Hi DexterZeus and Welcome to The Forum.
STOP 0x0000000A: IRQL_NOT_LESS_OR_EQUAL
Usual causes: Kernel mode driver, System Service, BIOS, Windows, Virus scanner, Backup tool, compatibility.
STOP 0x0000001A: MEMORY_MANAGEMENT
Usual causes: Device driver, memory, kernel.
Your latest dump files list
win32k.sys and
ntkrpamp.exeas the probable cause(s). These are Windows System file and for them to be the cause of your crash is highly unlikely.
Old and incompatible drivers can and do cause issues with Windows 7, often giving false error codes. Random stop codes can often indicate hardware issues.
As a Priority:
Norton is known to be a cause of BSOD's on many Windows 7 systems. I suggest that you uninstall Norton using the
Link Removed in Safe Mode. Download Blue Screen friendly
Link Removed due to 404 Error as its replacement. Make sure Windows firewall is enabled!
Outdated Drivers. Update:
atiide.sys Thu Sep 07 21:37:20 2006 Check with
O.E.M. Support,
Motherboard Mfr. or
Link Removed Controller Driver
bcm4sbxp.sys Tue Nov 21 12:25:43 2006 Broadcom 440x 10/100 Integrated Controller
Download and run
CPU-Z. Take screenshots/snips of the
Memory tab and
all the
slot#'s under the
SPD tab.
Go to
Post Reply, click on the
Go Advanced button and attach the screenshots/snips to your post for all the RAM experts to see by using the paper clip you will find on the top toolbar. Do not zip them up.
Download and install
RamMon. Run RamMon, select the
Export/Copy button. Select the Export/Copy format as
HTML then
Write to File. Include the saved report in a zipped file and attach.
Bugcheck Analysis:
* Bugcheck Analysis *
BugCheck 1A, {5003, c0802000, 2562, 25648c4}
Probably caused by : win32k.sys ( win32k!NtGdiCreateDIBSection+15a )
Followup: MachineOwner
1: kd> !analyze -v
MEMORY_MANAGEMENT (1a)
# Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 00005003, The subtype of the bugcheck.
Arg2: c0802000
Arg3: 00002562
Arg4: 025648c4
Debugging Details:
BUGCHECK_STR: 0x1a_5003
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: chrome.exe
CURRENT_IRQL: 0
TRAP_FRAME: 8f5dcbc8 -- (.trap 0xffffffff8f5dcbc8)
ErrCode = 00000000
eax=05e02000 ebx=05950000 ecx=00001000 edx=fffff000 esi=05bba000 edi=05e02000
eip=82e42d75 esp=8f5dcc3c ebp=8f5dcc44 iopl=0 nv up ei ng nz na pe cy
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010287
nt!ProbeForWrite+0x39:
82e42d75 8a06 mov al,byte ptr [esi] ds:0023:05bba000=??
Resetting default scope
LAST_CONTROL_TRANSFER: from 82c7e5db to 82cf8eb4
STACK_TEXT:
8f5dca74 82c7e5db 0000001a 00005003 c0802000 nt!KeBugCheckEx+0x1e
8f5dcaac 82cabc8d c002dde0 84c9aa0c 00000040 nt!MiAllocateWsle+0x6f
8f5dcb28 82caa8ad 8f5dcae0 00000000 86225f30 nt!MiDispatchFault+0x536
8f5dcbb0 82c5b3e8 00000000 05bba000 00000000 nt!MmAccessFault+0x25cc
8f5dcbb0 82e42d75 00000000 05bba000 00000000 nt!KiTrap0E+0xdc
8f5dcc44 82e775e9 05950000 004b2000 00000001 nt!ProbeForWrite+0x39
8f5dcc90 82e778f2 05950000 004b2000 00000004 nt!MiSecureVirtualMemory+0xf7
8f5dccb0 9883c093 05950000 004b2000 00000004 nt!MmSecureVirtualMemory+0x1a
8f5dcd08 82c581fa 25010d34 00000214 05950000 win32k!NtGdiCreateDIBSection+0x15a
8f5dcd08 779c70b4 25010d34 00000214 05950000 nt!KiFastCallEntry+0x12a
WARNING: Frame IP not in any known module. Following frames may be wrong.
