Installing programs question..
Discussion in 'Windows 7 Software' started by kskwerl, Jul 9, 2010.
  1. kskwerl
    kskwerl New Member
    Jul 9, 2010
    46
    0
    Ok, so I got a new mobo/cpu/ram/psu and I'm going to be doing a clean install this upcoming week. My question is.. can I install programs I'm going to be running in windows 7 on a different hard drive? Such as video games/web browsers/audio programs etc etc.
    If so, is it better to have them on a seperate drive? Also, are there any programs that have to be installed on the C: drive? I have three 500gb WD cavier blacks.
  2. kskwerl
    kskwerl New Member
    Jul 9, 2010
    46
    0
    Also, thanks in advance because I'm leaving to go out right now. All the help is much appreciated
  3. Nibiru2012
    Nibiru2012 New Member
    Dec 16, 2009
    466
    18
    There are a lot of opinions regarding this type of install. I have always put all my software and programs on the C drive. I know some gamers like to install games to another hard drive.
    I believe that all programs write files and such to the Windows folder on C drive.
    Here's some info I found at Tom's Hardware website:
    I hope this helps you out.
  4. kskwerl
    kskwerl New Member
    Jul 9, 2010
    46
    0
    Thank you very much it's much appreciated! The main reason I ask this is because I'm considering buying a SSD and the larger the drive the way way more expensive it is. But another question I have is this..if I do chose to install the programs on a different say..SATA drive..are there certain programs that need to be installed on the C: drive?
  5. Nibiru2012
    Dec 16, 2009
    466
    18
    To be honest with you, if you get a 60 GB SSD, one of the most common affordable size available, you should be able to put the operating system and all programs you use without much problem.
    What I have found is to put all downloads, photos, music files, documents, videos, etc. on a separate hard drive. Those are the items that chew up the most space.
    On my C drive I have about 40 programs installed including Office 2010 and in addition to the Windows 7 Professional x64 operating system. Right now I'm only using about 18.5 GB of space on my 64 GB partition on my 500 GB Samsung SATA II drive.
    ImgBurn has it's temp file on my C drive, but stores the files on my E drive. Same for Office 2010, downloads, DVDneXtCopy working file, uTorrent, etc.
  6. kskwerl
    kskwerl New Member
    Jul 9, 2010
    46
    0
    That's most likely what I'm going to do, I'm big into the movie torrent scene and as long as I can run games and other programs off a different drive then my OS thats definitely what I'm going to do. Thanks again
Share This Page
Loading...
