Windows 8 IE10 not saving tabs
Amram
The "Reopen last browsing session" is greyed out and staying greyed out in IE10. Is there a download fix that can one can get or is there another way to fix this thrilling problem.
hmm, well i'm not sure what to tell you. Does this always happen or do you want to get the particular tabs it should have saved. It works for me. sorry. Try opening a bunch of tabs and then closing out of the whole browser. then open it again. Does it work now? that's all I got
kmstrube81
Amram
I have 8 tabs opened. If I close down and bring the IE10 back up again, those tabs are all automatically brought up. But the "reopen last browsing session" is still greyed out for some reason. Any further suggestions will be welcomed. Thanks!
