Help
Help BSOD
Oversættelse fra Dansk til Engelsk
Hello everyone
is there anyone who can help me my computer keeps making BSOD
My computer is
motherbord asus m4a89gtd pro/usb3
cpu amd 1090t
kingston ram 4gb
graphics card Pov gtx275
psu corsair tx850w..
HELP!!!!!!!!!!
Loading Dump File [D:\040311-28797-01.dmp]
Symbol search path is: srv*c:\mss*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7600 MP (6 procs) Free x64
Built by: 7600.16695.amd64fre.win7_gdr.101026-1503
Machine Name:
Kernel base = 0xfffff800`02806000 PsLoadedModuleList = 0xfffff800`02a43e50
Debug session time: Sun Apr 3 10:14:32.792 2011 (UTC + 2:00)
System Uptime: 0 days 1:14:42.852
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck A, {fffffc604b3fa980, 2, 1, fffff80002897cf9}
Probably caused by : memory_corruption ( nt!MiUnlinkPageFromLockedList+6c9 )
Followup: MachineOwner
4: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
interrupt request level (IRQL) that is too high. This is usually
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: fffffc604b3fa980, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000001, bitfield :
Arg4: fffff80002897cf9, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff80002aae0e0
fffffc604b3fa980
CURRENT_IRQL: 2
FAULTING_IP:
fffff800`02897cf9 488914c1 mov qword ptr [rcx+rax*8],rdx
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0xA
PROCESS_NAME: avgnsa.exe
TRAP_FRAME: fffff8800c9fd700 -- (.trap 0xfffff8800c9fd700)
rax=0000003c0967f530 rbx=0000000000000000 rcx=fffffa8000000000
rdx=0000000000047a36 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002897cf9 rsp=fffff8800c9fd890 rbp=fffff80002ab01e0
r8=0000058000000000 r9=fffffa8000000008 r10=0000000000000000
r11=2aaaaaaaaaaaaaab r12=0000000000000000 r13=0000000000000000
iopl=0 nv up ei pl nz ac po nc
nt!MiUnlinkPageFromLockedList+0x6c9:
fffff800`02897cf9 488914c1 mov qword ptr [rcx+rax*8],rdx ds:0460:fffffc60`4b3fa980=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80002875ca9 to fffff80002876740
STACK_TEXT:
fffff880`0c9fd5b8 fffff800`02875ca9 : 00000000`0000000a fffffc60`4b3fa980 00000000`00000002 00000000`00000001 : nt!KeBugCheckEx
fffff880`0c9fd5c0 fffff800`02874920 : 00000000`001196cb fffffa80`01f96bc0 00000014`00000000 fffff6fb`831fdfd0 : nt!KiBugCheckDispatch+0x69
fffff880`0c9fd700 fffff800`02897cf9 : fffffa80`01f8e670 0000000f`ffffffff 7ff00000`00000000 00000000`03d5598f : nt!KiPageFault+0x260
fffff880`0c9fd890 fffff800`028a8587 : 0000000a`01964790 fffff680`00000000 0000007f`00000000 fffff680`0500cb20 : nt!MiUnlinkPageFromLockedList+0x6c9
fffff880`0c9fd920 fffff800`02892d26 : 00000000`00000000 0000000a`01964790 fffff680`0500c448 fffffa80`069cf998 : nt!MiResolveTransitionFault+0x167
fffff880`0c9fd9b0 fffff800`02890743 : ffffffff`ffffffff 0000000a`01889760 00000a8b`00000080 fffff880`00000000 : nt!MiDispatchFault+0x946
fffff880`0c9fdac0 fffff800`0287482e : 00000000`00000000 00000000`00000000 00000000`00000001 fffffa80`06fa3ae0 : nt!MmAccessFault+0x343
fffff880`0c9fdc20 0000000a`017886d4 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x16e
00000000`017bd6e0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0xa`017886d4
STACK_COMMAND: kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: nt!MiUnlinkPageFromLockedList+6c9
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4cc791bd
IMAGE_NAME: memory_corruption
FAILURE_BUCKET_ID: X64_0xA_nt!MiUnlinkPageFromLockedList+6c9
Re: Help BSOD
1. Attach CPU-Z screenshots:
a. memory tab
b. CPU tab
http://windows7forums.com/blue-scre...mportant-every-thread-starter-please-see.html
2. Attach RAMMon HTML.zip
3. dmp files from C:\Windows\Minidump
why cant i upload the files
Re: Help BSOD
now I tried to upload the files but nothing happens, what am I doing wrong
Post New Thread/Reply Thread ---> Go advanced ---> Manage attachments ---> Add files ---> Basic Uploader.
[langtitle=da]Re: Help BSOD[/langtitle]
[lang=da]undskyld igen, jeg er færdig som du skrev, men når man trykker på upload sker der ingenting. alle filerne i en rar fil 570 kb[/lang]
#7
Re: [langtitle=da]Re: Help BSOD[/langtitle]
sorry again I'm done as you wrote but when pressed on upload nothing happens. all the files located in a rar file
#8
Re: Help BSOD
Try again or upload to rapidshare.com.
#10
BugCheck 3B, {c0000005, fffff80002968165, fffff88004634ca0, 0}
Probably caused by : memory_corruption ( nt!MiGetTopLevelPfn+65 )
BugCheck 24, {1904fb, fffff8800e2acc58, fffff8800e2ac4c0, fffff8000289a7eb}
Probably caused by : Ntfs.sys ( Ntfs! ?? ::FNODOBFM::`string'+2cc9 )
1. RAM is set well. Still, if blue screens persist after the updates, run 10 passes of Memtest86+ - Advanced Memory Diagnostic Tool
2. Uninstall AVG:
AVG Worldwide - Download tools
3. Install MSE:
Virus, Spyware & Malware Protection | Microsoft Security Essentials
4. Update drivers:
Asus ATK0110 ACPI Utility
ASACPI.sys Sun Mar 27 22:30:36 2005
ALPHA Networks
anodlwfx.sys Fri Mar 06 05:10:08 2009
Atheros Extensible Wireless LAN
Darusb_win7x.sys Fri Dec 04 23:54:21 2009
Hardware Sensors Monitor
hmonitor45.sys Sat Jul 26 09:29:37 2008
NVIDIA
nvlddmkm.sys Thu May 14 16:48:07 2009
USB 3.0
nusb3xhc.sys Thu Apr 22 21:34:36 2010
CRASH DUMPS
Loading Dump File [F:\DMP\040311-28797-01.dmp]
Machine Name:
Debug session time: Sun Apr  3 04:14:32.792 2011 (UTC - 4:00)
4: kd> !analyze -v
Arguments:
Debugging Details:
 fffffc604b3fa980
CURRENT_IRQL:  2
FAULTING_IP:
BUGCHECK_STR:  0xA
STACK_TEXT:
STACK_COMMAND:  kb
FOLLOWUP_IP:
MODULE_NAME: nt
Loading Dump File [F:\DMP\033111-36332-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02868000 PsLoadedModuleList = 0xfffff800`02aa5e50
Debug session time: Thu Mar 31 10:46:22.590 2011 (UTC - 4:00)
System Uptime: 0 days 1:18:23.650
4: kd> !analyze -v
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000005, Exception code that caused the bugcheck
Arg2: fffff80002968165, Address of the instruction which caused the bugcheck
Arg3: fffff88004634ca0, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
FAULTING_IP:
fffff800`02968165 4c8b4928        mov     r9,qword ptr [rcx+28h]
CONTEXT:  fffff88004634ca0 -- (.cxr 0xfffff88004634ca0)
rax=0001000100000000 rbx=000fffffffffffff rcx=002ffab000000000
rdx=fffffff5556cbc79 rsi=fffffa8003908000 rdi=0000058000000000
rip=fffff80002968165 rsp=fffff88004635678 rbp=0000000000000002
 r8=fffffe00046356b0  r9=0001000100000000 r10=fffff88004635728
r11=0000000000000001 r12=000000003ffffff8 r13=0000000000000000
r14=fffff6fb40000000 r15=0000000fffffffff
iopl=0         nv up ei pl nz na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010206
nt!MiGetTopLevelPfn+0x65:
fffff800`02968165 4c8b4928        mov     r9,qword ptr [rcx+28h] ds:002b:002ffab0`00000028=????????????????
