Windows 8 Graphics upgrade for slim tower
Hmm... Well a quick look around found this:
GeForce GTX 750 Ti
http://www.geforce.co.uk/hardware/desktop-gpus/geforce-gtx-750-ti/specifications
It also only requires a 300W PSU. The GTX650 needs a 400W so you would have been right on the limit with the new card and PSU. This at least gives you a little breathing room whilst it also being faster and less power hungry.
Here's a link (plus EVGA is a great brand usually with lots of freebies):
http://www.newegg.com/Product/Produ...87024&cm_re=GTX_750_TI-_-14-487-024-_-Product :
Hi Babi,
sorry your post was missed. Do you still need some advice?
Your options look like they'll do the job did the originals fail or?
babi
Honorable Member
Thanks for your response.The originals are working fine.It's just that I am looking for a powerful power supply to go in accordance with the graphics card.I want to future proof my system.Please share your valuable opinion regarding the most suitable graphics card within $150 for slim tower.
GeForce GTX 750 Ti
babi
Honorable Member
GeForce GTX 750 Ti
Thanks a lot.One thing I want to know if this will be okay with the confines of the slim tower .
The card does have a fan and as long as the case is reasonably well ventilated then you should be fine. Do you have any internal case fans as such?
babi
Honorable Member
The cabinet uses the stock dell fan(single no).
You'll probably be fine then. The PSU of course has a fan which has been shown via tests to remove a surprising amount of heat from the case.
