First off, Hi
I'm new here.
My Problem:
Yesterday my PC was working fine when I was using it for one of my classes. I shut it off when it was time to go and when I started it back up a few hours later. As soon as it got past the boot logo it went to BlueScreen and shut back off. Up until that point my PC had been running absolutely perfect so I'm not sure where the blue screen came form. My PC is maybe 6 months old and I take good care of it.
Since then (pretty sure it started after I got the blue screen), my explorer has been randomly freezing. It doesn't give me the "Explorer is not Respinding" pop up or anything like that. It just freezes and I cannot click on anything in the taskbar, min/max any of the windows or anything at all. I can mouse over it but nothing happens when clicking. I can still use whatever program I am in usually. The way I get it to unfreeze is CTRL+ATL+Delete and start the task manager and that seems to fix the problem.
The only thing new I did with my PC was install Adobe InDesign CS6 while I was sitting in class. I don't think that is what cause it but it was fine up until that point so I'm not sure. I've restored my PC to an earlier point that was created before I installed InDesign and it is still doing it.
Any ideas or suggestions?
I already backed everything up and am planning to do a fresh install of Windows. But I wanted to check and see if there was an easier solution before I went that far.
System Specs:
Windows 7 64 bit
Intel Core i5
Nvidia GeForce GT 630M
8 gigs of DDR3 RAM
My Problem:
System Specs:
Windows 7 64 bit
Intel Core i5
8 gigs of DDR3 RAM