004bed20 00000000 00000000 00000000 00000000 0x779c70b4
STACK_COMMAND: kb
FOLLOWUP_IP:
9883c093 8945d4 mov dword ptr [ebp-2Ch],eax
SYMBOL_STACK_INDEX: 8
SYMBOL_NAME: win32k!NtGdiCreateDIBSection+15a
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: win32k
IMAGE_NAME: win32k.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4e65853e
FAILURE_BUCKET_ID: 0x1a_5003_win32k!NtGdiCreateDIBSection+15a
Drivers:
838a0000 838e8000 ACPI ACPI.sys Sat Nov 20 08:37:52 2010 (4CE788E0)
9171a000 91774000 afd afd.sys Mon Apr 25 03:18:00 2011 (4DB4D9D8)
95600000 95612000 AgileVpn AgileVpn.sys Tue Jul 14 00:55:00 2009 (4A5BC954)
839f0000 839f9000 amdxata amdxata.sys Fri Mar 19 16:19:01 2010 (4BA3A3F5)
83812000 8381b000 atapi atapi.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
8339c000 833bf000 ataport ataport.SYS Sat Nov 20 08:38:00 2010 (4CE788E8)
839af000 839afd80 atiide atiide.sys Thu Sep 07 21:37:20 2006 (45008300)
957dc000 957ed000 bcm4sbxp bcm4sbxp.sys Tue Nov 21 12:25:43 2006 (4562F047)
91632000 91639000 Beep Beep.SYS Tue Jul 14 00:45:00 2009 (4A5BC6FC)
93c9c000 93d67000 BHDrvx86 BHDrvx86.sys Thu Oct 13 01:30:44 2011 (4E963134)
93c8e000 93c9c000 blbdrive blbdrive.sys Tue Jul 14 00:23:04 2009 (4A5BC1D8)
832a7000 832af000 BOOTVID BOOTVID.dll Tue Jul 14 02:04:34 2009 (4A5BD9A2)
9395c000 93975000 bowser bowser.sys Wed Feb 23 04:47:32 2011 (4D649164)
83bbf000 83be3000 ccSetx86 ccSetx86.sys Mon Aug 08 22:35:03 2011 (4E405687)
98620000 9863e000 cdd cdd.dll Sat Nov 20 11:56:35 2010 (4CE7B773)
83ba0000 83bbf000 cdrom cdrom.sys Sat Nov 20 08:38:09 2010 (4CE788F1)
832f1000 8339c000 CI CI.dll Sat Nov 20 12:05:17 2010 (4CE7B97D)
893a6000 893cb000 CLASSPNP CLASSPNP.SYS Tue Jul 14 00:11:20 2009 (4A5BBF18)
832af000 832f1000 CLFS CLFS.SYS Tue Jul 14 00:11:10 2009 (4A5BBF0E)
89196000 891f3000 cng cng.sys Tue Jul 14 00:32:55 2009 (4A5BC427)
957ed000 957fa000 CompositeBus CompositeBus.sys Sat Nov 20 09:50:21 2010 (4CE799DD)
92d5a000 92d67000 crashdmp crashdmp.sys Tue Jul 14 00:45:50 2009 (4A5BC72E)
93c12000 93c76000 csc csc.sys Sat Nov 20 08:44:32 2010 (4CE78A70)
93c76000 93c8e000 dfsc dfsc.sys Sat Nov 20 08:42:32 2010 (4CE789F8)
92fc1000 92fcd000 discache discache.sys Tue Jul 14 00:24:04 2009 (4A5BC214)
89395000 893a6000 disk disk.sys Tue Jul 14 00:11:28 2009 (4A5BBF20)
92d37000 92d50000 drmk drmk.sys Tue Jul 14 01:36:05 2009 (4A5BD2F5)
83b63000 83ba0000 dtsoftbus01 dtsoftbus01.sys Wed Jul 27 15:03:27 2011 (4E301AAF)
92d7d000 92d86000 dump_atapi dump_atapi.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
92d67000 92d72000 dump_dumpata dump_dumpata.sys Tue Jul 14 00:11:16 2009 (4A5BBF14)