BUGCHECK_STR:  0x3B
PROCESS_NAME:  svchost.exe
CURRENT_IRQL:  2
LAST_CONTROL_TRANSFER:  from 0000000000000000 to fffff80002968165
STACK_TEXT:
fffff880`04635678 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!MiGetTopLevelPfn+0x65
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  0
SYMBOL_NAME:  nt!MiGetTopLevelPfn+65
MODULE_NAME: nt
STACK_COMMAND:  .cxr 0xfffff88004634ca0 ; kb
FAILURE_BUCKET_ID:  X64_0x3B_nt!MiGetTopLevelPfn+65
Loading Dump File [F:\DMP\040311-25552-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02814000 PsLoadedModuleList = 0xfffff800`02a51e50
Debug session time: Sun Apr  3 05:57:26.358 2011 (UTC - 4:00)
System Uptime: 0 days 0:07:15.314
4: kd> !analyze -v
NTFS_FILE_SYSTEM (24)
    If you see NtfsExceptionFilter on the stack then the 2nd and 3rd
    parameters are the exception record and context record. Do a .cxr
    on the 3rd parameter and then kb to obtain a more informative stack
    trace.
Arguments:
Arg1: 00000000001904fb
Arg2: fffff8800e2acc58
Arg3: fffff8800e2ac4c0
Arg4: fffff8000289a7eb
Debugging Details:
EXCEPTION_RECORD:  fffff8800e2acc58 -- (.exr 0xfffff8800e2acc58)
ExceptionAddress: fffff8000289a7eb (nt!MmCreateKernelStack+0x00000000000000d0)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
CONTEXT:  fffff8800e2ac4c0 -- (.cxr 0xfffff8800e2ac4c0)
rax=6bda5bab00000284 rbx=fffffa8006bdcb61 rcx=fffffa800262e481
rdx=fffffa80010ee7f1 rsi=fffffa8006bdcb60 rdi=6bda5bab00000254
rip=fffff8000289a7eb rsp=fffff8800e2ace90 rbp=0000000000000002
 r8=0000560000050800  r9=0000000fffffffff r10=fffffa8000000000
r11=fffffa80010ee7f0 r12=0000000000000000 r13=0000000000000002
iopl=0         nv up ei ng nz na po nc
cs=0010  ss=0018  ds=002b  es=002b  fs=0053  gs=002b             efl=00010286
nt!MmCreateKernelStack+0xd0:
fffff800`0289a7eb 488b48f8        mov     rcx,qword ptr [rax-8] ds:002b:6bda5bab`0000027c=????????????????
CURRENT_IRQL:  2
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  ffffffffffffffff
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002abc0e0
 ffffffffffffffff
FOLLOWUP_IP:
fffff880`0126b3d8 cc              int     3
FAULTING_IP:
nt!MmCreateKernelStack+d0
BUGCHECK_STR:  0x24
LAST_CONTROL_TRANSFER:  from fffff80002893fc4 to fffff8000289a7eb
STACK_TEXT:
fffff880`0e2abc58 fffff880`0126b3d8 : 00000000`00000024 00000000`001904fb fffff880`0e2acc58 fffff880`0e2ac4c0 : nt!KeBugCheckEx
fffff880`0e2abc60 fffff880`01263951 : fffff880`01297148 fffff880`0e2ad410 fffff880`0e2ad3e0 fffff8a0`017536a0 : Ntfs! ?? ::FNODOBFM::`string'+0x2cc9
fffff880`0e2abca0 fffff800`028b2d1c : fffffa80`039b6f70 fffffa80`06bdcb60 fffff8a0`00060006 fffff980`0550033a : Ntfs! ?? ::FNODOBFM::`string'+0x1446
fffff880`0e2abce0 fffff880`01263775 : fffff880`01297150 fffff880`0e2ad3e0 fffff880`0e2acc58 fffff880`0e2ad3e0 : nt!_C_specific_handler+0x8c
fffff880`0e2abd50 fffff800`028aa40d : fffff880`0129713c 00000000`00000000 fffff880`0124a000 00000000`00000000 : Ntfs!_GSHandlerCheck_SEH+0x75
fffff880`0e2abd80 fffff800`028b1a90 : fffff880`0129713c fffff880`0e2abdf8 fffff880`0e2acc58 fffff880`0124a000 : nt!RtlpExecuteHandlerForException+0xd
fffff880`0e2abdb0 fffff800`028be9ef : fffff880`0e2acc58 fffff880`0e2ac4c0 fffff880`00000000 6bda5bab`00000254 : nt!RtlDispatchException+0x410
fffff880`0e2ac490 fffff800`02883d82 : fffff880`0e2acc58 fffffa80`06bdcb61 fffff880`0e2acd00 fffffa80`06bdcb60 : nt!KiDispatchException+0x16f
fffff880`0e2acb20 fffff800`0288268a : 01cb8500`04f74800 01cbe600`e4709392 01cbe600`e4709392 00000000`016a1000 : nt!KiExceptionDispatch+0xc2
fffff880`0e2acd00 fffff800`0289a7eb : fffff880`0e2ad000 00000000`00000000 fffffa80`03df97f0 fffffa80`04d47180 : nt!KiGeneralProtectionFault+0x10a
fffff880`0e2ace90 fffff800`02893fc4 : fffffa80`03cd4450 fffffa80`06bdcb60 fffffa80`083c7140 fffff8a0`036517a0 : nt!MmCreateKernelStack+0xd0
fffff880`0e2acf70 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KeExpandKernelStackAndCalloutEx+0x244
STACK_COMMAND:  kb
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  Ntfs! ?? ::FNODOBFM::`string'+2cc9
MODULE_NAME: Ntfs
IMAGE_NAME:  Ntfs.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  4a5bc14f
FAILURE_BUCKET_ID:  X64_0x24_Ntfs!_??_::FNODOBFM::_string_+2cc9
DRIVERS
fffff880`06a2b000 fffff880`06a69000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00ece000 fffff880`00f25000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`06600000 fffff880`0668a000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`06ad5000 fffff880`06aeb000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`0693d000 fffff880`06952000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00e64000 fffff880`00e6f000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`066b9000 fffff880`066c2000   anodlwfx anodlwfx.sys Fri Mar 06 05:10:08 2009 (49B0F680)
fffff880`06897000 fffff880`0689f000   ASACPI   ASACPI.sys   Sun Mar 27 22:30:36 2005 (42476C4C)
fffff880`0e8f6000 fffff880`0e901000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00e31000 fffff880`00e3a000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00e3a000 fffff880`00e64000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff960`00810000 fffff960`00871000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`09976000 fffff880`099aa000   AVGIDSDriver AVGIDSDriver.Sys Tue Aug 03 18:24:45 2010 (4C58972D)
fffff880`018c7000 fffff880`018d1000   AVGIDSEH AVGIDSEH.Sys Mon Sep 13 18:46:38 2010 (4C8EA9CE)
fffff880`0987a000 fffff880`09886000   AVGIDSFilter AVGIDSFilter.Sys Tue Aug 03 18:23:21 2010 (4C5896D9)
fffff880`068c7000 fffff880`06917000   avgldx64 avgldx64.sys Tue Dec 07 21:01:55 2010 (4CFEE713)
fffff880`01977000 fffff880`01986000   avgmfx64 avgmfx64.sys Mon Sep 06 20:49:14 2010 (4C858C0A)
fffff880`018bd000 fffff880`018c7000   avgrkx64 avgrkx64.sys Mon Sep 06 20:49:37 2010 (4C858C21)
fffff880`066e1000 fffff880`06742000   avgtdia  avgtdia.sys  Fri Nov 12 06:08:42 2010 (4CDD203A)
fffff880`0198f000 fffff880`01996000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`013ed000 fffff880`013fe000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`095aa000 fffff880`095c8000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`006d0000 fffff960`006f7000   cdd      cdd.dll      unavailable (00000000)
fffff880`0194d000 fffff880`01977000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00c99000 fffff880`00d59000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`0188d000 fffff880`018bd000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c3b000 fffff880`00c99000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`0111c000 fffff880`0118f000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`06ac5000 fffff880`06ad5000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`01e75000 fffff880`01e83000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`01ef2000 fffff880`01ffc000   Darusb_win7x Darusb_win7x.sys Fri Dec 04 23:54:21 2009 (4B19E77D)
fffff880`0108a000 fffff880`010a8000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`01235000 fffff880`01244000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01074000 fffff880`0108a000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`06f87000 fffff880`06fa9000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`01907000 fffff880`0194d000   dtsoftbus01 dtsoftbus01.sys Mon Mar 14 09:15:36 2011 (4D7E14F8)
fffff880`01e8f000 fffff880`01e98000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01e83000 fffff880`01e8f000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`01e98000 fffff880`01eab000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`01eab000 fffff880`01eb7000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`07d09000 fffff880`07dfd000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`06952000 fffff880`06998000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`010aa000 fffff880`010be000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`00e6f000 fffff880`00ebb000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`0122b000 fffff880`01235000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`0103a000 fffff880`01074000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`01400000 fffff880`0144a000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`02df1000 fffff800`02e3a000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`06867000 fffff880`0688b000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`06eee000 fffff880`06f4a000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`01e38000 fffff880`01e51000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`01e51000 fffff880`01e59080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`01e2a000 fffff880`01e38000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`067f9000 fffff880`06800000   hmonitor45 hmonitor45.sys Sat Jul 26 09:29:37 2008 (488B26C1)
