Sucratzz
- Joined
- Oct 1, 2013
- Messages
- 1
- Thread Author
- #1
Hi there,
I have had a couple of driver_power_state_failure's on my surface pro these last two days.
The first time I noticed it happen was with low battery, my wifi stopped working so I went to restart and it was stuck on restarting... for a long time, then the bsod. (first dump Link Removed)
When I tried to restart it said I had 100% battery but turned off almost immediately.
I plugged the power in and booted up. It still said 100% battery with the power plug plugged in. A couple more restarts and plugging the power in and out and it eventually started reporting correct battery level.
The next day whilst plugged in, my wifi stopped working again. I performed a restart and the same thing happened, a long time stuck on resetting... then the bsod again. (second dump Link Removed).
After restarting from this I have been having problems with the wifi being connected to the router, but having limited access unless I disconnect and reconnect to it.
Can anyone please help?
