Formatted Computer, Now Stereo Mix Won't Work
Earlier, I formatted my PC and reinstalled Win7. Now Stereo Mix wont work. I've reinstalled the drivers (not sure if correct ones) and I've also checked off "show disconnected" or "show disabled".
Please help. I need to record computer sound with camtasia studios to finish my Minecraft Lets Play :3
Saltgrass
So after you checked Show Disabled Devices, you did not see the Stereo Mix icon in the Recording Devices dialog box? If you do, did you enable it?
If you do not see it, you may need to load a legacy driver for your system.
No, it didnt appear at all.
And what exactly is a legacy driver?
Saltgrass
What sound card or motherboard do you have so I can check for a driver.
Idk the sound card, under device manager it just lists ATI HDMI Audio and High Definition Audio Device. Im not sure what kind of motherboard.
kaos
ok somethin i do when i repair peoples pcs or install windows for them
windows update, optional updates, you should see a list of drivers, click the required drivers, install them and reboot
hopefully it should sort it
#7
After formatting, i immediately got all my drivers. but ill try
