HDF5 CVE-2025-6816 Heap Overflow: Risks, Fixes, and Mitigations
A heap-based buffer overflow in HDF5’s object-header serialization has been publicly documented and fixed, and defenders need to treat it as a practical risk for any service or product that opens untrusted .h5 files: CVE‑2025‑6816 affects HDF5 1.14.6 in the function H5O__fsinfo_encode (file src/H5Ofsinfo.c), and a proof-of-concept that triggers a crash is publicly available.
HDF5 memory-heap vulnerability CVE-2025-6816 with a patch option.Background / Overview​
HDF5 (Hierarchical Data Format 5) is the de facto binary container and C library used across scientific computing, engineering, and data‑intensive applications to store large numeric arrays, chunked datasets, and rich metadata. Because HDF5 is commonly linked directly into command-line tools, Python/R bindings, containerized services, and embedded appliances, a memory-safety defect inside the library can surface across a wide range of consumers.
CVE‑2025‑6816 was assigned after upstream researchers reported a heap-buffer-overflow that occurs during object-header serialization when processing corrupted or specially crafted metadata. The vulnerability manifests in HDF5 1.14.6, specifically inside the H5O__fsinfo_encode routine (src/H5Ofsinfo.c), and the upstream issue includes sanitizer output and a reproduction path. The public record and distribution trackers show consistent facts:
  • Affected upstream release: HDF5 1.14.6.
  • Root cause: heap-based buffer overflow in the object-header encoding path (H5O__fsinfo_encode).
  • Attack vector: local by default (an application must pass the crafted content to HDF5), but in practical deployments this becomes remotely exploitable when services accept and process uploaded .h5 files automatically.
What the bug actually is — technical anatomy​
Where the overflow occurs​
The vulnerable code is reached when HDF5 serializes file-system info messages while flushing object headers. A researcher‑reported sanitizer trace demonstrates a one‑byte write beyond an allocated heap buffer at H5Ofsinfo.c:243 inside H5O__fsinfo_encode. That is a classical heap-buffer-overflow: the function writes to memory past the end of its allocation when processing intentionally malformed metadata sequences. The upstream GitHub issue contains the AddressSanitizer output and an explicit reproduction harness built against the OSS‑Fuzz test harness.
Trigger conditions and practical reachability​
  • The immediate trigger is a malformed object-header continuation/message structure inside a .h5 file that causes the encode path to miscalculate or mis-handle a length, leading to a one‑byte or small overflow during serialization.
  • In real systems that accept arbitrary .h5 uploads — for example, web services that generate previews, ingestion pipelines that extract metadata, or automated conversion/thumbnailing backends — an unauthenticated remote actor can upload a crafted file and cause the vulnerable library code to execute inside a server process. That elevates the practical attack surface from local file to remote DoS at a minimum.
Proof‑of‑concept and evidence​
The GitHub issue includes test harness instructions, sanitizer logs, and references to a small PoC file repository used to reproduce the crash. Public vulnerability aggregators (NVD, Debian, Ubuntu trackers and independent VDBs) reference the same PoC artifacts, indicating the crash is reproducible and the problem is not hypothetical.
Impact analysis — confidentiality, integrity, availability​
This vulnerability’s practical impact is nuanced and depends heavily on deployment context, platform mitigations, and whether the target statically links HDF5 or uses a shared system library.
  • Availability: Primary immediate impact. A reliable crash PoC exists; repeated or automated triggering can cause worker churn, service instability, or sustained denial-of-service in systems that process untrusted HDF5 inputs (ingestion pipelines, preview servers).
  • Integrity: Possible. Heap corruption may result in data corruption or unexpected states in long‑running processes, particularly if the overflow overwrites in‑process metadata or serialization buffers. In some cases this may produce corrupted files or persistent erroneous state.
  • Confidentiality: Lower likelihood. The reported sanitizer trace and public analysis focus on writes past the buffer (overflow) rather than controlled reads that would leak memory. While heap abuse chains can sometimes be crafted to disclose memory, public advisories and upstream commentary treat information disclosure as a secondary concern.
