jpHam15
I'm running Windows 10 and this morning I started having trouble opening wav and or mp3 files using Media player. A window pops up with the message for error 0xC00D36B4. I've tried opening multiple files with the same issue. All of these files were ok yesterday. Not sure where to start with this issue.
The error code 0xC00D36B4 in Windows Media Player typically points to file compatibility, codec issues, or problems within the Media Player's library. Here are some troubleshooting steps to help resolve this issue:
1. Check File Compatibility
Ensure the file you are trying to play (MP3 or WAV) is supported by Windows Media Player. While these file types are widely compatible, problems can occur if:
  • The files are corrupt.
  • An unsupported encoding mechanism was used when creating the files.
You can verify this by trying to play the same files in another player like VLC Media Player (which supports more formats by default).
2. Update or Install Codecs
The...
The problem could be linked to missing or outdated codecs. Codecs enable your system to decode different audio/video formats. To resolve:
  • Download and install a reliable codec pack such as the K-Lite Codec Pack.
  • Avoid lesser-known sources to prevent malware or poorly written software from causing additional issues.
3. Clear and Rebuild the Media Player Library
Corruption in the Media Player's library can disrupt playback.
  • Close Windows Media Player.
  • Press Win + R, type %LOCALAPPDATA%\Microsoft\Media Player, and press Enter.
  • Delete all .wmdb files within the folder. These are your Media Player database files.
  • Restart Windows Media Player. It will rebuild the library automatically.
4. Update Windows and Device Drivers
Outdated software or drivers could also lead to playback issues.
  • To update Windows:
  • Go to Settings > Update & Security > Windows Update.
  • Click Check for updates to ensure your system is current.
  • To update audio drivers:
  • Open Device Manager (Win + X > Device Manager).
  • Expand the "Sound, video and game controllers" section.
  • Right-click your audio device and select Update driver.
Alternatively, visit your audio device manufacturer’s website for the latest drivers.
5. Restore Media Player or Use Alternatives
If none of the above steps work and the issue persists, consider resetting or using an alternative media player:
  • Reset Windows Media Player:
  • Open Control Panel > Programs > Turn Windows features on or off.
  • Locate Media Features and uncheck Windows Media Player.
  • Restart the PC, go back to the same menu, and re-enable it.
  • Try VLC or other media players, as they have broader support for file formats.
6. Run a System File Check
If you suspect system file corruption:
  • Open Command Prompt as an administrator.
  • Run the sfc /scannow command. This checks and repairs corrupted system files.
7. Verify the Integrity of Your Files
Even if your files played fine before, they could now be corrupted.
  • Test the files on another machine, or re-download them if possible.
Start with these steps and let me know how it goes! If the issue persists, providing more details (e.g., any recent system updates or changes) could help narrow down other causes.
Try this:
Restart your PC
Test the file in VLC Player
Update or reinstall your audio driver (via Device Manager)
Check your playback device settings (set the right one as default)
Reinstall Windows Media Player (via Windows Features)
If it works in VLC, the problem is with Media Player.
To resolve the error code 0xC00D36B4 in Windows Media Player when trying to play WAV or MP3 files, consider the following steps:
1. Restart Your PC
  • This resolves temporary glitches in both hardware and software.
2. Test in VLC Media Player
  • If the file plays in VLC Media Player, it's possible that codecs or settings in Windows Media Player (WMP) are causing issues.
3. Update or Reinstall Audio Drivers
Steps to Update Audio Drivers:
  • Open Device Manager with Win + X.
  • Expand Sound, Video, and Game Controllers.
  • Right-click your audio device and select Update Driver.
  • Alternatively, visit the manufacturer's website to download the latest drivers.
4. Check Playback Device Settings
  • Set Correct Playback Device as Default:
    • Right-click the Volume icon in the system tray and select Sounds.
    • Go to the Playback tab, right-click your output device, and choose Set as Default Device.
  • Disable Enhancements:
    • In the Playback tab, select the active device, click Properties, and under the Enhancements tab, select Disable all enhancements.
5. Reinstall Windows Media Player
  1. Navigate to the Control Panel.
  2. Go to Programs > Turn Windows Features On or Off.
  3. Expand Media Features, uncheck Windows Media Player, and restart your PC.
  4. Re-enable it using the same steps and restart again.
Additional Insights:​
If the file plays in VLC but not in WMP, consider replacing WMP with VLC for broader codec support or troubleshooting the WMP library by clearing database files and restarting the program. Let me know if further clarification is needed!
