GRUB2 CVE-2025-61661: Bootloader DoS via USB Strings
USB drive above a circuit board shows a GRUB2 prompt and CVE-2025-61661 warning.
A new GRUB2 vulnerability, tracked as CVE-2025-61661, permits an out‑of‑bounds write during USB string handling that can crash the bootloader when a maliciously‑crafted USB device is present during boot, producing a denial‑of‑service and a limited risk of data corruption; the defect is narrow, has a medium CVSS rating, and has already received a targeted upstream patch—administrators must inventory affected boot artifacts, apply vendor updates, and adopt short‑term device controls while vendors roll fixes into distribution packages.
Background / Overview​
GRUB (Grand Unified Bootloader) sits at the earliest stage of the platform boot chain; any code that runs there operates with highly privileged access to disk and memory and executes before the OS loads normal protection boundaries. The newly published CVE‑2025‑61661 concerns GRUB2’s handling of USB descriptor strings: the code used the wrong length field when allocating a buffer to hold a converted string, creating a mismatch between allocated memory and the amount of data written during conversion. That mismatch can produce an out‑of‑bounds write, which typically manifests as a crash (Denial‑of‑Service) during boot and, in some circumstances, might corrupt bootloader state or on‑disk structures. Two independent vulnerability indexers (NVD and Amazon’s ALAS tracker) list the defect and characterize it as a local/physical attack vector that requires presenting a malicious USB device to the target while it boots; both list a medium severity and an initial CVSS v3.1 base around 4.8. Red Hat’s trackers and community CVE aggregators contain equivalent descriptions and tie the report to an upstream mailing‑list patch.
Technical anatomy: what went wrong​
Root cause (in plain language)​
At its core the bug is a classic incorrect length field issue. GRUB’s USB string‑reading routine reads descriptor data from a device in multiple steps: the initial read yields a length field used for allocation, and a subsequent read yields the actual content and a length reported in a different structure. In the vulnerable code path the allocation used one structure’s length while the conversion routine used another, inconsistent length—so conversion could write past the allocated buffer when the second length exceeded the first. The incorrect field choice therefore creates a write that can land past the buffer boundary (an out‑of‑bounds write), producing memory corruption and an oops/crash in the bootloader.
The upstream fix​
The upstream patch is surgical and minimal: the allocation now uses the correct length field (the second/readback length) rather than the initially read length, ensuring the buffer is sized to fit the converted data. The authoritative patch submission that closed the issue (posted to the grub-devel / oss‑security lists) shows a one‑line replacement in grub-core/commands/usbtest.c that swaps descstr.length for descstrp->length in the allocation call. This is the canonical defensive correction for this kind of parsing bug.
Why the fix is low‑risk​
Because the remediation changes only which length field is used at the allocation point, it does not alter on‑disk formats, runtime APIs, or behavior for correctly‑behaving devices. Small, localized fixes like this are often accepted into stable vendor trees and backported quickly, reducing regression risk and making them practical for distribution maintainers.
Impact and exploitability​
Attack surface and preconditions​
  • Attack vector: physical / local — the attacker must present a USB device (or cause a host to enumerate a malicious USB device, including via USB passthrough in virtualized environments) during the boot sequence.
  • Privileges required: none beyond the attacker’s ability to physically attach or emulate the device; exploitation does not require pre‑existing OS code execution.
  • Complexity: moderate to high — crafting a device descriptor sequence that reliably triggers an out‑of‑bounds write during the narrow usbtest code path and does so during boot requires attention to timing and the GRUB environment. Several trackers mark attack complexity as non‑trivial.
Expected outcomes​
  • Primary impact: Denial of Service (bootloader crash) — a successful trigger will typically crash GRUB and prevent the system from booting until manual intervention, producing a total availability loss for that machine.
  • Secondary impact: possible data/boot corruption — while the most obvious effect is a crash, out‑of‑bounds writes can, in theory, corrupt GRUB’s in‑memory structures or disk‑side state (e.g., GRUB environment block). Public records and vendor summaries treat data corruption as plausible but less likely than DoS due to exploitation complexity.
