alphaamanitin
[SOLVED] DVD+/-R/CD+/-R will not read or write
Hey guys,
So I built a Windows machine recently (~8 months ago). It has Windows 7 32 bit Professional Installed on it. Twice now I have had the DVD device die. The first time it was a Sony, no a Lite-On iHAS242. The first time I thought oh well, dead DVD drive and bought another one, but now it has died. Both died after about 4 months.
Here are the details of the problem. It was running fine, watching DVDs, turned it off and the next time I went to play a DVD it was dead, this was about two days later. It is still in My Computer, the drive will recognize media. If I put a DVD in it will display the title of the DVD and how much memory of the DVD is free, it will even open DVD and CD to display what is inside. However, if I try to play a DVD or use whatever is on the DVD or CD the program attempting to run the DVD/CD content freezes. If it is a Microsoft program the whole computer freezes.
Thins I did to try to fix it.
First thing I did was uninstall the device in device manager and rebooted. Didn't work. Physically disconnected the DVD/CD-RW and waited a few minutes. Plugged it back in, same problem. Deleted all the registry values associated with the DVD/CD-RW drive, uninstalled the drive rebooted, same issue. Replaced the drive with my old Sony, that I had the same issue on 4 months previous, same issue.
I tried the Fix It program available from Microsoft, but that would not run. Said that my certificates were not okay and would not run. Gave up on trying to solve that issue and the instructions I found did not make sense to me. Here is a link to the steps I tried to use as I had the same issue of the original poster:
Problems installing fixit - invalid certificate
Should also mention that the first time I replaced the drive I replaced the SATA cable as well, so it should not be a faulty cable. Tonight Iwill try booting a live Ubuntu and see if Ubuntu has the same issues.
Thanks,
AlphaA
Hey guys,
Thanks,
AlphaA
