Fix Double Click?
iamsrk48
How to fix Single Clicking Option when Double Clicking Option Enabled?
Sent from my LG-M700 using Tapatalk
Follow these steps to fix the Single-click option:
Step 1: Access File Explorer Options.
Tip: File Explorer Options are also referred to as Folder Options.
Step 2: Select the clicking option.
In the General settings, under Click items as follows, choose Single-click to open an item (point to select) or Double-click to open an item (single-click to select), and then tap OK.
RuskinF
Member