CVSS and exploitation probability​
Major aggregators list a CVSS v3.1 base score of 4.8 (Medium) with a vector emphasizing physical/local attack vector and limited confidentiality/integrity impact. Early EPSS/telemetry shows a very low probability of in‑the‑wild exploitation, reflecting the need for physical presence or device attachment and the absence (to date) of reliable public proof‑of‑concept code. That said, the operational cost of a non‑bootable fleet device makes this a high‑priority patch for high‑availability environments.
Who and what is affected​
Affected components​
The vulnerability lives in GRUB2’s USB command/test code and therefore affects environments that:
  • use GRUB2 (the vast majority of Linux distributions and many embedded devices), and
  • allow USB device enumeration during boot (most desktops and many servers with enabled USB controllers, and virtual machines with USB passthrough).
Distribution and vendor status​
At disclosure multiple vendor trackers (Debian, Red Hat, Amazon Linux) and security feeds imported the CVE and noted that upstream patches exist and are being tracked for packaging. Several distributions showed “pending fix” status for grub2 packages, which is typical: maintainers must apply the upstream patch, build packages, run quality testing, and then publish a release. Expect staggered vendor timelines; appliance/OEM kernels and UEFI/firmware bundles are the long tail that often lags.
High‑risk deployments​
  • Unmanaged workstations, lab machines, or kiosks that accept arbitrary USB devices.
  • Public‑facing terminals, shared workstations, and systems that allow user‑attached devices during boot.
  • Virtualization hosts or guests that permit USB passthrough; a malicious tenant or host could present crafted descriptors.
  • Embedded appliances or vendor images with customized GRUB builds that may not receive prompt backports.
Detection and indicators​
This class of bootloader bug does not leave a network signature and is best detected with direct observation and device controls.
  • Symptom: immediate GRUB crash during device enumeration or boot; machine fails to progress into OS boot.
  • Forensic capture: enable serial console logging and capture early boot output; GRUB oopses or error messages may appear on serial/console and are the primary artifact for diagnosis.
  • In virtualized environments: correlate VM boot failures with USB passthrough attach events and hypervisor logs.
  • No reliable remote detection: because the exploit requires local device presentation during boot, network monitoring will not generally expose attempted exploitation.
For general context on similar USB and kernel device parsing faults (their detection and mitigation patterns), see the operational playbooks used for prior USB‑triggered kernel crashes—these emphasize logging, blocking untrusted devices, and centralizing boot/console output for triage.
Remediation and mitigation​
Definitive remediation (apply vendor patches)​
  1. Identify systems that ship the vulnerable GRUB2 package and map to vendor advisories (Debian, Red Hat, Ubuntu, Amazon Linux). Use your distribution’s security tracker to find the patched package names and versions.
  2. Apply the vendor’s grub2 package update through standard channels (apt, yum/dnf, zypper, or vendor image updates).
  3. Reboot into the patched environment. Because GRUB runs at boot, a reboot is required to complete remediation.
Note: test patches in a pilot ring where possible; although the upstream fix is small, GRUB updates touch the boot path and merit caution on production fleets.
Short‑term compensations and hardening (if immediate patching is impossible)​
  • Disable USB ports where feasible (BIOS/UEFI settings or physical port blockers) on critical systems.
  • Restrict boot device selection and require administrative presence for boot‑time device changes.
  • Disable USB passthrough on hypervisors and block guest ability to attach arbitrary host USB devices.
  • Enforce strict device allowlists via udev rules or endpoint device control tools on systems that must accept USB devices.
  • For environments that consume untrusted images, perform image import and examination in isolated sandboxes rather than on production hosts.
Operational checklist (condensed)​
  1. Inventory: list hosts with GRUB2—include physical machines and VM templates.
  2. Query package status: check installed grub2 package versions against vendor advisory mappings.
  3. Patch: schedule and apply vendor packages; validate in pilot environment.
  4. Reboot: coordinate reboots during maintenance windows.
  5. Verify: confirm GRUB stage and version on reboot and run basic boot tests.
  6. Harden: apply short‑term device controls until full patch coverage is achieved.
Risk analysis: strengths, caveats, and the long tail​
Strengths and positives​
  • The upstream fix is minimal and surgical—changing which length field gets used—so it is easy to audit and backport, and maintainers can safely recommend vendor backports.
