Installation error
techSupports
How can I fix antivirus installation error in my laptop? error message "were interrupted.Make sure you're online and try again." tell me any solution.............
livix07
Well-Known Member
This seems to be a connectivity issue.
How do you connect your laptop to the internet? via wireless or cable?
Please open the Command prompt and type in ifconfig /all, press Enter, then copy and paste what you see inside the Command prompt:
