golden4207
- Joined
- Mar 23, 2014
- Messages
- 6
- Thread Author
- #1
I see that there is 4 options:
1) System restore (I know what that is, won't help me)
2) There is refresh (I also know what this is, won't help)
3) Then there is RESET, which gives me 2 options: 1 of the options (none of this is verbatim, I am outside on my phone and forgot exact words as to describing the two different reset options) is to do a standard reset (as if I'm not selling the computer but still will restore to factory defaults etc), the 2nd is to do a full reset (as if I was wanting to sell the computer to somebody else to make sure my files are not on it, completely resetting my computer back to be as if I had just purchased it).
4) Then there is system recovery. Basically saying that it will do the same thing as a full reset, the second option reset, but with the option to save my files.
Now my question is, both the full reset and the recovery, APPEAR, as far as I can see, (besides the recovery saving files, which I already removed all files so don't care about) to do the same thing.... Which option out of the two, will completely restore my computer to the furthest extent that it can be restored to?
I hope that made sense,
thank you
Sent from my SM-N900T using WindowsForum mobile app
thank you
