- Thread Author
- #1
I can't connect to the internet anymore. I have a new Dell wireless laptop with a 1397 WLAN Mini-Card. My ISP is virgin media. I have a D-Link DIR 615 Router and a Webstar Modem.
I installed the router a couple of months ago and it was working fine until last week. Then the internet connection dropped and I haven't been able to restore it. I phoned my ISP helpdesk and they had me reset the router and the modem. Nothing seems to work.
I read on here about problems with Apple programs so I have unistalled Itunes, Quicktime and Bonjour.
I have tried calling my ISP 3 times so far and still no solution. They sent a new router (another DLink DIR 615) which I tried to install. I get so far through the process and then it says the default gateway is not available.
When I check the Wireless Network Connection Status it says:
Connection
IPv4 Connectivity No internet access
IPv6 Connectivity No internet access
Media State Enabled
SSID DLink
when I checked the details it gives the following:
Connection-specific DNS Suffix: cable.virginmedia.net
Description: Dell Wireless 1397 WLAN Mini-Card
Physical Address: 78-E4-00-57-AD-D0
DHCP Enabled: Yes
IPv4 Address: 192.168.0.101
IPv4 Subnet Mask: 255.255.255.0
Lease Obtained: 12 September 2010 11:08:07
Lease Expires: 19 September 2010 11:19:09
IPv4 Default Gateway: 192.168.0.1
IPv4 DHCP Server: 192.168.0.1
IPv4 DNS Server: 192.168.0.1
IPv4 WINS Server:
NetBIOS over Tcpip Enabled: Yes
Link-local IPv6 Address: fe80::3d6c:56d0:4d67:6a25%12
IPv6 Default Gateway:
IPv6 DNS Server:
When I run the windows network diagnostics it says the default gateway is not available. Below is the troubleshooter report. I have tried shutting everything down, rebooting the router and modem and then powering everything back up. It still doesn't work.
I have also tried putting the IP address: 192.168.0.1 in my browser but is says "address not valid".
Can anyone help get me back online?
Thanks
Troubleshooter report:
The default gateway is not availableDetected
Link RemovedThe default gateway is a device that connects a local network or computer to the Internet. A broadband modem or router is usually the default gateway.
Reset the "Wireless Network Connection" adapterCompleted
This can sometimes resolve an intermittent problem.
Network Diagnostics Log
File Name: B8C74B42-6082-4E1D-A381-1B74EEFFDA2E.Repair.1.etlInvestigate router or broadband modem issuesNot run
If you're connected to a hotspot or domain network, contact the network administrator. Otherwise: 1. Unplug or turn off the device. 2. After all the lights on the device are off, wait at least 10 seconds. 3. Turn the device on or plug it back into the power outlet. To restart a router or modem that has a built-in battery, press and quickly release the Reset button.
Detection details
Diagnostics Information (Network Adapter)
Details about network adapter diagnosis: Network adapter Wireless Network Connection driver information: Description . . . . . . . . . . : Dell Wireless 1397 WLAN Mini-Card Manufacturer . . . . . . . . . : Broadcom Provider . . . . . . . . . . . : Microsoft Version . . . . . . . . . . . : 4.176.75.21 Inf File Name . . . . . . . . . : C:\Windows\INF\netbc664.inf Inf File Date . . . . . . . . . : 13 July 2009 20:37:27 Section Name . . . . . . . . . : BCM43XG_NT61 Hardware ID . . . . . . . . . . : pci\ven_14e4&dev_4315 Instance Status Flags . . . . . : 0x180200a Device Manager Status Code . . : 0 IfType . . . . . . . . . . . . : 71 Physical Media Type . . . . . . : 9Link Removed
Diagnostics Information (Wireless Connectivity)
