david b
I allowed some automatic updates onto my computer last weekend. Internet worked fine for a few days and then nothing with the error DNS server not responding. I had a more computer literate friend look at it and he said that everything looked like it was working fine other than this error....my computer says all this junk: (makes not much sense to me) I would really really appreciate any help. :) I should also say its a laptop im using and its a LAN connection not wireless
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : telenet.be
Link-local IPv6 Address . . . . . : fe80::f495:b2f2:de6a:d4f8%10
IPv4 Address. . . . . . . . . . . : 78.22.124.232
Subnet Mask . . . . . . . . . . . : 255.255.240.0
Default Gateway . . . . . . . . . : 78.22.112.1
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Tunnel adapter Local Area Connection* 2:
Tunnel adapter Reusable ISATAP Interface {C73853E0-5F94-408C-ACBD-CD732DF99891}:
Tunnel adapter isatap.{EA7C7F02-CD4E-4F92-9B36-5ACE1E336F07}:
Tunnel adapter Reusable ISATAP Interface {802E7D97-529C-439A-A458-E3A806F8C2CD}:
Tunnel adapter Local Area Connection* 25:
Tunnel adapter isatap.telenet.be:
Tunnel adapter 6TO4 Adapter:
IPv6 Address. . . . . . . . . . . : 2002:4e16:7ce8::4e16:7ce8
You still didn't get what is needed, none of these are a connection, if you look at your first post the first few line give information about the connection it is just missing the part we need to see to see the DNS.
You need to do a 'ipconfig /all' to provide all the info needed to help you. You only did an 'ipconfig'.
alright, thanks. Hopefully its all here now! :)
Autoconfiguration Enabled . . . . : Yes
Tunnel adapter Local Area Connection* 85:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #62
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 91:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #67
Tunnel adapter Local Area Connection* 87:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #64
Tunnel adapter Local Area Connection* 93:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #68
Tunnel adapter Local Area Connection* 90:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #66
Tunnel adapter Local Area Connection* 97:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #72
Tunnel adapter Local Area Connection* 104:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #78
Tunnel adapter Local Area Connection* 94:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #69
Tunnel adapter Local Area Connection* 95:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #70
Tunnel adapter Local Area Connection* 96:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #71
Tunnel adapter Local Area Connection* 98:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #73
Tunnel adapter Local Area Connection* 100:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #74
Tunnel adapter Local Area Connection* 106:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #79
Tunnel adapter Local Area Connection* 103:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #77
Tunnel adapter Local Area Connection* 115:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #87
Tunnel adapter Local Area Connection* 107:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #80
Tunnel adapter Local Area Connection* 110:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #82
Tunnel adapter Local Area Connection* 111:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #83
Tunnel adapter Local Area Connection* 118:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #89
Tunnel adapter Local Area Connection* 114:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #86
Tunnel adapter Local Area Connection* 116:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #88
Tunnel adapter Local Area Connection* 119:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #90
Tunnel adapter Local Area Connection* 120:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #91
Tunnel adapter Local Area Connection* 124:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #95
Tunnel adapter isatap.coova.org:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #6
Tunnel adapter Local Area Connection* 121:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #92
Tunnel adapter Local Area Connection* 122:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #93
Tunnel adapter Local Area Connection* 123:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #94
Tunnel adapter Local Area Connection* 125:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #96
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #7
Tunnel adapter Local Area Connection* 132:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #99
Tunnel adapter Local Area Connection* 133:
Description . . . . . . . . . . . : Microsoft 6to4 Adapter #100
Tunnel adapter Local Area Connection* 134:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
C:\Users\David>
ahh crap! I just realised. that will be the wrong ipconfig info as im in work now where my internet is working fine. typical start to a monday morning. I'll post the proper one later
ok so this time i think it should be the right info. I really appreciate any help as its become a real problem now
Autoconfiguration Enabled . . . . : Yes Autoconfiguration Enabled . . . . : Yes