92d86000 92d97000 dump_dumpfve dump_dumpfve.sys Tue Jul 14 00:12:47 2009 (4A5BBF6F)
92d50000 92d5a000 Dxapi Dxapi.sys Tue Jul 14 00:25:25 2009 (4A5BC265)
9563c000 956f3000 dxgkrnl dxgkrnl.sys Sat Nov 20 09:08:14 2010 (4CE78FFE)
956f3000 9572c000 dxgmms1 dxgmms1.sys Thu Feb 03 03:45:05 2011 (4D4A24C1)
92f45000 92fa3000 eeCtrl eeCtrl.sys Fri Jul 08 02:45:11 2011 (4E166127)
92fa3000 92fc1000 EraserUtilRebootDrv EraserUtilRebootDrv.sys Fri Jul 08 02:45:11 2011 (4E166127)
957af000 957ba000 fdc fdc.sys Tue Jul 14 00:45:45 2009 (4A5BC729)
83a71000 83a82000 fileinfo fileinfo.sys Tue Jul 14 00:21:51 2009 (4A5BC18F)
92c9d000 92ca7000 flpydisk flpydisk.sys Tue Jul 14 00:45:45 2009 (4A5BC729)
833bf000 833f3000 fltmgr fltmgr.sys Tue Jul 14 00:11:13 2009 (4A5BBF11)
8900e000 89017000 Fs_Rec Fs_Rec.sys Tue Jul 14 00:11:14 2009 (4A5BBF12)
89363000 89395000 fvevol fvevol.sys Sat Nov 20 08:40:22 2010 (4CE78976)
89576000 895a7000 fwpkclnt fwpkclnt.sys Sat Nov 20 08:39:08 2010 (4CE7892C)
8302c000 83063000 hal halmacpi.dll Sat Nov 20 08:37:38 2010 (4CE788D2)
95790000 957af000 HDAudBus HDAudBus.sys Sat Nov 20 09:59:28 2010 (4CE79C00)
92cb8000 92d08000 HdAudio HdAudio.sys Sat Nov 20 10:00:19 2010 (4CE79C33)
92da2000 92db5000 HIDCLASS HIDCLASS.SYS Sat Nov 20 09:59:37 2010 (4CE79C09)
92db5000 92dbb480 HIDPARSE HIDPARSE.SYS Tue Jul 14 00:50:59 2009 (4A5BC863)
92d97000 92da2000 hidusb hidusb.sys Sat Nov 20 09:59:38 2010 (4CE79C0A)
938d7000 9395c000 HTTP HTTP.sys Sat Nov 20 08:40:17 2010 (4CE78971)
8941d000 89425000 hwpolicy hwpolicy.sys Sat Nov 20 08:37:35 2010 (4CE788CF)
92ee7000 92f45000 IDSvix86 IDSvix86.sys Wed Jul 20 14:18:06 2011 (4E26D58E)
93d88000 93d9a000 intelppm intelppm.sys Tue Jul 14 00:11:03 2009 (4A5BBF07)
91604000 9162b000 Ironx86 Ironx86.SYS Sat Jul 23 02:24:01 2011 (4E2A22B1)
93c00000 93c0d000 kbdclass kbdclass.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
92dc9000 92dd5000 kbdhid kbdhid.sys Sat Nov 20 09:50:10 2010 (4CE799D2)
80bcc000 80bd4000 kdcom kdcom.dll Tue Jul 14 02:08:58 2009 (4A5BDAAA)
92c17000 92c4b000 ks ks.sys Sat Nov 20 09:50:17 2010 (4CE799D9)
89183000 89196000 ksecdd ksecdd.sys Sat Nov 20 08:38:54 2010 (4CE7891E)
89301000 89326000 ksecpkg ksecpkg.sys Tue Jul 14 00:34:00 2009 (4A5BC468)
9385e000 9386e000 lltdio lltdio.sys Tue Jul 14 00:53:18 2009 (4A5BC8EE)
92dd5000 92df0000 luafv luafv.sys Tue Jul 14 00:15:44 2009 (4A5BC020)
83211000 83296000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Nov 20 12:00:54 2010 (4CE7B876)
92d72000 92d7d000 monitor monitor.sys Tue Jul 14 00:25:58 2009 (4A5BC286)
92fe4000 92ff1000 mouclass mouclass.sys Tue Jul 14 00:11:15 2009 (4A5BBF13)
