Microsoft’s public advisory for CVE-2025-38395 names a Linux kernel bug in the regulator gpio driver — a classic out‑of‑bounds allocation mistake — and confirms Azure Linux as the Microsoft product the company has already mapped to the affected upstream component, but the reality for enterprises and Windows users is more nuanced: any Microsoft product that ships or operates a Linux kernel build (notably Windows Subsystem for Linux, AKS node images, and other Azure-provided kernels) is plausibly in scope and deserves immediate inventory and verification.
Neon 3D diagram shows Linux kernel vulnerability CVE-2025-38395 with patch and security icons.Background / Overview​
CVE-2025-38395 is an upstream Linux kernel vulnerability in the regulator GPIO driver. The root cause is simple and common in systems programming: a structure field (drvdata->gpiods) intended to hold an array of GPIO descriptor pointers was only allocated space for a single pointer. If the hardware configuration requests more GPIOs (config::ngpios > 1), later code will index past the allocation and trigger an out‑of‑bounds memory access. The patch corrects allocation logic so drvdata->gpiods reserves space for config::ngpios entries, and it reorders the allocation/failure check for clarity. This is a kernel‑level bug (drivers/regulator/gpio‑regulator.c) and therefore it’s a problem for binaries that include that kernel code. Unlike a userland library where an application can link against a particular package, the Linux kernel is a monolithic target: any product that ships or runs a kernel binary built from the vulnerable upstream code — or a distribution kernel that contains the vulnerable driver — is a candidate for impact. Upstream maintainers and multiple distributions have released fixes or backports into stable kernels and downstream packages.
What Microsoft publicly stated (and what that statement actually means)​
Microsoft’s Security Response Center (MSRC) entry and related Microsoft posts make two important points:
  • Microsoft has published machine‑readable VEX/CSAF attestations and has started with the Azure Linux distribution (formerly CBL‑Mariner). Their VEX pilot clarifies which Microsoft product artifacts include specific upstream components. Microsoft explicitly says Azure Linux was identified as “including this open‑source library and therefore potentially affected,” and that they will update the CVE if additional products are identified.
  • The MSRC advisory FAQ language — repeated across multiple vulnerability pages — is an inventory attestation, not a global exclusion. In plain terms: Microsoft has validated Azure Linux for this upstream component; the company has not yet completed attestation for every other Microsoft product. They explicitly commit to expanding the VEX/CSAF mapping over time.
That distinction — between “this is what we have validated so far” and “this is the only Microsoft artifact that could ever contain the vulnerable code” — is the critical operational nuance many teams miss.
Technical verification: upstream patch and distribution responses​
The fix for the kernel source was merged upstream and propagated into the stable trees and distribution kernels. The upstream patch is visible in the regulator tree and has been picked into multiple stable branches (the commit is referenced as c9764fd... in stable backports). Kernel maintainers included the patch in several stable branches and distributions have published package updates to include the fix. Distribution advisories (Debian, Ubuntu, Red Hat and other vendors) mapped the CVE to fixed kernel package versions — showing a standard vendor response: patch upstream, backport to supported kernel lines, and ship updated kernel packages. If you run a mainstream distro kernel (vendor-supplied, distribution kernel), check your distribution’s advisory and update channels; most Linux vendors already have fixes in place or scheduled packages.
Is Azure Linux the only Microsoft product that includes the library (and is therefore affected)?​
Short answer: No — Azure Linux is not necessarily the only Microsoft product that could include the vulnerable kernel code. It is the only Microsoft product Microsoft has publicly attested to include that upstream component so far, but absence of an attestation for other Microsoft artifacts is not proof that those artifacts are unaffected. Microsoft has stated it will update the CVE/VEX entries if more products are identified. Why that matters practically:
  • The CVE is a Linux kernel issue. Any product that ships a Linux kernel binary with that driver present, or any environment that runs a kernel built from the vulnerable upstream commits, is in the attack surface.
  • Microsoft operates and publishes multiple kernel artifacts that are built in different pipelines and may include different commit ranges and configuration options. These distinct artifacts are separate inventory items: Azure Linux images, Microsoft’s WSL2 kernel builds, linux-azure/“Azure‑tuned” kernels used for some VM SKUs, AKS container host images, and curated Marketplace images. Any of these can be a carrier depending on build choices.
