Windows 7 I had two BSODs occur yesterday
mattcnz
The first I was unaware of, but the second occurred while browsing the web with divx open. If anyone could please take a look it would be greatly appreciated.
Hello and welcome to the forum.
Update these two drivers
dsNcAdpt.sys 3/30/2009 Network Connect VPN software by Juniper Networks Support - Juniper Networks
and
dne64x.sys 11/10/2008 Citrix Deterministic Network Enhancer Miniport or Cisco Systems VPN Client Cisco Systems, Inc
If you are unable to update these two drivers my suggestion would be to either uninstall the associated software and or rename the file extensions from .sys to .OLD
Regards
Randy
and
Regards
Randy
