Windows 8 FRAPS Compatibility Situation
Mike
Windows Forum Admin
Delivered-To: [email protected]
Received: by 10.68.241.201 with SMTP id wk9csp357540pbc;
Sun, 11 Nov 2012 20:37:17 -0800 (PST)
Received: by 10.50.159.198 with SMTP id xe6mr6925406igb.46.1352695037297;
Return-Path: <[email protected]>
Received: from relay02.pair.com (relay02.pair.com. [209.68.5.16])
by mx.google.com with SMTP id kg10si5311803igc.38.2012.11.11.20.37.16;
Received-SPF: pass (google.com: domain of [email protected] designates 209.68.5.16 as permitted sender) client-ip=209.68.5.16;
Authentication-Results: mx.google.com; spf=pass (google.com: domain of [email protected] designates 209.68.5.16 as permitted sender) [email protected]
Message-Id: <[email protected]>
Received: (qmail 45265 invoked from network); 12 Nov 2012 04:37:15 -0000
Received: from 150.101.162.129 (HELO dev) (150.101.162.129)
by relay02.pair.com with SMTP; 12 Nov 2012 04:37:15 -0000
X-pair-Authenticated: 150.101.162.129
Content-Type: text/plain; charset="UTF-8"
MIME-Version: 1.0
Date: Mon, 12 Nov 2012 15:37:03 +1100
Subject: Re: (Case BPL127665) Fraps message: Mike Fara
X-Bcc:
Dear Mike,
Thanks for your inquiry. Unfortunately as you have mentioned the current version of Fraps does not work with Windows 8. However, our developers are currently working on the next version of Fraps which will include official support for Windows 8 as well as other minor bug fixes and improvements.
Regards,
Chris Van Graas
The email you received pertains to compatibility issues with Fraps on Windows 8. Here are the key points from the email:
  • Sender: Beepa Support email]>
  • Recipient: [email protected]
  • Date: Mon, 12 Nov 2012 15:37:03 +1100
  • Subject: Re: (Case BPL127665) Fraps message: Mike Fara
Summary of the Email:
  • Issue: The current version of Fraps is not compatible with Windows 8.
  • Resolution: Developers are working on the next version of Fraps, which will include official support for Windows 8, along with other minor bug fixes and improvements.
If you are encountering issues with Fraps on Windows 8, you may need to wait for the upcoming version with Windows 8 support and other enhancements mentioned in the email.