Details about wireless connectivity diagnosis: Information for connection being diagnosed Interface GUID: 70ae01f8-064a-47d4-bcea-7a1d25713870 Interface name: Dell Wireless 1397 WLAN Mini-Card Interface type: Native WiFiConnection incident diagnosed Auto Configuration ID: 5 Connection ID: 8Connection status summary Connection started at: 2010-09-12 11:19:08-933 Profile match: Success Pre-Association: Success Association: Success Security and Authentication: SuccessList of visible access point(s): 8 item(s) total, 8 item(s) displayed BSSID BSS Type PHY Signal(dB) Chnl/freq SSID-------------------------------------------------------------------------00-18-4D-96-04-56 Infra g -89 11 NETGEAR00-18-F6-79-0A-49 Infra g -73 1 BTHomeHub-F5F8F0-7D-68-4A-7C-F0 Infra <unknown> -38 6 dlink00-16-0A-0F-BC-8C Infra g -65 6 Simon's house00-24-B2-A0-C0-62 Infra g -87 6 Blyth00-1C-DF-4B-24-E1 Infra <unknown> -85 8 Cecil_Gaybody1C-AF-F7-14-1E-3C Infra <unknown> -85 9 (Unnamed Network)00-19-E0-FF-2E-1A Infra g -88 10 TP-LINKConnection History Information for Auto Configuration ID 5 List of visible networks: 8 item(s) total, 8 item(s) displayed BSS Type PHY Security Signal(RSSI) Compatible SSID ------------------------------------------------------------------------------ Infra g Yes 2 Yes NETGEAR Infra g Yes 34 Yes BTHomeHub-F5F8 Infra <unknown> No 94 Yes dlink Infra g Yes 66 Yes Simon's house Infra g Yes 6 Yes Blyth Infra <unknown> Yes 10 Yes Cecil_Gaybody Infra <unknown> Yes 10 Yes (Unnamed Network) Infra g No 4 Yes TP-LINK List of preferred networks: 3 item(s) Profile: Nadya SSID: Nadya SSID length: 5 Connection mode: Infra Security: Yes Set by group policy: No Connect even if network is not broadcasting: No Connectable: No Reason: 0x00028002 Profile: dlink SSID: dlink SSID length: 5 Connection mode: Infra Security: Yes Set by group policy: No Connect even if network is not broadcasting: No Connectable: Yes Profile: DELL-LAPTOP_Network SSID: DELL-LAPTOP_Network SSID length: 19 Connection mode: Infra Security: Yes Set by group policy: No Connect even if network is not broadcasting: No Connectable: No Reason: 0x00028002 Information for Connection ID 8 Connection started at: 2010-09-12 11:19:08-933 Auto Configuration ID: 5 Profile: Discovery connection SSID: dlink SSID length: 5 Connection mode: Infra Security: No Pre-Association and Association Connectivity settings provided by hardware manufacturer (IHV): No Security settings provided by hardware manufacturer (IHV): No Profile matches network requirements: Success Pre-association status: Success Association status: Success Last AP: f0-7d-68-4a-7c-f0 Security and Authentication Configured security type: Open Configured encryption type: None 802.1X protocol: No Key exchange initiated: Yes Unicast key received: No Multicast key received: No Number of security packets received: 0 Number of security packets sent: 0 Security attempt status: Success Connectivity Packet statistics Ndis Rx: 835 Ndis Tx: 990 Unicast decrypt success: 0 Multicast decrypt success: 0 Unicast decrypt failure: 0 Multicast decrypt failure: 0 Rx success: 1290 Rx failure: 20590 Tx success: 28 Tx failure: 0 Tx retry: 2 Tx multiple retry: 2 Tx max lifetime exceeded: 0 Tx ACK failure: 4 Roaming history: 0 item(s) Information for Connection ID 7 Connection started at: 1601-01-01 01:00:00-000 Auto Configuration ID: 5 Profile: dlink SSID: dlink SSID length: 5 Connection mode: Infra Security: Yes Pre-Association and Association Connectivity settings provided by hardware manufacturer (IHV): No Security settings provided by hardware manufacturer (IHV): No Profile matches network requirements: Fail Pre-association status: Fail 0x00000000 Association status: Fail 0x00000000 Association reason code: 0x00000000 Information for Auto Configuration ID 4 List of visible networks: 4 item(s) total, 4 item(s) displayed BSS Type PHY Security Signal(RSSI) Compatible SSID ------------------------------------------------------------------------------ Infra g Yes 30 Yes BTHomeHub-F5F8 Infra <unknown> No 100 Yes dlink Infra g Yes 30 Yes Simon's house Infra <unknown> Yes 14 Yes Cecil_Gaybody List of preferred networks: 3 item(s) Profile: Nadya