92dbe000 92dc9000 mouhid mouhid.sys Tue Jul 14 00:45:08 2009 (4A5BC704)
839b0000 839c6000 mountmgr mountmgr.sys Sat Nov 20 08:38:09 2010 (4CE788F1)
93975000 93987000 mpsdrv mpsdrv.sys Tue Jul 14 00:52:52 2009 (4A5BC8D4)
a1630000 a1657000 mqac mqac.sys Sat Nov 20 10:40:34 2010 (4CE7A5A2)
93987000 939aa000 mrxsmb mrxsmb.sys Wed Apr 27 03:17:20 2011 (4DB77CB0)
939aa000 939e5000 mrxsmb10 mrxsmb10.sys Sat Jul 09 03:29:57 2011 (4E17BD25)
939e5000 93a00000 mrxsmb20 mrxsmb20.sys Wed Apr 27 03:17:26 2011 (4DB77CB6)
9168b000 91696000 Msfs Msfs.SYS Tue Jul 14 00:11:26 2009 (4A5BBF1E)
838f1000 838f9000 msisadrv msisadrv.sys Tue Jul 14 00:11:09 2009 (4A5BBF0D)
89158000 89183000 msrpc msrpc.sys Tue Jul 14 00:11:59 2009 (4A5BBF3F)
92edd000 92ee7000 mssmbios mssmbios.sys Tue Jul 14 00:19:25 2009 (4A5BC0FD)
89353000 89363000 mup mup.sys Tue Jul 14 00:14:14 2009 (4A5BBFC6)
89400000 8941d000 MxEFUF32 MxEFUF32.sys Thu Oct 28 03:33:39 2010 (4CC8E103)
a7183000 a7196600 NAVENG NAVENG.SYS Fri Jul 29 13:10:02 2011 (4E32A31A)
a7003000 a7182300 NAVEX15 NAVEX15.SYS Fri Jul 29 13:07:28 2011 (4E32A280)
8920c000 892c3000 ndis ndis.sys Sat Nov 20 08:39:19 2010 (4CE78937)
9562a000 95635000 ndistapi ndistapi.sys Tue Jul 14 00:54:24 2009 (4A5BC930)
938b4000 938c4000 ndisuio ndisuio.sys Sat Nov 20 10:06:36 2010 (4CE79DAC)
93d9a000 93dbc000 ndiswan ndiswan.sys Sat Nov 20 10:07:48 2010 (4CE79DF4)
92ca7000 92cb8000 NDProxy NDProxy.SYS Sat Nov 20 10:07:39 2010 (4CE79DEB)
917dd000 917eb000 netbios netbios.sys Tue Jul 14 00:53:54 2009 (4A5BC912)
91774000 917a6000 netbt netbt.sys Sat Nov 20 08:39:22 2010 (4CE7893A)
892c3000 89301000 NETIO NETIO.SYS Sat Nov 20 08:40:03 2010 (4CE78963)
a6b30000 a6bc1000 netr73 netr73.sys Wed Oct 05 07:54:22 2011 (4E8BFF1E)
91696000 916a4000 Npfs Npfs.SYS Tue Jul 14 00:11:31 2009 (4A5BBF23)
92ed3000 92edd000 nsiproxy nsiproxy.sys Tue Jul 14 00:12:08 2009 (4A5BBF48)
82c1a000 8302c000 nt ntkrpamp.exe Thu Jun 23 03:23:05 2011 (4E02A389)
89029000 89158000 Ntfs Ntfs.sys Fri Mar 11 03:21:11 2011 (4D799527)
9162b000 91632000 Null Null.SYS Tue Jul 14 00:11:12 2009 (4A5BBF10)
951f8000 951f9040 nvBridge nvBridge.kmd Fri Apr 08 04:14:44 2011 (4D9E7DA4)
94809000 951f8000 nvlddmkm nvlddmkm.sys Sat Oct 15 07:34:27 2011 (4E992973)
9386e000 938b4000 nwifi nwifi.sys Tue Jul 14 00:51:59 2009 (4A5BC89F)
917ad000 917cc000 pacer pacer.sys Tue Jul 14 00:53:58 2009 (4A5BC916)
957ba000 957d2000 parport parport.sys Tue Jul 14 00:45:34 2009 (4A5BC71E)
8392e000 8393f000 partmgr partmgr.sys Sat Nov 20 08:38:14 2010 (4CE788F6)
93800000 93807000 parvdm parvdm.sys Tue Jul 14 00:45:29 2009 (4A5BC719)
838f9000 83923000 pci pci.sys Sat Nov 20 08:37:57 2010 (4CE788E5)
