Diagnostic Tool problem
Hey,
I'm trying to follow the orders to post my problem here, but facing some problems.
I downloaded the SF Diagnostic Tool and ran it.
System Information and MSINFO 32 were good but each of the other options result an error.
For each it says: "Can not find file: "c:\DriverList.txt" for Driver List and the matching text file name for the other options.
Even when I choose "continue" nothing comes up.
I'm done with the DMP files and the CPU-Z screenshots. Just need to complete this to finish it all and be ready to post.
Any idea?
Thanks,
Trouble
Noob Whisperer
Hello and welcome to the forum.
When running the SF Diagnostic Tool you need to right click the executable and choose "Run As Administrator"
Regards
Randy
Regards
Randy
I'm logged in as Admin.
And... for some reason when I right click files I don't have "Run as Administrator".
Trouble
Noob Whisperer
Try to right click the executable and choose properties.
Then select the Compatibility Tab and check the box at the bottom that says "Run As Administrator"
See if that works for you
I have only one tab there called "General".
I have the same problem.