  • The attack vector requires device presentation during boot (physical or emulated), which reduces the remote‑network risk surface compared with kernel network services.
Caveats and residual risks​
  • The practical cost of boot failures is high for fleets of servers or appliances; even if exploitation is non‑trivial, the operational risk for devices in public or shared environments is meaningful.
  • OEM and embedded device images that include custom GRUB builds may not receive timely fixes; these devices are the classic long tail for bootloader bugs. Operators must contact vendors and track firmware/kernel backports.
  • A determined attacker with physical access can cause wide disruption without needing a flawless exploit that yields code execution—simple DoS is sufficient in many malicious scenarios.
Public exploitation status​
As of the initial disclosures, there is no robust public proof‑of‑concept weaponization reported, EPSS is very low, and major feeds show no KEV/CISA‑flagged exploitation. That reduces immediate panic, but defenders must not conflate low exploitation telemetry with low priority for patching—this bug affects the boot phase and can produce high availability costs.
Practical guidance for administrators (step‑by‑step)​
  1. Quickly triage scope:
    • Run a package query to find grub2 installations across inventory. (Examples: apt list --installed | grep grub2; rpm -qa | grep grub2.
  2. Check vendor advisories:
    • Use Debian/Ubuntu/Red Hat/ALAS advisories and your distro’s security tracker to map CVE→package→fixed version.
  3. Prioritize hosts:
    • Put public kiosks, lab devices, hypervisor hosts, and any systems that accept unknown USB devices high on the list.
  4. Patch and reboot:
    • Stage updates in a small pilot ring, then roll to production; coordinate reboots.
  5. Apply mitigations if immediate patching isn’t possible:
    • Disable USB in firmware or physically block ports, disable USB passthrough for VMs, and enforce device allowlists.
  6. Post‑patch validation:
    • Confirm GRUB functions on each patched host by verifying successful boots and checking GRUB version strings where possible.
  7. Long‑term: request vendor attestations and track OEM updates for embedded devices that cannot be patched via standard package managers.
Broader context: why small bootloader bugs matter​
Bootloaders are singularly sensitive components: they initialize hardware, parse low‑level media, and hand off control to operating systems. A denial of boot can halt entire services and often requires hands‑on recovery. Historically, small parsing mistakes in early boot code or kernel drivers disproportionately affect availability and can be leveraged as part of supply‑chain or physical sabotage operations. The GRUB2 fix here is emblematic of modern secure‑coding practice: tiny defensive checks and correct field usage eliminate a class of faults without heavy refactoring. Operators win by consuming those small fixes quickly and by hardening device‑attachment policies to reduce exposure windows.
CVE‑2025‑61661 is not a glamorous remote RCE—but it is a practical availability vulnerability in a high‑value component. The vulnerability is well‑understood, the upstream patch is focused and already published, and major distributors have begun mapping the issue into their packages. The operational imperative is straightforward: inventory GRUB2 across your fleet, apply vendor package updates and reboots as they become available, and in the interim enforce strict USB/boot device controls—particularly for systems that are public, multi‑tenant, or provide critical services. Small parsing bugs in boot code cause big outages; rapid, disciplined patching and device control are the right responses.
Appendix — Quick reference (single‑line items)
  • CVE: CVE‑2025‑61661 (GRUB2, USB string length mismatch).
  • Primary impact: Denial‑of‑Service / boot crash; limited risk of data corruption.
  • CVSS (reported): ~4.8 (Medium), vector highlights physical/local attack vector.
  • Upstream patch: replace descstr.length with descstrp->length in grub‑core/commands/usbtest.c.
  • Immediate mitigations: disable USB ports or USB passthrough; enforce device allowlists; patch and reboot when vendor packages are available.
