Windows 10 How do I Keep Notepad on the Screen
Hermitkrab
Even from the days of XP, I never found a way to keep either notepad or wordpad on top of other pages. Clicking anywhere on the screen with notepad open immediately minimizes it. Is there any way to keep notepad locked on top of other windows?Thanks in advance for your assisstance.
ussnorway
Windows Forum Team
option 1 = use two (or more monitors) and spread the desktop
option 2 (windows 8, 8.1 or X) = split the metro screen
An image from 'How do I Keep Notepad on the Screen'. Left image shows a multitasking desktop with a forum and notepad; right image shows static noise.
Neemobeer
Windows Forum Team
Notepad doesn't have a "Always on Top" feature, but you could use Notepad++ which does under View > "Always on Top"
Hermitkrab
Thanks, all. I'm going with Notepad++. I vaguely recall reading about that program somewhere. I'll post back if there's any problem. Thanks again for the rapid replies.