8399a000 839a1000 pciide pciide.sys Tue Jul 14 00:11:19 2009 (4A5BBF17)
839a1000 839af000 PCIIDEX PCIIDEX.SYS Tue Jul 14 00:11:15 2009 (4A5BBF13)
89000000 8900e000 pcw pcw.sys Tue Jul 14 00:11:10 2009 (4A5BBF0E)
a1657000 a16ee000 peauth peauth.sys Tue Jul 14 01:35:44 2009 (4A5BD2E0)
92d08000 92d37000 portcls portcls.sys Tue Jul 14 00:51:00 2009 (4A5BC864)
83296000 832a7000 PSHED PSHED.dll Tue Jul 14 02:09:36 2009 (4A5BDAD0)
95612000 9562a000 rasl2tp rasl2tp.sys Tue Jul 14 00:54:33 2009 (4A5BC939)
93dbc000 93dd4000 raspppoe raspppoe.sys Tue Jul 14 00:54:53 2009 (4A5BC94D)
93dd4000 93deb000 raspptp raspptp.sys Tue Jul 14 00:54:47 2009 (4A5BC947)
92fcd000 92fe4000 rassstp rassstp.sys Tue Jul 14 00:54:57 2009 (4A5BC951)
92e92000 92ed3000 rdbss rdbss.sys Sat Nov 20 08:42:44 2010 (4CE78A04)
93deb000 93df5000 rdpbus rdpbus.sys Tue Jul 14 01:02:40 2009 (4A5BCB20)
91673000 9167b000 RDPCDD RDPCDD.sys Sat Nov 20 10:22:19 2010 (4CE7A15B)
9167b000 91683000 rdpencdd rdpencdd.sys Tue Jul 14 01:01:39 2009 (4A5BCAE3)
91683000 9168b000 rdprefmp rdprefmp.sys Tue Jul 14 01:01:41 2009 (4A5BCAE5)
89326000 89353000 rdyboost rdyboost.sys Sat Nov 20 09:00:07 2010 (4CE78E17)
9382d000 9385e000 RMCAST RMCAST.sys Sat Nov 20 10:06:36 2010 (4CE79DAC)
938c4000 938d7000 rspndr rspndr.sys Tue Jul 14 00:53:20 2009 (4A5BC8F0)
916c7000 9171a000 SbFw SbFw.sys Tue Apr 05 19:08:08 2011 (4D9B5A88)
83a00000 83a0f400 SBFWIM SBFWIM.sys Tue Feb 08 11:33:47 2011 (4D512A1B)
a16ee000 a16f8000 secdrv secdrv.SYS Wed Sep 13 14:18:32 2006 (45080528)
957d2000 957dc000 serenum serenum.sys Tue Jul 14 00:45:27 2009 (4A5BC717)
83be3000 83bfd000 serial serial.sys Tue Jul 14 00:45:33 2009 (4A5BC71D)
895ef000 895f7000 spldr spldr.sys Mon May 11 17:13:47 2009 (4A084EBB)
a6a34000 a6ac6000 SRTSP SRTSP.SYS Tue Aug 02 21:26:19 2011 (4E385D6B)
92e82000 92e92000 SRTSPX SRTSPX.SYS Tue Aug 02 21:26:26 2011 (4E385D72)
a1776000 a17c8000 srv srv.sys Fri Apr 29 03:46:30 2011 (4DBA2686)
a1726000 a1776000 srv2 srv2.sys Fri Apr 29 03:46:13 2011 (4DBA2675)
a16f8000 a1719000 srvnet srvnet.sys Fri Apr 29 03:46:08 2011 (4DBA2670)
95635000 95636380 swenum swenum.sys Tue Jul 14 00:45:08 2009 (4A5BC704)
83a1a000 83a71000 SYMDS SYMDS.SYS Mon May 16 23:14:26 2011 (4DD1A1C2)
83a82000 83b63000 SYMEFA SYMEFA.SYS Fri Jul 22 01:20:59 2011 (4E28C26B)
92e5c000 92e82000 SYMEVENT SYMEVENT.SYS Thu May 05 04:15:41 2011 (4DC2165D)
92e08000 92e5c000 SYMNETS SYMNETS.SYS Thu Jul 21 03:12:31 2011 (4E278B0F)
8942c000 89576000 tcpip tcpip.sys Tue Jun 21 04:16:03 2011 (4E000CF3)
a1719000 a1726000 tcpipreg tcpipreg.sys Sat Nov 20 10:07:13 2010 (4CE79DD1)
