SKJoy2001
Operating system: Microsoft Windows 7 Ultimate Edition x64 Bit Beta Build 7000 on Compaq Preserio CQ45.
User: Administrator with UAC to the minimum level.
Hardware: GongTong EDGE Modem into the T-Express card slot.
Trouble: Driver installation says the driver is not digitally signed and this version of Windows requires hardware drivers to be digitally signed for installation. The device driver installs but the device is reported to be NOT FUNCTIONAL in the Device Manager screen.
History: I have successfully used this piece of hardware on my previous Microsoft Windows XP Professional x64 Bit without any trouble as well as Microsoft Windows VISTA Ultimate Edition.
Product website: Link Removed due to 404 Error
It seems like you are facing issues with installing a driver for the GongTong EDGE Modem on Windows 7 Ultimate Beta Build 7000, which requires digitally signed drivers for installation. Given that Windows 7 sometimes enforces driver signing to ensure system stability and security, here are a few methods you can try to resolve this issue:
Method 1: Disable Driver Signature Enforcement (Temporary Solution)​
  1. Restart Your Computer: Restart the computer.
  2. Boot Advanced Startup Options: When the system restarts, press F8 before the Windows logo appears to access the Advanced Boot Options menu.
  3. Disable Driver Signature Enforcement: From the menu, select "Disable Driver Signature Enforcement."...
  4. Install the Driver: Try to install the driver again.
    Method 2: Use an Advanced Boot Option (Similar to Method 1)​
  5. Restart Your Computer.
  6. Press F8: As your computer restarts, press F8 repeatedly before the Windows logo appears to access the Advanced Boot Options menu.
  7. Choose "Disable Digital Driver Signature Enforcement": This option temporarily disables driver signature enforcement for the current boot.
    Method 3: Sign the Driver Yourself (Advanced)​
  8. Obtain a Code Signing Certificate: Purchase a code signing certificate from a trusted certificate authority.
  9. Sign the Driver Yourself: Use tools like signtool.exe in the Windows SDK to digitally sign the driver file.
  10. Install the Driver: After signing the driver, try installing it again.
    Method 4: Update Windows​
    Ensure your Windows 7 system is up to date with the latest patches and updates. Sometimes, newer updates include fixes or changes related to driver signing.
    Method 5: Contact the Manufacturer​
    Reach out to GongTong's support team to inquire about digitally signed drivers compatible with Windows 7. They might have an updated driver that meets Windows 7's driver signing requirements. By following these methods, you should be able to install the driver for the GongTong EDGE Modem on your Windows 7 Ultimate system successfully. Good luck, and let me know if you encounter any issues during the process!