  • Remote Code Execution (RCE): Unverified / speculative. Multiple public trackers caution that turning a heap overflow into reliable RCE depends on allocator behavior, compiler/hardening flags (ASLR, hardened allocators, RELRO, PIE), and exploitable surrounding conditions. No widely‑trusted public writeup has demonstrated stable RCE for this CVE as of public disclosure; therefore treat claims of RCE as unverified until independently reproduced by multiple, reliable researchers.
Who and what is affected​
  • Confirmed upstream affected: HDF5 1.14.6. Downstream packages that bundle or ship that exact library version are in scope. Because HDF5 is embedded across many ecosystems, the observable exposure categories include:
  • Server‑side ingestion and preview services that accept .h5 uploads.
  • Command‑line tools and utilities (h5dump, h5ls, h5repack) used in automated pipelines.
  • Statically linked binaries and vendor appliances that embed the library — such builds require a rebuild to remediate.
  • Containers, images, and CI runners that include the vulnerable library version in their images.
Distributors and trackers (Debian, Ubuntu, SUSE) have mapped the CVE to their packaging and listed vulnerable package sets; Debian published tracking notes linking to the GitHub issue and PR, and Ubuntu’s advisory maps the CVE to package priorities. These vendor trackers can help operators map which releases are affected in their environment.
Upstream response and fixes​
Upstream triage is visible on the HDF Group repository: the GitHub issue describing the heap-buffer-overflow was closed and associated pull requests implement bounds checks and defensive handling for corrupted continuation messages. The PRs and commits that close the issue are available in the project’s pull‑request history and are what downstream packagers must include in patched builds. Operators should prefer a vendor or upstream release that explicitly references the fix commits, or apply a vendor backport that lists the PR/commit SHA in the changelog. Key remediation options:
  • Upgrade to an upstream HDF5 release that includes the fix (watch for release notes explicitly referencing the PR/commit).
  • Apply vendor-supplied patches or package updates that include the upstream commits.
  • If neither is available, rebuild the library from source with the upstream commit(s) merged and redeploy any statically linked artifacts.
Immediate mitigations and defensive playbook​
Where patching cannot be immediate, deploy the following mitigations to reduce exposure and blast radius:
  • Inventory and prioritize:
  • Locate every binary, container image, and package that links HDF5 1.14.6 (dynamic or static). Search package manifests, wheels, conda/conda-forge artifacts, Docker images, and SBOMs.
  • Reduce attack surface:
  • Block or quarantine untrusted .h5 uploads. Replace automatic processing of user-provided HDF5 files with a manual review step or a strict validation/sandbox pipeline.
  • Enforce authentication and authorization for upload endpoints and quarantine incoming files for scanning before any decode action.
  • Contain and harden:
  • Run HDF5‑processing tasks in isolated, least‑privilege sandboxes (dedicated containers, seccomp/AppArmor/SELinux profiles, strict cgroups and ulimits).
  • If possible, separate previewing/metadata extraction into credentials‑restricted microservices and scale them horizontally so crashes are localized and observable.
  • Monitor and detect:
  • Instrument process crash alerts (systemd unit restarts, container health checks) and set high‑severity alerts for repeated core dumps or SIGSEGVs in HDF5‑linked processes.
  • Watch for known PoC file names or uploaded artifacts matching repositories referenced in public advisories—quarantine and analyze suspicious uploads.
  • Developer guidance:
  • Rebuild static binaries that embed HDF5 once patched library or commit is available.
  • Add unit tests and fuzz tests targeting object-header and message serialization paths.
  • Consider adding defensive pre-validation that rejects suspicious or inconsistent header/message lengths before calling low‑level encode/decode functions.
Risk assessment — who should worry most​
  • Cloud services and public ingestion endpoints: High urgency. These endpoints accept unauthenticated uploads at scale and can be trivially triggered by attackers to produce DoS or crash conditions without user interaction. Patch and/or sandbox these services first.