fffff880`094e2000 fffff880`095aa000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`015ee000 fffff880`015f7000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`06ba0000 fffff880`06baf000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`01e5a000 fffff880`01e68000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bb5000 fffff800`00bbf000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`06e12000 fffff880`06e55000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`01200000 fffff880`0121a000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`015b1000 fffff880`015dc000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`06fa9000 fffff880`06fae200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`06fd0000 fffff880`06fe5000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`01ec5000 fffff880`01ee8000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c1a000 fffff880`00c27000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`01eb7000 fffff880`01ec5000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`06baf000 fffff880`06bbe000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`01e68000 fffff880`01e75000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00e17000 fffff880`00e31000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`095c8000 fffff880`095e0000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`09400000 fffff880`0942d000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`09809000 fffff880`09857000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`09857000 fffff880`0987a000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`019f4000 fffff880`019ff000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f2e000 fffff880`00f38000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`010be000 fffff880`0111c000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`067ee000 fffff880`067f9000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`015dc000 fffff880`015ee000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0145f000 fffff880`01551000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`06b0f000 fffff880`06b1b000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`094b7000 fffff880`094ca000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`06b1b000 fffff880`06b4a000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`06ed9000 fffff880`06eee000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`06787000 fffff880`06796000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`06742000 fffff880`06787000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01551000 fffff880`015b1000   NETIO    NETIO.SYS    Mon Jul 13 19:21:46 2009 (4A5BC18A)
fffff880`01800000 fffff880`01811000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`067e2000 fffff880`067ee000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02814000 fffff800`02df1000   nt       ntkrnlmp.exe Tue Oct 26 22:43:09 2010 (4CC791BD)
fffff880`0124a000 fffff880`013ed000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`01986000 fffff880`0198f000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`06e67000 fffff880`06e7f000   nusb3hub nusb3hub.sys Thu Apr 22 21:34:35 2010 (4BD0F92B)
fffff880`06998000 fffff880`069c8000   nusb3xhc nusb3xhc.sys Thu Apr 22 21:34:36 2010 (4BD0F92C)
fffff880`07201000 fffff880`07d08b00   nvlddmkm nvlddmkm.sys Thu May 14 16:48:07 2009 (4A0C8387)
fffff880`09464000 fffff880`094b7000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`06693000 fffff880`066b9000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00f78000 fffff880`00f8d000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f38000 fffff880`00f6b000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00e00000 fffff880`00e07000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00e07000 fffff880`00e17000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`0121a000 fffff880`0122b000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`09886000 fffff880`0992c000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`06f4a000 fffff880`06f87000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c27000 fffff880`00c3b000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`06aeb000 fffff880`06b0f000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`06b4a000 fffff880`06b65000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`06b65000 fffff880`06b86000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`06b86000 fffff880`06ba0000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`0183c000 fffff880`0188d000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`019d9000 fffff880`019e2000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`019e2000 fffff880`019eb000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`019eb000 fffff880`019f4000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`01000000 fffff880`0103a000   rdyboost rdyboost.sys Mon Jul 13 19:34:34 2009 (4A5BC48A)
fffff880`094ca000 fffff880`094e2000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`06a69000 fffff880`06abc000   Rt64win7 Rt64win7.sys Sun May 30 23:46:43 2010 (4C033123)
fffff880`0992c000 fffff880`09937000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`0688b000 fffff880`06897000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`06796000 fffff880`067b3000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`0144a000 fffff880`01452000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`0e885000 fffff880`0e8f6000   spsys    spsys.sys    Mon May 11 13:20:58 2009 (4A085E7A)
fffff880`0bebe000 fffff880`0bf54000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`0be57000 fffff880`0bebe000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`09937000 fffff880`09964000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`06bbe000 fffff880`06bbf480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01601000 fffff880`017fe000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`09964000 fffff880`09976000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`0182f000 fffff880`0183c000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`01811000 fffff880`0182f000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`067ce000 fffff880`067e2000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`004a0000 fffff960`004aa000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`06917000 fffff880`0693d000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`0bf54000 fffff880`0bfa8000   udfs     udfs.sys     Mon Jul 13 19:23:37 2009 (4A5BC1F9)
fffff880`06e55000 fffff880`06e67000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`01e0d000 fffff880`01e2a000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`07dfd000 fffff880`07dfef00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`06856000 fffff880`06867000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`06e7f000 fffff880`06ed9000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`069c8000 fffff880`069d3000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`06800000 fffff880`06856000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`00f6b000 fffff880`00f78000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`01996000 fffff880`019a4000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`019a4000 fffff880`019c9000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00f8d000 fffff880`00fa2000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00fa2000 fffff880`00ffe000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`0118f000 fffff880`011db000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`01e00000 fffff880`01e0d000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`066c2000 fffff880`066d8000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`067b3000 fffff880`067ce000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`019c9000 fffff880`019d9000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00d59000 fffff880`00dfd000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00c00000 fffff880`00c0f000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`0668a000 fffff880`06693000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`000c0000 fffff960`003d0000   win32k   win32k.sys   Tue Jan 04 22:59:44 2011 (4D23ECB0)
fffff880`06abc000 fffff880`06ac5000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f25000 fffff880`00f2e000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`06faf000 fffff880`06fd0000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`018d1000 fffff880`018df000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`018df000 fffff880`018eb000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`018eb000 fffff880`018f4000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`018f4000 fffff880`01907000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
#13
Re: Help BSOD again
1. You were supposed to update drivers:
[B]
[/B]
2. Run 10 passes of memtest overnight
CRASH DUMPS
Loading Dump File [F:\DMP\040511-23727-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02a18000 PsLoadedModuleList = 0xfffff800`02c55e50
Debug session time: Tue Apr  5 00:35:08.609 2011 (UTC - 4:00)
System Uptime: 0 days 1:02:25.045
BugCheck 1A, {41790, fffffa800028ba80, ffff, 0}
Probably caused by : ntkrnlmp.exe ( nt! ?? ::FNODOBFM::`string'+33906 )
4: kd> !analyze -v
MEMORY_MANAGEMENT (1a)
    # Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000041790, The subtype of the bugcheck.
