Windows 7 How could i relocate system reserved partition from one hdd to another?
Barna
Member
Hello,
I'd like to ask for help. I installed windows on my 1TB drive, but it automatically put the system reserved partition on my 320GB drive. Is it possible to relocate that to my 1TB drive, and if so, how complicated would that be, and how would I go about doing that?
Thanks in advance,
Barna
Sounds like the efi files which Windows defaults to the first partitian on the first drive?
An image from 'How could i relocate system reserved partition from one hdd to another?'. Disk Management shows Disk 0 with multiple NTFS partitions and their usage details.
  • Yes Acronis true image can move it ... there are prob others that can as well.
imo if you want the thing on your 1 t drive (internal) then you are better off re-installing Windows with only the 1 T drive in the system... that way Windows will just default to it.
ussnorway
Windows Forum Team
