nandobadam88
Well-Known Member
HD Tune 5.60 is good or bad software for Full Surface Scan (Full ErrorScan disabled quickscan) for HDDs 2.5" buy in Aliexpress + enclosure case USB 3.0? to really discover the true health of the drive
HD Tune Pro 5.60, while a reliable and widely-used tool for general drive diagnostics, including full surface scans, should be used carefully when dealing with hard drives sourced from marketplaces like AliExpress, especially when paired with an external USB 3.0 enclosure. Here's a deep dive addressing your question:
Pros of Using HD Tune 5.60:​
  • Detailed Surface Scans: The Full Error Scan (when not using the "Quick Scan" option) can provide a thorough check of the disk's surface, looking for bad sectors.
  • SMART Monitoring: HD Tune can also check the drive's SMART data, which is critical for assessing its health (e.g., read/write errors, reallocated sectors).
  • User-Friendly Interface: It’s...
  • User-Friendly Interface: It’s straightforward to use, especially for quick diagnostics.
Limitations to Consider:​
  • USB Interface Limitations: Running health scans via an external USB enclosure can sometimes result in less accurate or incomplete results. This is due to potential compatibility issues, the quality of the USB bridge in the enclosure, or insufficient power supplied to the drive.
  • Bad Drives or Fake Drives: Drives bought from platforms like AliExpress are often known for counterfeit storage devices that misreport their capacity or health. HD Tune may not fully detect firmware-level counterfeits.
  • Tool Age: HD Tune 5.60 is no longer actively updated, so it lacks support for new standards (e.g., SMR drives or more advanced error-checking algorithms).
Alternatives or Supplemental Tools:​
To complement HD Tune, you may want to use the following:
  • CrystalDiskInfo: It provides a detailed breakdown of SMART data in real-time.
  • HDDScan: Another tool offering surface tests and deeper diagnostics, including USB-connected drives.
  • Victoria HDD: Known for its advanced surface scanning and error resolution capabilities.
Recommendations for Drive Testing:​
  • Initial Testing:
  • Use the "Full Error Scan" in HD Tune as your first diagnostic to detect obvious bad sectors.
  • Run a SMART check concurrently to look at key health indicators.
  • Power:
  • Ensure the USB enclosure is powered adequately (preferably with an external power supply if possible) to avoid errors caused by power fluctuations.
  • Storage Verification:
  • If you suspect the drive's capacity may be fake, use tools like H2testw or FakeFlashTest to confirm its reported capacity and performance.
  • Long-Term Monitoring:
  • Consider CrystalDiskInfo for ongoing monitoring since it provides a more dynamic readout, especially for drives used in enclosures.
Should You Use HD Tune 5.60?​
Yes, it's a good starting point for a Full Surface Scan when testing HDDs from AliExpress. However, you should be cautious with the results and consider corroborating with additional tools, especially since the source of the drive and the use of an external enclosure add layers of uncertainty.
Would you like assistance with setting up any of the recommended tools or interpreting scans?
Using HD Tune 5.60 for a Full Surface Scan (with QuickScan disabled) is a solid starting point to evaluate the physical health of a 2.5" HDD purchased on AliExpress housed in a USB 3.0 enclosure. However, while HD Tune is good for identifying surface-level issues like bad or slow sectors, it has some limitations in uncovering the true health of a potentially refurbished or tampered HDD. Let’s examine why:
1. Strengths of HD Tune for Full Surface Scans:​
a. Detects Physical Damage:
  • The Full Surface Scan mode tests every sector on the HDD for readability. It flags:
    • Bad Sectors (Unreadable): Areas on the platter that cannot be read or written to, indicating physical wear or damage.
    • Slow Sectors: Sectors that take longer than average to read, which may indicate wear or degradation.
  • This makes HD Tune effective at identifying platter-level issues.
b. Straightforward & Non-Destructive:
  • HD Tune’s scan operates in read-only mode by default during surface testing, meaning it won’t overwrite any data. This is ideal for testing drives that already contain data.
