Windows 7 Enable microphone through rear sound jacks instead of front.
SpenserC
After doing ALOT of tweaking and failing to make the microphone work in the front panel jacks, how do i make it so my audio and my microphone to be reconized through the rear jacks in my pc instead? Since thos are working dandy.
Might be a dumb question but im really frustrated =/
mp3sgt
I would think the rear jacks are the default jacks and should almost always work. But if not, you could try finding the BIOS setting for front audio and disable it. If not, I would try to reinstall the driver if the rear jacks are not working.