Arg2: fffffa800028ba80
Arg3: 000000000000ffff
Debugging Details:
BUGCHECK_STR:  0x1a_41790
PROCESS_NAME:  MsMpEng.exe
CURRENT_IRQL:  0
LAST_CONTROL_TRANSFER:  from fffff80002afbf9e to fffff80002a88740
STACK_TEXT:
fffff880`0d60d968 fffff800`02afbf9e : 00000000`0000001a 00000000`00041790 fffffa80`0028ba80 00000000`0000ffff : nt!KeBugCheckEx
fffff880`0d60d970 fffff800`02aca0da : 00000000`00000000 00000000`04df0fff fffffa80`00000000 fffffa80`076a5b30 : nt! ?? ::FNODOBFM::`string'+0x33906
fffff880`0d60db30 fffff800`02a87993 : ffffffff`ffffffff 00000000`0436ead0 00000000`0436ea98 00000000`00008000 : nt!NtFreeVirtualMemory+0x5ca
fffff880`0d60dc20 00000000`7792f89a : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceCopyEnd+0x13
00000000`0436ea08 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7792f89a
STACK_COMMAND:  kb
FOLLOWUP_IP:
fffff800`02afbf9e cc              int     3
SYMBOL_NAME:  nt! ?? ::FNODOBFM::`string'+33906
MODULE_NAME: nt
IMAGE_NAME:  ntkrnlmp.exe
FAILURE_BUCKET_ID:  X64_0x1a_41790_nt!_??_::FNODOBFM::_string_+33906
DRIVERS
fffff880`06939000 fffff880`06977000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00f68000 fffff880`00fbf000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`066df000 fffff880`06769000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`069e3000 fffff880`069f9000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`066c1000 fffff880`066d6000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00ea4000 fffff880`00eaf000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`06798000 fffff880`067a1000   anodlwfx anodlwfx.sys Fri Mar 06 05:10:08 2009 (49B0F680)
fffff880`06931000 fffff880`06939000   ASACPI   ASACPI.sys   Sun Mar 27 22:30:36 2005 (42476C4C)
fffff880`09d72000 fffff880`09d7d000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00e9b000 fffff880`00ea4000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fd2000 fffff880`00ffc000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff960`008b0000 fffff960`00911000   ATMFD    ATMFD.DLL    unavailable (00000000)
fffff880`02b6e000 fffff880`02b75000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`066b0000 fffff880`066c1000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`060c8000 fffff880`060e6000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00690000 fffff960`006b7000   cdd      cdd.dll      unavailable (00000000)
fffff880`02b0a000 fffff880`02b34000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00ceb000 fffff880`00dab000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`01074000 fffff880`010a4000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00c8d000 fffff880`00ceb000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01139000 fffff880`011ac000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`069d3000 fffff880`069e3000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`06c28000 fffff880`06c36000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`0825e000 fffff880`08368000   Darusb_win7x Darusb_win7x.sys Fri Dec 04 23:54:21 2009 (4B19E77D)
fffff880`06692000 fffff880`066b0000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`06683000 fffff880`06692000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`0121b000 fffff880`01231000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`06c00000 fffff880`06c22000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`02ac4000 fffff880`02b0a000   dtsoftbus01 dtsoftbus01.sys Mon Mar 14 09:15:36 2011 (4D7E14F8)
fffff880`06c42000 fffff880`06c4b000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`06c36000 fffff880`06c42000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`06c4b000 fffff880`06c5e000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`08375000 fffff880`08381000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`14905000 fffff880`149f9000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`13c00000 fffff880`13c46000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`010c7000 fffff880`010db000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`00dab000 fffff880`00df7000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`01211000 fffff880`0121b000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`015ab000 fffff880`015f5000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`02ff5000 fffff800`0303e000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`06901000 fffff880`06925000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`06d56000 fffff880`06db2000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`083ac000 fffff880`083c5000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`083c5000 fffff880`083cd080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`0839e000 fffff880`083ac000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`0667c000 fffff880`06683000   hmonitor45 hmonitor45.sys Sat Jul 26 09:29:37 2008 (488B26C1)
fffff880`06000000 fffff880`060c8000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`01412000 fffff880`0141b000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`02a96000 fffff880`02aa5000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`083ce000 fffff880`083dc000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00ba9000 fffff800`00bb3000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`06c7a000 fffff880`06cbd000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`013e5000 fffff880`013ff000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01580000 fffff880`015ab000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`06c22000 fffff880`06c27200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`08244000 fffff880`08259000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`08200000 fffff880`08223000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00c6c000 fffff880`00c79000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`083e9000 fffff880`083f7000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`02aa5000 fffff880`02ab4000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`083dc000 fffff880`083e9000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00e81000 fffff880`00e9b000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02b34000 fffff880`02b65000   MpFilter MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
fffff880`0617a000 fffff880`06192000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`06192000 fffff880`061bf000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`086f1000 fffff880`0873f000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`0873f000 fffff880`08762000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`02bd3000 fffff880`02bde000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00fc8000 fffff880`00fd2000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`010db000 fffff880`01139000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`06671000 fffff880`0667c000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`01400000 fffff880`01412000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`0142e000 fffff880`01520000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`06824000 fffff880`06830000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`0614f000 fffff880`06162000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`06830000 fffff880`0685f000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`06d41000 fffff880`06d56000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`067b7000 fffff880`067c6000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02a2b000 fffff880`02a70000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`01520000 fffff880`01580000   NETIO    NETIO.SYS    Thu Apr 08 22:43:59 2010 (4BBE946F)
