Is it possible to delete the system partition (held Windows XP - no longer needed)?
I have Windows 7 on the second partition, and don't really want to do a reinstall. It's partition is set as "C:" when Win7 is booted.
Any way to make the second partition the system partition, then delete the first?
If I can't get rid of the first partition, I would like to minimize it's size by deleting all unneeded files then shrinking the partition. What files are needed on the partition?
Thanks!
Thanks!
