how to disable bottom/left menu tabloïds articles, without login?
premier
hello
the question is simple, as this : how to disable those things on the "weather" panel? especially the "articles" advertising... (without being connected to msft account)
thank you vm :)
Capture d'écran d'un portail d'actualités en français affichant plusieurs gros titres.
Thanks — good screenshot. Two quick questions before exact steps: are you on Windows 10 or Windows 11, and do you want to keep the little weather/temperature on the taskbar while removing the article/news tiles, or do you want the whole panel gone?
Below are safe options for both OSes (all work without signing in to a Microsoft account).
If you’re on Windows 10 (News & interests)
  • Quick (no registry): right‑click the taskbar → News and interests → Reduce taskbar updates to keep just the weather/temperature and stop rotating article updates, or choose Turn off to remove the feature entirely.
  • Registry (make the change persist / scriptable):
  • Open Registry Editor (regedit).
  • Go to...
  • Go to HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Feeds.
  • Create or edit a DWORD (32‑bit) value named ShellFeedsTaskbarViewMode and set:
  • 0 = show icon + temp
  • 1 = icon only
  • 2 = disabled (turns the feature off).
  • Sign out / restart Explorer or reboot. (Back up the key before editing.
If you’re on Windows 11 (Widgets)
  • Turn off just the news feed (keep widgets like weather):
  • Open Widgets (Win + W or click weather on the taskbar).
  • Click the gear (Settings) in the top right → Show or hide feeds → turn the Microsoft Start / Feed (My Feed) toggle to Off and confirm. This removes the article/news feed but leaves other widgets (weather) available.
  • Remove Widgets completely (if you don’t want the panel at all): right‑click the taskbar → Taskbar settings → toggle Widgets Off — or set TaskbarDa = 0 under HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced to hide it via registry.
    If you want to remove the feed component entirely (no feed even in the background)
  • You can uninstall the package that powers the feed (Windows Web Experience Pack). Open an elevated PowerShell/Command Prompt and run:
    winget uninstall "windows web experience pack"
    That removes the Microsoft Start/MSN feed from Widgets (you can reinstall later if needed).
    Notes / cautions
  • Turning off the feed or uninstalling the web experience pack will stop the article tiles but may change what other widgets display; uninstalling the pack is more aggressive.
  • Registry edits and vivetool tweaks are reversible but always back up the registry or create a system restore point first.
  • If you only want temperature visible but Microsoft’s UI won’t cooperate, you can replace it with a small third‑party tray/weather app (WeatherBar, Meteo, WeatherMate, etc..
    Tell me:
  • Which Windows version (10 or 11)?
  • Do you want to keep the weather/temperature visible on the taskbar or remove the whole thing?
I’ll give the exact step‑by‑step you need (including the exact registry values / commands) for your system.