fffff880`09cec000 fffff880`09d01000   NisDrvWFP NisDrvWFP.sys Tue Sep 14 20:20:25 2010 (4C901149)
fffff880`02bde000 fffff880`02bef000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`06665000 fffff880`06671000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02a18000 fffff800`02ff5000   nt       ntkrnlmp.exe Tue Oct 26 22:43:09 2010 (4CC791BD)
fffff880`01242000 fffff880`013e5000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`02b65000 fffff880`02b6e000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`06ccf000 fffff880`06ce7000   nusb3hub nusb3hub.sys Thu Apr 22 21:34:35 2010 (4BD0F92B)
fffff880`13c46000 fffff880`13c76000   nusb3xhc nusb3xhc.sys Thu Apr 22 21:34:36 2010 (4BD0F92C)
fffff880`14903000 fffff880`14904180   nvBridge nvBridge.kmd Fri Jan 07 20:57:22 2011 (4D27C482)
fffff880`13ca8000 fffff880`14902d00   nvlddmkm nvlddmkm.sys Fri Jan 07 21:07:22 2011 (4D27C6DA)
fffff880`060fc000 fffff880`0614f000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`06772000 fffff880`06798000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00e40000 fffff880`00e55000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00e00000 fffff880`00e33000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00e6a000 fffff880`00e71000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00e71000 fffff880`00e81000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`01200000 fffff880`01211000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`08600000 fffff880`086a6000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`06db2000 fffff880`06def000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00c79000 fffff880`00c8d000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`06800000 fffff880`06824000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`0685f000 fffff880`0687a000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`13c83000 fffff880`13ca4000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`0687a000 fffff880`06894000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`06614000 fffff880`06665000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`02bb8000 fffff880`02bc1000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02bc1000 fffff880`02bca000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02bca000 fffff880`02bd3000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`06162000 fffff880`0617a000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`06977000 fffff880`069ca000   Rt64win7 Rt64win7.sys Sun May 30 23:46:43 2010 (4C033123)
fffff880`086a6000 fffff880`086b1000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`06925000 fffff880`06931000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`067c6000 fffff880`067e3000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`015f5000 fffff880`015fd000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`09c56000 fffff880`09cec000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`08762000 fffff880`087c9000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`086b1000 fffff880`086de000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`06894000 fffff880`06895480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`01603000 fffff880`01800000   tcpip    tcpip.sys    Sun Jun 13 23:39:04 2010 (4C15A458)
fffff880`086de000 fffff880`086f0000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`02a1e000 fffff880`02a2b000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`02a00000 fffff880`02a1e000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`06600000 fffff880`06614000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`00500000 fffff960`0050a000   TSDDD    TSDDD.dll    Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02a70000 fffff880`02a96000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`06cbd000 fffff880`06ccf000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`08381000 fffff880`0839e000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`13c76000 fffff880`13c77f00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`068f0000 fffff880`06901000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`06ce7000 fffff880`06d41000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`13c78000 fffff880`13c83000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`0689a000 fffff880`068f0000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`00e33000 fffff880`00e40000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`02b75000 fffff880`02b83000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`02b83000 fffff880`02ba8000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00e55000 fffff880`00e6a000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00c00000 fffff880`00c5c000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`011ac000 fffff880`011f8000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`08368000 fffff880`08375000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`067a1000 fffff880`067b7000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`067e3000 fffff880`067fe000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`02ba8000 fffff880`02bb8000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00eb5000 fffff880`00f59000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00f59000 fffff880`00f68000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`06769000 fffff880`06772000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`00070000 fffff960`00380000   win32k   win32k.sys   Tue Jan 04 22:59:44 2011 (4D23ECB0)
fffff880`069ca000 fffff880`069d3000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00fbf000 fffff880`00fc8000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`08223000 fffff880`08244000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`09d01000 fffff880`09d72000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`0141b000 fffff880`01429000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`01231000 fffff880`0123d000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`010a4000 fffff880`010ad000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`010ad000 fffff880`010c0000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
#14
[langtitle=da]Re: Help BSOD again[/langtitle]
[lang=da]Hej jeg har har kørt memtest og den fandt ingen fejl,og jeg har installert mse, og opdateret driver , men fik en ny BSOD i dag, hvad kan der være galt.. files a rapidshare http://rapidshare.com/files/456316668/040711-21793-01.rar[/lang]
#15
Re: [langtitle=da]Re: Help BSOD again[/langtitle]
It still looks like a memory issue.
Navigate to c:\windows\system32\drivers and rename to .bak this file:
1. It is recommended to test each stick separately and in different slots.
RAM - Test with Memtest86+ - Windows 7 Forums
2. Command Prompt > chkdsk /f
3. Command Prompt > sfc /scannow
Report the results.
CRASH DUMPS
Loading Dump File [F:\DMP\040711-21793-01.dmp]
Machine Name:
Kernel base = 0xfffff800`02a0a000 PsLoadedModuleList = 0xfffff800`02c47e50
Debug session time: Thu Apr  7 07:05:16.035 2011 (UTC - 4:00)
System Uptime: 0 days 6:37:43.471
BugCheck D1, {ff0101, 2, 9, ff0101}
Probably caused by : ntkrnlmp.exe ( nt!KiPageFault+260 )
4: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 0000000000ff0101, memory referenced
Arg3: 0000000000000009, value 0 = read operation, 1 = write operation
Arg4: 0000000000ff0101, address which referenced memory
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from fffff80002cb20e0
 0000000000ff0101
CURRENT_IRQL:  2
FAULTING_IP:
+3661376264666230
00000000`00ff0101 ??              ???