  • The interface is easy to use and delivers results in a grid format, visually highlighting healthy sectors (green) and damaged sectors (red).
c. Works Well with USB 3.0 Enclosures:
  • HD Tune is compatible with most USB-to-SATA enclosures when paired via USB 3.0. Your drive’s enclosure chipset (e.g., JMicron or ASMedia) should be capable of correctly relaying commands between the HDD and HD Tune, making the tool suitable for use with external drives.
d. Useful for Exposing AliExpress Drives:
  • Drives bought from AliExpress are often refurbished with potential platter or surface damage:
    • HD Tune can identify bad sectors that may have bypassed SMART monitoring (e.g., if SMART data has been reset or tampered with).
    • It’s a reliable method to verify if the reported "good condition" claims are accurate.
2. Limitations of HD Tune for Assessing True HDD Health
While HD Tune is excellent for basic surface damage testing, it may fail to uncover hidden health issues commonly found in refurbished or tampered drives:
a. No SMART Attribute Monitoring:
  • SMART attributes (Self-Monitoring, Analysis, and Reporting Technology) provide critical insights into an HDD’s overall health, including:
    • Reallocated sectors (bad sectors that have already been mapped to spare areas).
    • Pending sectors (unreadable sectors waiting to be re-mapped).
    • Power-on hours (actual usage of the drive).
  • HD Tune does not natively monitor or interpret SMART data, which means it cannot detect signs of long-term wear or tampering visible in SMART logs.
b. Firmware-Level Modifications Are Undetectable:
  • Many HDDs sold on AliExpress are refurbished, and sellers frequently reset SMART data or tamper with firmware to make the drive appear healthier.
  • HD Tune does not analyze firmware functionality or check for suppressed health attributes (e.g., no increment in Load/Unload Cycle Count, constant zero for G-Sense Error Rate, etc..
c. USB 3.0 Interface Limitations:
  • While USB 3.0 enclosures are generally reliable, lower-quality bridge chipsets may:
    • Skew test results by introducing latency (showing false slow sectors).
    • Mask drive behavior due to limited feature support (e.g., interference with SMART passthrough or caching).
  • Direct SATA connections provide more accurate results.
d. Testing Limitations for Logical and Predictive Health Issues:
  • HD Tune’s Surface Test can identify physical damage but does not provide insights into:
    • Logical errors affecting file systems.
    • Imminent failures predicted by shifts in SMART trends (e.g., consistent growth in reallocated sectors, vibration trends).
3. Complementary Tools to Use Alongside HD Tune
To get a complete picture of the drive’s health (especially for refurbished HDDs from AliExpress):
  • CrystalDiskInfo (SMART Monitoring):
    • Use CrystalDiskInfo to examine SMART attributes like:
      • Reallocated Sector Count (ID 05): Tracks how many bad sectors have been swapped with spare sectors.
      • Pending Sector Count (ID 197): Shows physically weak sectors awaiting reassignment.
      • Power-On Hours (ID 09): Confirms whether the drive’s usage history has been reset.
    • If SMART data looks suspiciously pristine or unchanging, tampering may have occurred.
  • HDDScan (Advanced Functionality Monitoring):
    • HDDScan can reveal:
      • Physical drive read/write speeds with deeper control over surface tests.
      • Potential drive issues like high vibration levels or firmware suppression of SMART attributes.
  • Victoria HDD:
    • Victoria can manually analyze HDD health by interacting directly with the firmware for low-level tests, including SMART status, power-off retracts, and more frequent surface scans.
  • WD Data Lifeguard Diagnostic (for WD drives):
    • If you bought a Western Digital drive, run this official diagnostic utility. It offers extended tests for bad sectors and firmware integrity.
4. How to Maximize the Accuracy of a Full Surface Scan on a USB 3.0 HDD
For accurate results while using HD Tune 5.60 on a 2.5” HDD in an enclosure, follow these tips:
a. Use a High-Quality USB 3.0 Enclosure:
  • Ensure the USB-to-SATA enclosure has a reliable chipset (e.g., JMicron JMS578 or ASMedia ASM1153).
  • Enclosures like Orico 25PW1 Black and Kesu 2530 are good options. Avoid cheap generic enclosures, as they can interfere with scan results.
b. Monitor Drive Temperature:
  • Use a tool like CrystalDiskInfo alongside HD Tune to check for overheating during the test:
    • Temperature should stay below 50–55°C.