Concrete Microsoft artifacts to consider (plausible carriers):
  • Azure Linux (attested) — Microsoft has explicitly mapped this artifact to the upstream component and flagged it for customers. This is authoritative for Azure Linux.
  • Windows Subsystem for Linux (WSL2) kernel builds — Microsoft maintains and ships the WSL2 kernel and also releases the kernel source (microsoft/WSL2‑Linux‑Kernel). WSL’s kernel lineage can contain upstream fixes or vulnerabilities depending on the kernel release used by the WSL package on your Windows host. WSL kernels are serviced by Microsoft Update and are a separate artifact from Azure Linux. That makes WSL an obvious candidate to inventory.
  • linux-azure / Azure‑tuned kernels and AKS node images — some Azure VM and container host images use kernels that are tuned or built for cloud environments; those builds may share code with Azure Linux or be independently maintained. AKS’s Azure Linux Container Host is explicitly based on CBL‑Mariner lineage and Microsoft publishes separate node image lifecycles for AKS.
These items are not conjecture; they’re operational facts about how Microsoft builds and ships Linux artifacts. What remains a work item is the per‑artifact inventory that proves which specific kernel builds include the exact fixed or vulnerable upstream commits. Microsoft’s VEX/CSAF pilot provides that inventory for Azure Linux first; the rest of the product landscape is in progress.
Risks and attacker model​
  • Local exploitation is the primary exposure class. This particular bug is a memory corruption triggered by a kernel driver misallocation; exploitation usually requires local access and device configuration that exercises the driver with ngpios > 1. In cloud and multi‑tenant contexts where kernel modules and hardware pass‑through exist, attacker-controlled configurations or local escalation paths can be a serious concern. Upstream advisories and distribution CVE mappings characterize the typical attack vector as local.
  • Device drivers are a common pivot point. Driver-level OOB writes or reads can be used in local privilege escalation chains. If an attacker can execute code or reach a shell on a VM or a container host with the vulnerable kernel loaded, kernel exploitation can lead to host compromise. The practical severity depends on exploitability details (privilege model, module loading, sandboxing) and whether vendor mitigations (KASLR, SMEP, user namespaces restrictions) are present.
  • Cloud/managed services nuance. If you run container workloads on AKS node pools or Azure Linux-based hosts, the vulnerable kernel is your host kernel — not the container image’s userland. That means containerized apps may be indirectly impacted by a host kernel flaw. Conversely, a VM that uses a vendor kernel from the image publisher (Ubuntu, Red Hat, etc. might be impacted by the distribution’s kernel version rather than Microsoft’s attestation. Inventory and verification are essential.
Practical verification and remediation steps (prioritized)​
  • Patch Azure Linux hosts immediately.
  • If you run Azure Linux (CBL‑Mariner / AzureLinux SKUs), follow Microsoft’s remediation guidance and the VEX/CSAF attestation: apply the kernel update Microsoft published for the affected Azure Linux builds. The MSRC attestation for Azure Linux is authoritative and actionable.
  • Inventory Microsoft-supplied Linux artifacts in your estate.
  • Create an inventory that explicitly lists:
  • Azure Linux node pools, container hosts, and VM images using Azure Linux.
  • Any AKS node images and OS SKUs in use (including older Azure Linux versions).
  • Windows hosts with WSL2 installed and which WSL kernel version they use.
  • Marketplace appliances or partner images that Microsoft lists as “curated” or “Microsoft-maintained.”
  • Use Microsoft’s CSAF/VEX outputs and the Azure Learn docs to map product SKUs to kernel artifacts.
  • Check your WSL kernel versions and update if necessary.
  • On a Windows machine with WSL2, open a WSL shell and run uname -r to see the running kernel version. Compare that version against the fixed kernel versions published by upstream or Microsoft’s WSL kernel repo. Microsoft publishes the WSL kernel source and ships prebuilt kernels via the Store or Windows Update, so keep WSL updated.
  • Verify AKS/VM node kernels.