PROCESS_NAME:  iexplore.exe
BUGCHECK_STR:  0xD1
TRAP_FRAME:  fffff88002e46ca0 -- (.trap 0xfffff88002e46ca0)
rax=0000000000000004 rbx=0000000000000000 rcx=0000000000000000
rdx=fffffa800528e7a0 rsi=0000000000000000 rdi=0000000000000000
rip=0000000000ff0101 rsp=fffff88002e46e30 rbp=fffff88002e46ed0
 r8=fffff88002e46e01  r9=00000000002fd844 r10=0000000000000000
r11=000000116bf1ba18 r12=0000000000000000 r13=0000000000000000
iopl=0         nv up ei pl zr na po nc
LAST_CONTROL_TRANSFER:  from fffff80002a79ca9 to fffff80002a7a740
STACK_TEXT:
fffff880`02e46b58 fffff800`02a79ca9 : 00000000`0000000a 00000000`00ff0101 00000000`00000002 00000000`00000009 : nt!KeBugCheckEx
fffff880`02e46b60 fffff800`02a78920 : 00000000`00000000 00000000`00000000 00000000`ffffffff 00000000`00000000 : nt!KiBugCheckDispatch+0x69
fffff880`02e46ca0 00000000`00ff0101 : fffff880`009b41e0 00000000`00000002 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x260
fffff880`02e46e30 fffff880`009b41e0 : 00000000`00000002 00000000`00000000 00000000`00000000 00000000`00000001 : 0xff0101
fffff880`02e46e38 00000000`00000002 : 00000000`00000000 00000000`00000000 00000000`00000001 fffff800`02b61bca : 0xfffff880`009b41e0
fffff880`02e46e40 00000000`00000000 : 00000000`00000000 00000000`00000001 fffff800`02b61bca fffff880`009b1180 : 0x2
STACK_COMMAND:  kb
FOLLOWUP_IP:
nt!KiPageFault+260
fffff800`02a78920 440f20c0        mov     rax,cr8
SYMBOL_STACK_INDEX:  2
SYMBOL_NAME:  nt!KiPageFault+260
MODULE_NAME: nt
FAILURE_BUCKET_ID:  X64_0xD1_nt!KiPageFault+260
DRIVERS
fffff880`068de000 fffff880`0691c000   1394ohci 1394ohci.sys Mon Jul 13 20:07:12 2009 (4A5BCC30)
fffff880`00f0a000 fffff880`00f61000   ACPI     ACPI.sys     Mon Jul 13 19:19:34 2009 (4A5BC106)
fffff880`06627000 fffff880`066b1000   afd      afd.sys      Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`06988000 fffff880`0699e000   AgileVpn AgileVpn.sys Mon Jul 13 20:10:24 2009 (4A5BCCF0)
fffff880`02a95000 fffff880`02aaa000   amdppm   amdppm.sys   Mon Jul 13 19:19:25 2009 (4A5BC0FD)
fffff880`00ff5000 fffff880`01000000   amdxata  amdxata.sys  Tue May 19 13:56:59 2009 (4A12F2EB)
fffff880`066e0000 fffff880`066e9000   anodlwfx anodlwfx.sys Fri Mar 06 05:10:08 2009 (49B0F680)
fffff880`068d6000 fffff880`068de000   ASACPI   ASACPI.sys   Wed Jul 15 23:31:29 2009 (4A5E9F11)
fffff880`08939000 fffff880`08944000   asyncmac asyncmac.sys Mon Jul 13 20:10:13 2009 (4A5BCCE5)
fffff880`00e1a000 fffff880`00e23000   atapi    atapi.sys    Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00e23000 fffff880`00e4d000   ataport  ataport.SYS  Mon Jul 13 19:19:52 2009 (4A5BC118)
fffff960`00900000 fffff960`00961000   ATMFD    ATMFD.DLL    Fri Jan 07 00:49:20 2011 (4D26A960)
fffff880`02ba2000 fffff880`02ba9000   Beep     Beep.SYS     Mon Jul 13 20:00:13 2009 (4A5BCA8D)
fffff880`067ef000 fffff880`06800000   blbdrive blbdrive.sys Mon Jul 13 19:35:59 2009 (4A5BC4DF)
fffff880`0458e000 fffff880`045ac000   bowser   bowser.sys   Mon Jul 13 19:23:50 2009 (4A5BC206)
fffff960`00710000 fffff960`00737000   cdd      cdd.dll      Wed Jan 26 01:31:34 2011 (4D3FBFC6)
fffff880`0834c000 fffff880`08369000   cdfs     cdfs.sys     Mon Jul 13 19:19:46 2009 (4A5BC112)
fffff880`02b3e000 fffff880`02b68000   cdrom    cdrom.sys    Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`00c00000 fffff880`00cc0000   CI       CI.dll       Mon Jul 13 21:32:13 2009 (4A5BE01D)
fffff880`0103a000 fffff880`0106a000   CLASSPNP CLASSPNP.SYS Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00d1d000 fffff880`00d7b000   CLFS     CLFS.SYS     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`01128000 fffff880`0119b000   cng      cng.sys      Mon Jul 13 19:49:40 2009 (4A5BC814)
fffff880`06978000 fffff880`06988000   CompositeBus CompositeBus.sys Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`083d1000 fffff880`083df000   crashdmp crashdmp.sys Mon Jul 13 20:01:01 2009 (4A5BCABD)
fffff880`08235000 fffff880`0833f000   Darusb_win7x Darusb_win7x.sys Fri Dec 04 23:54:21 2009 (4B19E77D)
fffff880`067d1000 fffff880`067ef000   dfsc     dfsc.sys     Mon Jul 13 19:23:44 2009 (4A5BC200)
fffff880`067c2000 fffff880`067d1000   discache discache.sys Mon Jul 13 19:37:18 2009 (4A5BC52E)
fffff880`01200000 fffff880`01216000   disk     disk.sys     Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`06c99000 fffff880`06cbb000   drmk     drmk.sys     Mon Jul 13 21:01:25 2009 (4A5BD8E5)
fffff880`02af8000 fffff880`02b3e000   dtsoftbus01 dtsoftbus01.sys Mon Mar 14 09:15:36 2011 (4D7E14F8)
fffff880`083eb000 fffff880`083f4000   dump_atapi dump_atapi.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`083df000 fffff880`083eb000   dump_dumpata dump_dumpata.sys Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`08200000 fffff880`08213000   dump_dumpfve dump_dumpfve.sys Mon Jul 13 19:21:51 2009 (4A5BC18F)
fffff880`08213000 fffff880`0821f000   Dxapi    Dxapi.sys    Mon Jul 13 19:38:28 2009 (4A5BC574)
fffff880`14884000 fffff880`14978000   dxgkrnl  dxgkrnl.sys  Tue Jan 25 23:22:56 2011 (4D3FA1A0)
fffff880`14978000 fffff880`149be000   dxgmms1  dxgmms1.sys  Tue Jan 25 23:22:12 2011 (4D3FA174)
fffff880`010b6000 fffff880`010ca000   fileinfo fileinfo.sys Mon Jul 13 19:34:25 2009 (4A5BC481)
fffff880`0106a000 fffff880`010b6000   fltmgr   fltmgr.sys   Mon Jul 13 19:19:59 2009 (4A5BC11F)
fffff880`013ed000 fffff880`013f7000   Fs_Rec   Fs_Rec.sys   Mon Jul 13 19:19:45 2009 (4A5BC111)
fffff880`00cc0000 fffff880`00cfa000   fvevol   fvevol.sys   Fri Sep 25 22:34:26 2009 (4ABD7DB2)
fffff880`01581000 fffff880`015cb000   fwpkclnt fwpkclnt.sys Mon Jul 13 19:21:08 2009 (4A5BC164)