    • Drives overheating during extended scans in passive-enclosure setups (like Orico and Kesu) should be cooled by pausing the test periodically.
c. Use a Stable USB Connection:
  • Avoid USB hubs or unreliable ports; connect the enclosure directly to the PC via a USB 3.0 port.
  • Verify connection stability before beginning a long surface scan.
d. Cross-Verify Results:
  • Combine the surface test results from HD Tune with SMART diagnostics to determine whether bad sectors are visible in SMART attributes (e.g., reallocated counts) or are being suppressed/hiding deeper issues.
5. When is HD Tune Good, and When is It Insufficient?
Good Scenarios for HD Tune:
  • Quickly checking for bad sectors or physical damage, especially on potentially unreliable drives purchased from marketplaces like AliExpress.
  • Diagnosing slow read/write performance issues caused by bad or slow sectors.
  • Confident testing of known-good drives in a reliable USB 3.0 enclosure to verify surface health.
When HD Tune May Be Insufficient:
  • When testing refurbished or tampered drives:
    • In many AliExpress cases, true drive health is hidden behind reset SMART data or altered firmware.
  • When you require predictive health reporting: HD Tune provides no insight into long-term trends (e.g., increasing reallocated or pending sectors).
  • For deep drive diagnostics, including logical errors, firmware analysis, or power management evaluations.
Summary: Is HD Tune Good for Full Surface Scans?
CriteriaPros of HD TuneCons of HD Tune
Bad Sector DetectionQuickly identifies bad and slow sectors visually.Cannot detect firmware-suppressed sectors or logical issues.
Ease of UseSimple interface with clear red/green sector mapping.Does not provide notable SMART or firmware insights (e.g., power-on hours).
USB 3.0 CompatibilityWorks with high-quality enclosures like Orico 25PW1 / Kesu 2530.USB overhead may cause slower performance compared to direct SATA.
Drive Health EvaluationGood for detecting surface damage on basic scans.Insufficient without complementary SMART and firmware testing tools.
HD Tune 5.60 is an effective tool for basic surface scans on external 2.5" HDDs but has limitations for refurbished drives with tampered firmware or reset SMART data—common on AliExpress purchases. To truly determine the health of the drive, you should combine HD Tune with SMART analysis tools (e.g., CrystalDiskInfo, HDDScan) to reveal deeper issues.
Let me know if you’d like step-by-step instructions on combining diagnostic tools!
HD Tune is good or bad software for Full Surface Scan (Full ErrorScan disabled quickscan) for HDDs 2.5" buy in Aliexpress + enclosure case USB 3.0? to really discover the true health of the drive
i use enclosure case USB3.0 Orico 25PW1 black and Kesu 2530
Yes, HD Tune is a good software tool for performing a Full Surface Scan (with QuickScan disabled) on 2.5" HDDs purchased from marketplaces like AliExpress and housed in USB 3.0 enclosures, such as the Orico 25PW1 or Kesu 2530. However, while it is excellent for detecting bad or slow sectors, it has some limitations when dealing with potentially refurbished or tampered drives often sold on such platforms. Refurbished drives may have their SMART data reset or firmware altered, which HD Tune cannot fully investigate.
Let’s analyze how well HD Tune works in your setup and what additional steps you can take to verify the true health of the drive:
a. Checks for Physical Drive Damage:
  • The Full Error Scan thoroughly tests all sectors of the HDD, reading sector by sector to detect:
    • Bad Sectors: Unreadable parts of the platters that indicate physical damage.
    • Slow Sectors: Sectors with slower-than-average read times, often a precursor to platter degradation or mechanical failure.
  • This makes HD Tune an effective tool for identifying surface-level issues in the drive’s platters.
b. Visual Output for Easy Interpretation:
  • HD Tune visually maps the results of the scan:
    • Green Blocks: Indicate sectors in good condition.
    • Red Blocks: Represent bad sectors.
  • This simple graphic allows you to quickly spot problematic regions.
c. USB 3.0 Compatibility:
  • Kesu 2530 and Orico 25PW1 black USB 3.0 enclosures are compatible with HD Tune due to their use of reliable USB-to-SATA chipsets (likely JMicron JMS578 or ASMedia ASM1153). These chipsets properly handle the communication between the HDD and the software, ensuring accurate results during surface scans.
d. Non-Destructive Testing:
  • HD Tune performs a read-only test, meaning the tool does not modify or overwrite data on the drive during the scan. This ensures your data remains safe (assuming the disk is still functional).
e. Good Starting Tool for AliExpress Drives:
  • Many HDDs sold on AliExpress are heavily refurbished or even counterfeit, so running a surface scan with HD Tune is a good first step for exposing physical problems on the platters, such as:
    • Hidden bad sectors.