  • For AKS clusters: query node OS SKUs and kernel release; if nodes run Azure Linux or a Microsoft-supplied kernel build, prioritize patching or node pool upgrades. Microsoft documents the Azure Linux container host lifecycle and AKS node SKUs in the AKS Azure Linux FAQ and intro pages.
  • Adopt Microsoft’s VEX/CSAF feeds into your automation.
  • Microsoft’s VEX pilot for Azure Linux is a machine‑readable source of truth for the products Microsoft has validated. Integrate the CSAF/VEX files into your vulnerability automation so you’ll receive immediate updates if Microsoft maps additional products to the same upstream component.
  • For custom appliances / Marketplace images, require vendor SBOM or kernel provenance.
  • If you run third‑party Marketplace appliances or partner images, request their SBOM/kernel build information or verify the kernel binary inside the image. Microsoft’s attestation model applies to Microsoft-built artifacts — partner images must be reconciled case by case.
How to check a host quickly (commands and outcomes)​
  • On Linux host (or WSL shell):
  • uname -r — reveal exact kernel release string.
  • modinfo gpio-regulator or grep -n "gpiod" /boot/config-$(uname -r) — inspect whether the driver or relevant config option is present.
  • For packaged kernels, consult distro advisory mapping for CVE-2025-38395 and check installed kernel package version.
  • On Windows with WSL:
  • wsl --status — show WSL version and kernel details for serviced WSL instances.
  • wsl -d <distro> uname -r — check the runtime kernel string inside the distro; if it’s a Microsoft‑provided kernel, compare with WSL kernel release notes and MSRC advisories.
Note: exact mapping from uname -r to upstream commit range may require vendor guidance; where possible, consult Microsoft’s published kernel release notes (WSL kernel releases) or your distribution’s CVE advisory.
Strengths in Microsoft’s approach — and where more clarity is needed​
Strengths
  • Microsoft’s adoption of machine‑readable CSAF/VEX for Azure Linux is a major transparency step. Publishing structured attestations reduces ambiguity and enables automation in enterprise vulnerability orchestration. This directly addresses the “which product ships component X” problem.
  • Microsoft’s public wording is appropriately cautious: it names the product the company has validated (Azure Linux) and pledges to update CVE and VEX entries when more products are identified. That’s the correct public‑facing posture when a full product inventory is still in progress.
Gaps / risks
  • VEX/CSAF coverage is partial at rollout. Microsoft’s pilot started with Azure Linux; until VEX mapping extends across other Microsoft product lines, customers must perform artifact‑level verification themselves. Absence of a VEX attestation is not a badge of safety — it’s simply an unread entry in the company’s inventory.
  • The kernel is a moving target across Microsoft artifacts. Different kernels and kernel configurations across WSL, linux-azure, Azure Linux, and Marketplace images complicate triage. Customers may need to triage dozens or hundreds of kernel variants in large estates. Automated SBOM, kernel provenance, and integration with Microsoft’s CSAF feed are practical necessities.
Conclusion — actionable verdict​
  • Treat the MSRC statement as authoritative for Azure Linux and apply patches there without delay. Microsoft’s VEX/CSAF attestation for Azure Linux is the canonical signal that those artifacts include the implicated upstream code and must be remediated.
  • Do not assume Azure Linux is the only Microsoft product that could contain the vulnerable kernel code. Any Microsoft artifact that ships or runs a Linux kernel — especially the WSL2 kernel and Azure-hosted node/VM images — is a plausible carrier until proven otherwise. Inventory those artifacts, check running kernel versions, and apply vendor updates or node pool upgrades as required.
  • Integrate Microsoft’s CSAF/VEX feeds into your vulnerability automation and maintain a short feedback loop for newly published attestations. Microsoft has committed to expanding VEX mapping beyond Azure Linux; where possible, rely on those machine‑readable attestations for faster, lower‑noise triage.
  • If you need a fast, prioritized checklist: patch Azure Linux first; inventory WSL and AKS/node images next; integrate VEX/CSAF; and request kernel provenance from any Marketplace or partner images in use.
Final caution: the upstream patch and vendor advisories are already publicly visible and mapped to distribution kernel updates. If your environment runs any Linux kernel build from the vulnerable upstream range, assume you need to test and patch. Public attestations are an important automation aid, but they are not a substitute for asset-level verification in heterogeneous IT estates.
