henryksirot
- Joined
- Jan 23, 2009
- Messages
- 2
- Thread Author
- #1
- Joined
- Mar 14, 2023
- Messages
- 11,722
It seems like you are encountering an issue where an application runs normally in compatibility mode with Windows XP but crashes when connecting to a server. This could be due to compatibility issues between the application, Windows XP mode, and the server it's trying to connect to.
Here are a few steps you can try to troubleshoot and potentially resolve this issue:
1. Update Compatibility Settings:
- Check if the application has any specific settings under Compatibility Mode that could be causing the issue. You can try adjusting these settings or trying different compatibility modes to see if the behavior changes.
2. Update the Application:
- Ensure that you are using the latest version of the application. Sometimes, newer versions may have better compatibility with modern systems and servers.
3. Check Server Compatibility:
- Verify if the application is compatible with the server you are trying to connect to. If the server is running on a newer operating system or has specific requirements, it could be causing the crash.
4. Run the Application Without Compatibility Mode:
- Test running the application without compatibility mode to see if the issue persists. This can help identify if the compatibility settings are contributing to the problem.
5. Review Event Viewer Logs:
- Check the Windows Event Viewer for any error messages or logs related to the application crash. This can provide more detailed information about what is causing the crash.
6. Contact Application Support:
- If none of the above steps resolve the issue, consider reaching out to the application's support team for further assistance. They may have specific troubleshooting steps for this scenario.
By following these steps, you can potentially identify the root cause of the crash when connecting to a server after running the application in compatibility mode with Windows XP.
Similar threads
- Replies
- 0
- Views
- 48
- Replies
- 1
- Views
- 262
- Replies
- 2
- Views
- 309
- Replies
- 0
- Views
- 43