fffff800`02fe7000 fffff800`03030000   hal      hal.dll      Mon Jul 13 21:27:36 2009 (4A5BDF08)
fffff880`068a6000 fffff880`068ca000   HDAudBus HDAudBus.sys Mon Jul 13 20:06:13 2009 (4A5BCBF5)
fffff880`06c00000 fffff880`06c5c000   HdAudio  HdAudio.sys  Mon Jul 13 20:06:59 2009 (4A5BCC23)
fffff880`08394000 fffff880`083ad000   HIDCLASS HIDCLASS.SYS Mon Jul 13 20:06:21 2009 (4A5BCBFD)
fffff880`083ad000 fffff880`083b5080   HIDPARSE HIDPARSE.SYS Mon Jul 13 20:06:17 2009 (4A5BCBF9)
fffff880`08386000 fffff880`08394000   hidusb   hidusb.sys   Mon Jul 13 20:06:22 2009 (4A5BCBFE)
fffff880`044c6000 fffff880`0458e000   HTTP     HTTP.sys     Mon Jul 13 19:22:16 2009 (4A5BC1A8)
fffff880`015e5000 fffff880`015ee000   hwpolicy hwpolicy.sys Mon Jul 13 19:19:22 2009 (4A5BC0FA)
fffff880`02aaa000 fffff880`02ab9000   kbdclass kbdclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`083b6000 fffff880`083c4000   kbdhid   kbdhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff800`00bd1000 fffff800`00bdb000   kdcom    kdcom.dll    Mon Jul 13 21:31:07 2009 (4A5BDFDB)
fffff880`06cc9000 fffff880`06d0c000   ks       ks.sys       Wed Mar 03 23:32:25 2010 (4B8F37D9)
fffff880`013c2000 fffff880`013dc000   ksecdd   ksecdd.sys   Mon Jul 13 19:20:54 2009 (4A5BC156)
fffff880`01556000 fffff880`01581000   ksecpkg  ksecpkg.sys  Fri Dec 11 01:03:32 2009 (4B21E0B4)
fffff880`06cbb000 fffff880`06cc0200   ksthunk  ksthunk.sys  Mon Jul 13 20:00:19 2009 (4A5BCA93)
fffff880`06de9000 fffff880`06dfe000   lltdio   lltdio.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`06da5000 fffff880`06dc8000   luafv    luafv.sys    Mon Jul 13 19:26:13 2009 (4A5BC295)
fffff880`00cfc000 fffff880`00d09000   mcupdate_AuthenticAMD mcupdate_AuthenticAMD.dll Mon Jul 13 21:29:09 2009 (4A5BDF65)
fffff880`0821f000 fffff880`0822d000   monitor  monitor.sys  Mon Jul 13 19:38:52 2009 (4A5BC58C)
fffff880`02ab9000 fffff880`02ac8000   mouclass mouclass.sys Mon Jul 13 19:19:50 2009 (4A5BC116)
fffff880`083c4000 fffff880`083d1000   mouhid   mouhid.sys   Mon Jul 13 20:00:20 2009 (4A5BCA94)
fffff880`00e00000 fffff880`00e1a000   mountmgr mountmgr.sys Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`02b68000 fffff880`02b99000   MpFilter MpFilter.sys Tue Sep 14 20:19:28 2010 (4C901110)
fffff880`08944000 fffff880`08954000   MpNWMon  MpNWMon.sys  Tue Sep 14 20:19:30 2010 (4C901112)
fffff880`045ac000 fffff880`045c4000   mpsdrv   mpsdrv.sys   Mon Jul 13 20:08:25 2009 (4A5BCC79)
fffff880`045c4000 fffff880`045f1000   mrxsmb   mrxsmb.sys   Sat Feb 27 02:52:19 2010 (4B88CF33)
fffff880`08667000 fffff880`086b5000   mrxsmb10 mrxsmb10.sys Sat Feb 27 02:52:28 2010 (4B88CF3C)
fffff880`086b5000 fffff880`086d8000   mrxsmb20 mrxsmb20.sys Sat Feb 27 02:52:26 2010 (4B88CF3A)
fffff880`02a09000 fffff880`02a14000   Msfs     Msfs.SYS     Mon Jul 13 19:19:47 2009 (4A5BC113)
fffff880`00f6a000 fffff880`00f74000   msisadrv msisadrv.sys Mon Jul 13 19:19:26 2009 (4A5BC0FE)
fffff880`010ca000 fffff880`01128000   msrpc    msrpc.sys    Mon Jul 13 19:21:32 2009 (4A5BC17C)
fffff880`067b7000 fffff880`067c2000   mssmbios mssmbios.sys Mon Jul 13 19:31:10 2009 (4A5BC3BE)
fffff880`015d3000 fffff880`015e5000   mup      mup.sys      Mon Jul 13 19:23:45 2009 (4A5BC201)
fffff880`01404000 fffff880`014f6000   ndis     ndis.sys     Mon Jul 13 19:21:40 2009 (4A5BC184)
fffff880`069c2000 fffff880`069ce000   ndistapi ndistapi.sys Mon Jul 13 20:10:00 2009 (4A5BCCD8)
fffff880`0449b000 fffff880`044ae000   ndisuio  ndisuio.sys  Mon Jul 13 20:09:25 2009 (4A5BCCB5)
fffff880`069ce000 fffff880`069fd000   ndiswan  ndiswan.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`06d90000 fffff880`06da5000   NDProxy  NDProxy.SYS  Mon Jul 13 20:10:05 2009 (4A5BCCDD)
fffff880`066ff000 fffff880`0670e000   netbios  netbios.sys  Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff880`02a50000 fffff880`02a95000   netbt    netbt.sys    Mon Jul 13 19:21:28 2009 (4A5BC178)
fffff880`014f6000 fffff880`01556000   NETIO    NETIO.SYS    Thu Apr 08 22:43:59 2010 (4BBE946F)
fffff880`088b3000 fffff880`088c8000   NisDrvWFP NisDrvWFP.sys Tue Sep 14 20:20:25 2010 (4C901149)
fffff880`02a14000 fffff880`02a25000   Npfs     Npfs.SYS     Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`067ab000 fffff880`067b7000   nsiproxy nsiproxy.sys Mon Jul 13 19:21:02 2009 (4A5BC15E)
fffff800`02a0a000 fffff800`02fe7000   nt       ntkrnlmp.exe Tue Oct 26 22:43:09 2010 (4CC791BD)
fffff880`0121f000 fffff880`013c2000   Ntfs     Ntfs.sys     Mon Jul 13 19:20:47 2009 (4A5BC14F)
fffff880`02b99000 fffff880`02ba2000   Null     Null.SYS     Mon Jul 13 19:19:37 2009 (4A5BC109)
fffff880`06d1e000 fffff880`06d36000   nusb3hub nusb3hub.sys Thu Apr 22 21:34:35 2010 (4BD0F92B)
fffff880`149be000 fffff880`149ee000   nusb3xhc nusb3xhc.sys Thu Apr 22 21:34:36 2010 (4BD0F92C)
fffff880`14882000 fffff880`14883180   nvBridge nvBridge.kmd Fri Jan 07 20:57:22 2011 (4D27C482)
fffff880`13c27000 fffff880`14881d00   nvlddmkm nvlddmkm.sys Fri Jan 07 21:07:22 2011 (4D27C6DA)
fffff880`04448000 fffff880`0449b000   nwifi    nwifi.sys    Mon Jul 13 20:07:23 2009 (4A5BCC3B)
fffff880`066ba000 fffff880`066e0000   pacer    pacer.sys    Mon Jul 13 20:09:41 2009 (4A5BCCC5)
fffff880`00fb4000 fffff880`00fc9000   partmgr  partmgr.sys  Mon Jul 13 19:19:58 2009 (4A5BC11E)
fffff880`00f74000 fffff880`00fa7000   pci      pci.sys      Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`00fde000 fffff880`00fe5000   pciide   pciide.sys   Mon Jul 13 19:19:49 2009 (4A5BC115)
fffff880`00fe5000 fffff880`00ff5000   PCIIDEX  PCIIDEX.SYS  Mon Jul 13 19:19:48 2009 (4A5BC114)
fffff880`013dc000 fffff880`013ed000   pcw      pcw.sys      Mon Jul 13 19:19:27 2009 (4A5BC0FF)
