and conservative, but the operational remedy is clear: confirm that your distribution or vendor kernel package includes the upstream stable commit and reboot into the patched kernel. For multi‑tenant hosts, CI/CD runners, and any systems exposing GPU devices to untrusted code, prioritize this update; use access controls on /dev/dri and deny GPU passthrough to untrusted workloads as an interim mitigation until patches and reboots are complete.
