Windows 8 F1 2011 can't be installed - Please PLEASE help me :(
tjalfed
I just got my new computer (Lenovo Z500 Ideapad nordic edition)
It runs Windows 8.
I just bought F1 with the computer in a disc. But for some reason when i install it it just says "Please wait while Windows configures f1 2011. The green bar stops at 1/5 and i tried to install it several times. I tried the Wizard installer but diddent help.
What can i do??
Waxinator
Try Right-click the Setup file and "Run as Administrator".
Observe any hidden pop-up message.
siamon
If you want to overwrite the existing system with a fresh install that is no problem. Run the install and format the drive before installing - serials are not "embedded". Before overwriting the existing system you should consider running the built in utility to create a set of recovery disks should you later wish to revert to the oem installation.
