jackdaniel
Member
- Joined
- Apr 21, 2026
- Messages
- 5
- Thread Author
- #1
You can’t open an OST file directly without Outlook, but you can easily access it using an OST Viewer tool or by converting it to PST format. Here is the solutions to open OST file without Outlook installation.
1. Use an OST Viewer Tool (Best Way)
It is the easiest method and no Outlook is needed to view your OST file data. Steps to do so it.
2. Convert OST to PST
You can change the OST file into a PST file, and then it can easy open, but you need Outlook for that.
Important: OST files are linked to Outlook, so they don’t open normally. Always use a copy of the file to stay safe
Install the BLR OST Viewer tool
Open the tool and select your OST file
View emails, attachments, contacts, etc.
Use the BLR OST to PST converter to convert your file
Open the new PST file in any supported email app