SSID: Nadya SSID length: 5 Connection mode: Infra Security: Yes Set by group policy: No Connect even if network is not broadcasting: No Connectable: No Reason: 0x00028002 Profile: dlink SSID: dlink SSID length: 5 Connection mode: Infra Security: Yes Set by group policy: No Connect even if network is not broadcasting: No Connectable: Yes Profile: DELL-LAPTOP_Network SSID: DELL-LAPTOP_Network SSID length: 19 Connection mode: Infra Security: Yes Set by group policy: No Connect even if network is not broadcasting: No Connectable: No Reason: 0x00028002 Information for Connection ID 6 Connection started at: 1601-01-01 01:00:00-000 Auto Configuration ID: 4 Profile: dlink SSID: dlink SSID length: 5 Connection mode: Infra Security: Yes Pre-Association and Association Connectivity settings provided by hardware manufacturer (IHV): No Security settings provided by hardware manufacturer (IHV): No Profile matches network requirements: Fail Pre-association status: Fail 0x00000000 Association status: Fail 0x00000000 Association reason code: 0x00000000 Information for Auto Configuration ID 3 List of visible networks: 10 item(s) total, 10 item(s) displayed BSS Type PHY Security Signal(RSSI) Compatible SSID ------------------------------------------------------------------------------ Infra g No 32 Yes TP-LINK Infra g Yes 32 Yes BTHomeHub-F5F8 Infra g Yes 34 Yes Simon's house Infra <unknown> Yes 8 Yes Cecil_Gaybody Infra g Yes 2 Yes NETGEAR Infra <unknown> Yes 6 Yes (Unnamed Network) Infra g Yes 4 Yes Wireless Gateway Zyxel 1 Infra <unknown> Yes 6 Yes ethereagle Infra g Yes 8 Yes Shaw Infra <unknown> No 92 Yes dlink List of preferred networks: 3 item(s) Profile: Nadya SSID: Nadya SSID length: 5 Connection mode: Infra Security: Yes Set by group policy: No Connect even if network is not broadcasting: No Connectable: No Reason: 0x00028002 Profile: dlink SSID: dlink SSID length: 5 Connection mode: Infra Security: Yes Set by group policy: No Connect even if network is not broadcasting: No Connectable: Yes Profile: DELL-LAPTOP_Network SSID: DELL-LAPTOP_Network SSID length: 19 Connection mode: Infra Security: Yes Set by group policy: No Connect even if network is not broadcasting: No Connectable: No Reason: 0x00028002 Information for Connection ID 5 Connection started at: 1601-01-01 01:00:00-000 Auto Configuration ID: 3 Profile: dlink SSID: dlink SSID length: 5 Connection mode: Infra Security: Yes Pre-Association and Association Connectivity settings provided by hardware manufacturer (IHV): No Security settings provided by hardware manufacturer (IHV): No Profile matches network requirements: Fail Pre-association status: Fail 0x00000000 Association status: Fail 0x00000000 Association reason code: 0x00000000Link Removed
Details about wireless connectivity diagnosis: For complete information about this session see the wireless connectivity information event.Helper Class: Auto Configuration Initialize status: SuccessInformation for connection being diagnosed Interface GUID: 70ae01f8-064a-47d4-bcea-7a1d25713870 Interface name: Dell Wireless 1397 WLAN Mini-Card Interface type: Native WiFiResult of diagnosis: There may be problemLink Removed
Diagnostics Information (Wireless Network Adapter)
Details about wireless network adapter diagnosis: For complete information about this session see the wireless connectivity information event.Helper Class: Native WiFi MSM Initialize status: SuccessInformation for connection being diagnosed Interface GUID: 70ae01f8-064a-47d4-bcea-7a1d25713870 Interface name: Dell Wireless 1397 WLAN Mini-Card Interface type: Native WiFi Profile: Discovery connection SSID: dlink SSID length: 5 Connection mode: Infra Security: No Connect even if network is not broadcasting: NoResult of diagnosis: There may be problem
Connection
Media State Enabled
SSID DLink
DHCP Enabled: Yes
IPv4 WINS Server:
IPv6 DNS Server:
Thanks
Detection details