    • Poor-quality repairs or long-term wear from excessive usage.
2. Limitations of HD Tune for Evaluating “True Health”
While HD Tune is powerful for locating surface issues, it falls short in other critical areas that help assess a drive’s overall reliability and health:
a. No SMART Monitoring:
  • SMART Data (Self-Monitoring, Analysis, and Reporting Technology) contains essential information about the health of the HDD, such as:
    • Reallocated Sector Count (ID 5): Tracks sectors that the drive has re-mapped to spare areas due to damage.
    • Pending Sector Count (ID 197): Shows sectors that are failing but haven’t been reallocated yet.
    • Power-On Hours (ID 9): Indicates how long the drive has been in use.
  • HD Tune does not evaluate SMART attributes during the Full Surface Scan, leaving you blind to historical data about the drive’s prior usage or wear.
b. Limited Insight into Firmware Alterations:
  • Many refurbished drives on AliExpress may have firmware tampering, such as:
    • Resetting SMART logs to hide high Power-On Hours or past disk errors.
    • Suppressing certain attributes (e.g., Load/Unload Cycle Count not incrementing).
  • HD Tune cannot detect whether these firmware functions have been altered, so a “clean” surface result doesn’t necessarily mean the drive is healthy.
c. USB-Specific Latency and False Positives:
  • While USB 3.0 enclosures are generally accurate for surface scans, there’s a slight risk of:
    • Slow Sector Misdiagnosis: The slight latency introduced by the USB interface can occasionally flag sectors as “slow” when they’re normal.
    • Interruptions in Power or Data Transmission: Poor-quality USB connections could cause false issues during testing.
d. Inability to Predict Failures:
  • HD Tune detects current physical issues (e.g., existing bad sectors) but does not analyze trends that could predict future failure. Tools that track SMART trends, like CrystalDiskInfo, are required for this.
3. Using HD Tune in Combination with Other Tools
To fully evaluate the health of a 2.5" HDD bought through a potentially unreliable source (like AliExpress), you should complement HD Tune with tools that can provide deeper insights:
a. CrystalDiskInfo (SMART Monitoring):
  • Use this tool to check for:
    • Reallocated Sector Count (ID 5): If this number is non-zero, the drive has failed sectors that were remapped.
    • Pending Sector Count (ID 197): If non-zero, the drive has sectors waiting for reallocation (a serious potential failure risk).
    • Power-On Hours (ID 9): If this value seems unrealistically low on a used/refurbished drive, it’s likely the SMART data was manipulated.
b. HDDScan:
  • Offers advanced sector health testing and SMART monitoring.
  • Includes extra surface scan options like read/write/verify modes for deeper testing.
c. Manufacturer Tools (If Applicable):
  • For Western Digital drives: WD Data Lifeguard Diagnostic provides extended surface testing and SMART verification.
  • For Seagate drives: SeaTools can test firmware behavior while checking surface health.
4. How to Perform a Full Surface Scan on Your Setup
Preparation:
  1. Confirm Stable Connections:
    • Ensure the USB cable and enclosure are connected securely to a USB 3.0 port on your PC.
    • Avoid using USB hubs, as they may cause instability during long surface scans.
  2. Monitor Temperature:
    • Use a tool like CrystalDiskInfo to monitor HDD temperature during the test.
    • Both Kesu 2530 and Orico 25PW1 black enclosures lack active cooling. If the drive temperature exceeds 50–55°C during the test, pause the scan and let the drive cool.
Performing the Scan:
  1. Launch HD Tune 5.60.
  2. Go to the Error Scan tab.
  3. Disable QuickScan (to ensure all sectors on the drive are tested).
  4. Begin the Full Surface Scan:
    • Depending on the drive size (e.g., 1TB), the scan may take 1–3 hours.
    • Keep an eye on the grid output:
      • Green Blocks: Healthy sectors.
      • Red Blocks: Bad sectors (indicating permanent damage to the platter).
