Windows 10 How can I get my PC to output in 32bit 10bpc (my monitor and graphics card both support it).
20886432
I have a ViewSonic VP2770-LCD monitor and an NVIDIA GeForce GTX 780 graphics card connected via DisplayPort. It is capable of displaying 32bit 10bpc color but on all of the test images, I have used it is not doing so. I have a digital camera that can make use of this and I want to.
Josephur
Windows Forum Admin
I believe the consumer series of that time at least only would output 10bpc in supported DirectX applications, not normal desktop applications. Might take some research to uncover exactly what is supported.
Neemobeer
Windows Forum Team
Should be in the Nvidia control panel under 'Change Resolutions' and it should work on everything including making reading easier.