916bb000 916c7000 TDI TDI.SYS Sat Nov 20 08:39:18 2010 (4CE78936)
916a4000 916bb000 tdx tdx.sys Sat Nov 20 08:39:17 2010 (4CE78935)
89017000 89028000 termdd termdd.sys Sat Nov 20 10:21:10 2010 (4CE7A116)
989e0000 989e9000 TSDDD TSDDD.dll unavailable (00000000)
93d67000 93d88000 tunnel tunnel.sys Sat Nov 20 10:06:40 2010 (4CE79DB0)
92c4b000 92c59000 umbus umbus.sys Sat Nov 20 10:00:23 2010 (4CE79C37)
92dbc000 92dbd700 USBD USBD.SYS Fri Mar 25 02:57:53 2011 (4D8C04B1)
95781000 95790000 usbehci usbehci.sys Fri Mar 25 02:57:58 2011 (4D8C04B6)
92c59000 92c9d000 usbhub usbhub.sys Fri Mar 25 02:58:34 2011 (4D8C04DA)
9572c000 95736000 usbohci usbohci.sys Fri Mar 25 02:57:58 2011 (4D8C04B6)
95736000 95781000 USBPORT USBPORT.SYS Fri Mar 25 02:58:05 2011 (4D8C04BD)
83923000 8392e000 vdrvroot vdrvroot.sys Tue Jul 14 00:46:19 2009 (4A5BC74B)
91639000 91645000 vga vga.sys Tue Jul 14 00:25:50 2009 (4A5BC27E)
91645000 91666000 VIDEOPRT VIDEOPRT.SYS Tue Jul 14 00:25:49 2009 (4A5BC27D)
839c6000 839ef180 vmbus vmbus.sys Sat Nov 20 09:14:58 2010 (4CE79192)
895a7000 895af380 vmstorfl vmstorfl.sys Sat Nov 20 09:14:37 2010 (4CE7917D)
8393f000 8394f000 volmgr volmgr.sys Sat Nov 20 08:38:06 2010 (4CE788EE)
8394f000 8399a000 volmgrx volmgrx.sys Tue Jul 14 00:11:41 2009 (4A5BBF2D)
895b0000 895ef000 volsnap volsnap.sys Sat Nov 20 08:38:13 2010 (4CE788F5)
a7197000 a71a1000 vwifibus vwifibus.sys Tue Jul 14 00:52:02 2009 (4A5BC8A2)
917cc000 917dd000 vwififlt vwififlt.sys Tue Jul 14 00:52:03 2009 (4A5BC8A3)
917eb000 917fe000 wanarp wanarp.sys Sat Nov 20 10:07:45 2010 (4CE79DF1)
91666000 91673000 watchdog watchdog.sys Tue Jul 14 00:24:10 2009 (4A5BC21A)
83821000 83892000 Wdf01000 Wdf01000.sys Tue Jul 14 00:11:36 2009 (4A5BBF28)
83892000 838a0000 WDFLDR WDFLDR.SYS Tue Jul 14 00:11:25 2009 (4A5BBF1D)
917a6000 917ad000 wfplwf wfplwf.sys Tue Jul 14 00:53:51 2009 (4A5BC90F)
98780000 989ce000 win32k win32k.sys Tue Sep 06 03:28:14 2011 (4E65853E)
83800000 83812000 winhv winhv.sys Sat Nov 20 08:38:15 2010 (4CE788F7)
838e8000 838f1000 WMILIB WMILIB.SYS Tue Jul 14 00:11:22 2009 (4A5BBF1A)
893cb000 893e5000 WudfPf WudfPf.sys Sat Nov 20 09:58:55 2010 (4CE79BDF)
Unloaded modules:
a6ac6000 a6b30000 spsys.sys
Checksum: 00000000
ImageSize: 0006A000
893cb000 893d8000 crashdmp.sys
Checksum: 00000000
ImageSize: 0000D000
893d8000 893e3000 dump_ataport
Checksum: 00000000
ImageSize: 0000B000
895f7000 89600000 dump_atapi.s
Checksum: 00000000
ImageSize: 00009000
893e3000 893f4000 dump_dumpfve
Checksum: 00000000
ImageSize: 00011000
Let us know how it goes. If you get further problems with blue screens, attach your new dump files and details and we'll move on from there.
HTH.