Result Analysis:
  • If the scan completes with red blocks:
    • The drive has bad sectors and should not be used for critical data. Backup any data immediately and consider replacing the drive.
  • If the scan completes only with green blocks:
    • The drive’s surface appears healthy, but other vulnerabilities (e.g., declining SMART attributes) may still exist.
5. Enclosure Assessment: Kesu 2530 and Orico 25PW1 Black
FeatureKesu 2530Orico 25PW1 Black
Chipset QualityLikely JMicron (JMS578) with good USB-to-SATA support.Likely JMicron or ASMedia (strong compatibility).
Compatibility with HD TuneFully compatible with surface scans.Fully compatible.
Thermal ConcernMay heat up during prolonged scans; no fan included (passive cooling only).Same as Kesu—keep drive under 50–55°C.
6. When HD Tune is Ideal
  1. To Confirm Physical Platter Condition:
    • HD Tune is excellent for identifying existing bad sectors or surface-level damage after purchasing a used/refurbished HDD.
  2. To Create a Clear Visual Health Map:
    • The grid-based visualization quickly highlights bad sectors for easy reference.
  3. When Used with Trusted Enclosures:
    • Your current enclosures (Orico 25PW1 and Kesu 2530) are compatible and provide stable bridges for accurate testing.
7. Summary
CriteriaAdvantages (HD Tune)Limitations
Detection of Surface ProblemsEffective for finding bad sectors and highlighting damaged areas.Doesn’t analyze deeper issues related to firmware or SMART logs.
Ease of VisualizationSimple grid layout for quick understanding of sector health (red=bad).Provides no predictive health warnings.
Compatibility with USB 3.0Works well with good chipsets like JMicron and ASMedia in enclosures like Orico/Kesu.Cheap USB bridges may introduce latency or false slow sectors.
Final Verdict:
HD Tune is good for detecting surface-level issues on a 2.5" HDD inside USB 3.0 enclosures (like Kesu 2530 or Orico 25PW1). For true health evaluation, you should also use tools like CrystalDiskInfo or HDDScan to analyze SMART attributes and assess potential firmware tampering.
Would you like step-by-step instructions for combining HD Tune with SMART diagnostics? Let me know!
never scan a Usb drive... the software is designed for internal drives and usb ports can drop out without warning - if your software [any software] is reading to a drive when it goes offline bad things happen
I use HDD + USB enclosure case, I have no other alternative, it's very complex to open the PC and install the HDD in the motherboard.
HD Tune is generally a useful tool for performing a full surface scan on 2.5" HDDs—especially when you're testing drives purchased from marketplaces like AliExpress in USB 3.0 enclosures such as the Orico 25PW1 Black and Kesu 2530. However, its effectiveness depends on several factors and it has both strengths and limitations.
Advantages:
  • It performs a comprehensive error scan, reading every sector to identify physical defects such as bad sectors or slow sectors.
  • Its visual representation (i.e., a grid mapping of good and bad sectors) is easy to interpret.
  • When used with quality USB 3.0 enclosures (with reliable chipsets like JMicron JMS578 or ASMedia ASM1153E), it can provide an accurate surface health picture.
Limitations:
  • HD Tune’s surface test only checks the physical integrity of the disk’s surface; it doesn’t evaluate SMART attributes or firmware-level issues that might affect long-term reliability.
  • If the USB-to-SATA enclosure has any issues (such as buffering, power delivery, or signal instability), these can influence the scan results.
  • For complete diagnosis, HD Tune should ideally be used alongside SMART monitoring tools (like CrystalDiskInfo or HDDScan) to reveal hidden problems such as rising reallocated sector counts or pending sectors.
Recommendation:
For a thorough assessment of the true health of your 2.5" HDDs:
  • Use HD Tune's Full Surface Scan (with QuickScan disabled) to detect physical imperfections.
  • Supplement this with SMART diagnostics (using CrystalDiskInfo or HDDScan) to get insights into drive wear and potential failures.
  • Verify that your USB 3.0 enclosures (Orico 25PW1 and Kesu 2530) are operating reliably; poor enclosure performance can misrepresent scan results.
Overall, HD Tune is a good tool for basic and physical surface diagnostics, but for a complete assessment of long-term drive health, combining it with additional diagnostic tools is the best approach.
