Windows 7 Deleting Build-Info
Strinsgebab
Banned
Hey guys,
i don´t like always looking at the build-info in the right corner on the desktop... is there a way to delete it or to switch it of?
If it really bugs you that much then go here and good luck! This was for Vista, but should work the same for Win-7
Link Removed - Not Found
