Windows 10 Ethernet and Wireless keep disconnecting - Windows 10 Pro 21H1
Cache
CA
Cache1978
Created on September 28, 2021
Ethernet and Wireless keep disconnecting​
I have a problem where my ethernet intermittently keeps dropping. Occasionally it happens on WiFi as well and I've also seen it happen on a USB-to-Ethernet adapter.
I have a large network with many other devices connected physically and wirelessly but no other device is affected. For this reason I believe it is an issue with my Laptop. Furthermore, I believe it might be an OS or driver issue rather than a hardware fault because it's not limited to the Ethernet adapter.
The issue is that the Ethernet connection will occasionally drop saying it's connected but with "No internet", however there is also no local network access. When I switch to WiFi most times it will work but sometimes the same issue occurs either immediately or after a little bit of use. A reboot is the only way I can get it to work again and then it only works for a maximum of an hour before it happens again (most often within 30 minutes).
Sometimes it picks up a weird IP address indicating the DHCP server isn't work but it's working fine, other times all the settings are fine correct but still won't work. I tried specifying a static IP and DNS when it occurs but it just locks up when trying.
Things I have tried:
Turned off windows firewall - Not resolved it
Turned off Windows defender - Not resolved it
Ensured will windows updates and drivers are up to date - Not resolved it
Formatted Windows and completely re-installed - Not resolved it
Tried a different network switch - Not resolved it
Tried a different network directly connected to a different router (different network entirely) - Not resolved it
Tried different ethernet cable - Not resolved it
Turned off fast shutdown - Not resolved it
Turned off "Windows can shut this down to save energy" on the network adapters - Not resolved it
Complete network reset - Not resolved it
Virus scan and malware scan - Not resolved it
Tried static IP - Not resolved it
Disabling network adapter and re-enabling but it won't re-enable - Not resolved it
Removed all intel drivers and killer software and let windows chose the drivers it believes is best - Not resolved it
A few things I found in the logs which might be related but i'm not sure:
Microsoft-Windows-Host-Network-Service-Admin
'IpICSHlpStopSharing' : '0x80070032'.
A provider, IntelMEProv, has been registered in the Windows Management Instrumentation namespace root\Intel_ME to use the LocalSystem account. This account is privileged and the provider may cause a security violation if it does not correctly impersonate user requests.
I'm completely out of ideas and have been working on this for 2 weeks now. Any help would be massively appreciated.
Thanks.
Top Bottom
