Windows 7 Installation Problem
CryptoFreak
Okay When I try to install Windows 7 either from a virtual machine or directly booting it normally I get cannot find a particular file. I do not remember the exact message but it goes something like this,,,"cannot find install image(install.wim) because it does not exist" but the file does exist I checked the iso and a burned disc and the file is there.
montyuk
are you running the installer from the iso or from a dvd when your installing it on vmware?
try running it directly from the iso by altering the path for the cd in settings.
CryptoFreak
I tried running it in vmware straight from the iso. I did not want to burn it to dvd just to find out it wont install. I am using the Vista x64 profile in vmware...maybe I should use longhorn x64 which is experimental. I have done that with windows server 2008 and it works fine. Maybe Windows 7 does not like running in a virtual machine as a Vista x64 profile.
Top Bottom