fffff880`086d8000 fffff880`0877e000   peauth   peauth.sys   Mon Jul 13 21:01:19 2009 (4A5BD8DF)
fffff880`06c5c000 fffff880`06c99000   portcls  portcls.sys  Mon Jul 13 20:06:27 2009 (4A5BCC03)
fffff880`00d09000 fffff880`00d1d000   PSHED    PSHED.dll    Mon Jul 13 21:32:23 2009 (4A5BE027)
fffff880`0699e000 fffff880`069c2000   rasl2tp  rasl2tp.sys  Mon Jul 13 20:10:11 2009 (4A5BCCE3)
fffff880`06800000 fffff880`0681b000   raspppoe raspppoe.sys Mon Jul 13 20:10:17 2009 (4A5BCCE9)
fffff880`0681b000 fffff880`0683c000   raspptp  raspptp.sys  Mon Jul 13 20:10:18 2009 (4A5BCCEA)
fffff880`13c00000 fffff880`13c1a000   rassstp  rassstp.sys  Mon Jul 13 20:10:25 2009 (4A5BCCF1)
fffff880`0675a000 fffff880`067ab000   rdbss    rdbss.sys    Mon Jul 13 19:24:09 2009 (4A5BC219)
fffff880`02bec000 fffff880`02bf5000   RDPCDD   RDPCDD.sys   Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02bf5000 fffff880`02bfe000   rdpencdd rdpencdd.sys Mon Jul 13 20:16:34 2009 (4A5BCE62)
fffff880`02a00000 fffff880`02a09000   rdprefmp rdprefmp.sys Mon Jul 13 20:16:35 2009 (4A5BCE63)
fffff880`044ae000 fffff880`044c6000   rspndr   rspndr.sys   Mon Jul 13 20:08:50 2009 (4A5BCC92)
fffff880`0691c000 fffff880`0696f000   Rt64win7 Rt64win7.sys Sun May 30 23:46:43 2010 (4C033123)
fffff880`0877e000 fffff880`08789000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffff880`068ca000 fffff880`068d6000   serenum  serenum.sys  Mon Jul 13 20:00:33 2009 (4A5BCAA1)
fffff880`0670e000 fffff880`0672b000   serial   serial.sys   Mon Jul 13 20:00:40 2009 (4A5BCAA8)
fffff880`015cb000 fffff880`015d3000   spldr    spldr.sys    Mon May 11 12:56:27 2009 (4A0858BB)
fffff880`0881d000 fffff880`088b3000   srv      srv.sys      Thu Aug 26 23:38:00 2010 (4C773318)
fffff880`08600000 fffff880`08667000   srv2     srv2.sys     Thu Aug 26 23:37:46 2010 (4C77330A)
fffff880`08789000 fffff880`087b6000   srvnet   srvnet.sys   Thu Aug 26 23:37:24 2010 (4C7732F4)
fffff880`0683c000 fffff880`0683d480   swenum   swenum.sys   Mon Jul 13 20:00:18 2009 (4A5BCA92)
fffff880`087b6000 fffff880`087c8000   tcpipreg tcpipreg.sys Mon Jul 13 20:09:49 2009 (4A5BCCCD)
fffff880`02a43000 fffff880`02a50000   TDI      TDI.SYS      Mon Jul 13 19:21:18 2009 (4A5BC16E)
fffff880`02a25000 fffff880`02a43000   tdx      tdx.sys      Mon Jul 13 19:21:15 2009 (4A5BC16B)
fffff880`06746000 fffff880`0675a000   termdd   termdd.sys   Mon Jul 13 20:16:36 2009 (4A5BCE64)
fffff960`005b0000 fffff960`005ba000   TSDDD    TSDDD.dll    unavailable (00000000)
fffff880`06600000 fffff880`06626000   tunnel   tunnel.sys   Mon Jul 13 20:09:37 2009 (4A5BCCC1)
fffff880`06d0c000 fffff880`06d1e000   umbus    umbus.sys    Mon Jul 13 20:06:56 2009 (4A5BCC20)
fffff880`08369000 fffff880`08386000   usbccgp  usbccgp.sys  Mon Jul 13 20:06:45 2009 (4A5BCC15)
fffff880`149ee000 fffff880`149eff00   USBD     USBD.SYS     Mon Jul 13 20:06:23 2009 (4A5BCBFF)
fffff880`06895000 fffff880`068a6000   usbehci  usbehci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`06d36000 fffff880`06d90000   usbhub   usbhub.sys   Mon Jul 13 20:07:09 2009 (4A5BCC2D)
fffff880`149f0000 fffff880`149fb000   usbohci  usbohci.sys  Mon Jul 13 20:06:30 2009 (4A5BCC06)
fffff880`0683f000 fffff880`06895000   USBPORT  USBPORT.SYS  Mon Jul 13 20:06:31 2009 (4A5BCC07)
fffff880`00fa7000 fffff880`00fb4000   vdrvroot vdrvroot.sys Mon Jul 13 20:01:31 2009 (4A5BCADB)
fffff880`02ba9000 fffff880`02bb7000   vga      vga.sys      Mon Jul 13 19:38:47 2009 (4A5BC587)
fffff880`02bb7000 fffff880`02bdc000   VIDEOPRT VIDEOPRT.SYS Mon Jul 13 19:38:51 2009 (4A5BC58B)
fffff880`00fc9000 fffff880`00fde000   volmgr   volmgr.sys   Mon Jul 13 19:19:57 2009 (4A5BC11D)
fffff880`00d7b000 fffff880`00dd7000   volmgrx  volmgrx.sys  Mon Jul 13 19:20:33 2009 (4A5BC141)
fffff880`0119b000 fffff880`011e7000   volsnap  volsnap.sys  Mon Jul 13 19:20:08 2009 (4A5BC128)
fffff880`0833f000 fffff880`0834c000   vwifibus vwifibus.sys Mon Jul 13 20:07:21 2009 (4A5BCC39)
fffff880`066e9000 fffff880`066ff000   vwififlt vwififlt.sys Mon Jul 13 20:07:22 2009 (4A5BCC3A)
fffff880`0672b000 fffff880`06746000   wanarp   wanarp.sys   Mon Jul 13 20:10:21 2009 (4A5BCCED)
fffff880`02bdc000 fffff880`02bec000   watchdog watchdog.sys Mon Jul 13 19:37:35 2009 (4A5BC53F)
fffff880`00e57000 fffff880`00efb000   Wdf01000 Wdf01000.sys Mon Jul 13 19:22:07 2009 (4A5BC19F)
fffff880`00efb000 fffff880`00f0a000   WDFLDR   WDFLDR.SYS   Mon Jul 13 19:19:54 2009 (4A5BC11A)
fffff880`066b1000 fffff880`066ba000   wfplwf   wfplwf.sys   Mon Jul 13 20:09:26 2009 (4A5BCCB6)
fffff960`000f0000 fffff960`00400000   win32k   win32k.sys   Tue Jan 04 22:59:44 2011 (4D23ECB0)
fffff880`0696f000 fffff880`06978000   wmiacpi  wmiacpi.sys  Mon Jul 13 19:31:02 2009 (4A5BC3B6)
fffff880`00f61000 fffff880`00f6a000   WMILIB   WMILIB.SYS   Mon Jul 13 19:19:51 2009 (4A5BC117)
fffff880`06dc8000 fffff880`06de9000   WudfPf   WudfPf.sys   Mon Jul 13 20:05:37 2009 (4A5BCBD1)
Unloaded modules:
fffff880`088c8000 fffff880`08939000   spsys.sys
    Checksum:  00000000
    ImageSize:  00071000
fffff880`015ee000 fffff880`015fc000   crashdmp.sys
    Checksum:  00000000
    ImageSize:  0000E000
fffff880`011e7000 fffff880`011f3000   dump_ataport
    Checksum:  00000000
    ImageSize:  0000C000
fffff880`01216000 fffff880`0121f000   dump_atapi.s
    Checksum:  00000000
    ImageSize:  00009000
fffff880`00dd7000 fffff880`00dea000   dump_dumpfve
    Checksum:  00000000
    ImageSize:  00013000
Hello again I've run memtest and it wrote 10 pass and 0 error, I've also run chkdsk it found nothing and sfc / scannow did not find some error has been trying to update every driver that you wrote.. http://rapidshare.com/files/456598650/040911-25521-01.rar