  • Research facilities, HPC clusters, and reproducible science images: Moderate to high urgency. These environments heavily use HDF5, often rely on precise builds, and occasionally use static linking — upgrading can be operationally expensive and slow, so containment and rebuild planning should begin immediately.
  • Desktop tools and local analysis workstations: Moderate urgency. The attack typically requires a user to open a malicious file; however, for targeted attacks (social engineering) this remains a viable vector. Prioritize machines used for collaborative or cross-organizational data exchange.
  • Vendor appliances and embedded devices that statically bundle HDF5: High long‑tail risk. These require vendor coordination and new firmware/software images to remediate; they may remain vulnerable for extended periods.
Reconciling severity and exploitability assessments​
Public trackers show slight divergence in scoring and urgency: some vendors (Ubuntu/SUSE) give this CVE a low/medium priority (CVSS v3 ~3.3 or CVSS v4 ~4.8 in some feeds), while others place higher emphasis on the presence of a PoC and the fact that multiple related HDF5 memory bugs were reported around the same release window. This divergence is common: CVSS scoring depends on the assumed attack vector and whether the environment processes untrusted inputs automatically. Operators should prioritize the practical threat model — services that process untrusted .h5 files at scale should treat this as high priority even if a generic CVSS score appears low. Important caution: although a crash PoC exists, claims of reliable RCE are not corroborated by multiple independent exploit writeups at publication time. Turning a heap overflow into dependable arbitrary code execution requires environmental conditions (predictable heap layout, absence of mitigations) that are often not present on modern, hardened hosts. Treat RCE as possible but unproven unless new, credible evidence appears.
Practical checklist for sysadmins and dev teams​
  • Inventory: Find all hosts, containers, and CI artifacts with HDF5 1.14.6.
  • Prioritize: Patch internet‑facing ingestion services, multi‑tenant hosts, and static‑linked artifacts first.
  • Patch: Apply vendor packages that explicitly reference the fix commits or upgrade to a patched upstream release.
  • Rebuild: Recompile statically linked binaries and rebuild containers that embed HDF5.
  • Contain: Sandbox HDF5 processing tasks and restrict upload flows.
  • Monitor: Alert on crashes and examine recent uploads if a host shows HDF5-related failures.
  • Validate: Run the upstream sanitizer harness or regression tests in a staging environment to confirm the fix behaves as expected.
Wider implications and long‑term recommendations​
This CVE is another reminder that infrastructure libraries used widely across scientific and enterprise systems must be treated as critical surface area in vulnerability management. Productivity and reproducibility pressures often delay patching in scientific teams; organizations should adopt supply-chain and runtime containment practices to mitigate that risk vector.
Long‑term steps to lower recurrence risk:
  • Add continuous fuzzing and AddressSanitizer/UBSan coverage for code that parses or serializes external binary formats.
  • Maintain SBOMs that list precise library versions and static linkages so triage can be rapid.
  • Encourage upstream maintainers to tag and publish consolidated security releases that clearly list fixed CVEs and commit SHAs — that improves downstream packaging confidence and reduces mismatch errors.
CVE‑2025‑6816 is a concrete, reproducible heap-based buffer overflow in HDF5 1.14.6’s object-header encode path (H5O__fsinfo_encode in src/H5Ofsinfo.c). The vulnerability can be triggered by crafted .h5 content and has a public proof‑of‑concept; while the dominant immediate effect is denial‑of‑service and process crash, the presence of a heap overflow raises long‑term exploitation concerns and merits rapid remediation for any systems that process untrusted HDF5 inputs. Operators should patch using official vendor or upstream fixes (or merge the upstream PR/commit), rebuild statically linked artifacts, sandbox HDF5 processing, and monitor for crashes and suspicious uploads. For defenders: prioritize internet‑facing ingestion endpoints and multi‑tenant processing nodes, apply the upstream or vendor patches that include the GitHub PR fixes, and treat any recurring, unexplained HDF5-related crashes as high‑severity indicators that merit immediate forensics and containment.
  • windowsforum-hdf5-cve-2025-6816-heap-overflow-risks-fixes-and-mitigations.webp
