* Bugcheck Analysis *
BugCheck 3B, {c0000094, fffff8800aeb0c34, fffff88007826c90, 0}
Probably caused by : MFWAWAVE64.sys ( MFWAWAVE64+4c34 )
SYSTEM_SERVICE_EXCEPTION (3b)
An exception happened while executing a system service routine.
Arguments:
Arg1: 00000000c0000094, Exception code that caused the bugcheck
Arg2: fffff8800aeb0c34, Address of the instruction which caused the bugcheck
Arg3: fffff88007826c90, Address of the context record for the exception that caused the bugcheck
Arg4: 0000000000000000, zero.
Debugging Details:
EXCEPTION_CODE: (NTSTATUS) 0xc0000094 - {EXCEPTION} Integer division by zero.
FAULTING_IP:
MFWAWAVE64+4c34
fffff880`0aeb0c34 f7f1 div eax,ecx
CONTEXT: fffff88007826c90 -- (.cxr 0xfffff88007826c90)
rax=0000000000002fff rbx=0000000000000000 rcx=0000000000000000
rdx=0000000000000000 rsi=fffffa80058f25a0 rdi=00000000000000b0
rip=fffff8800aeb0c34 rsp=fffff88007827660 rbp=0000000000003000
r8=0000000000000008 r9=0000000000000004 r10=fffff88002f64e20
r11=0000000000000001 r12=0000000000000004 r13=fffffa8006f17010
iopl=0 nv up ei pl zr na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010246
MFWAWAVE64+0x4c34:
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
BUGCHECK_STR: 0x3B
PROCESS_NAME: audiodg.exe
CURRENT_IRQL: 0
LAST_CONTROL_TRANSFER: from 0000000000000000 to fffff8800aeb0c34
STACK_TEXT:
fffff880`07827660 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : MFWAWAVE64+0x4c34
FOLLOWUP_IP:
MFWAWAVE64+4c34
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: MFWAWAVE64+4c34
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: MFWAWAVE64
IMAGE_NAME: MFWAWAVE64.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4e3c6468
STACK_COMMAND: .cxr 0xfffff88007826c90 ; kb
FAILURE_BUCKET_ID: X64_0x3B_MFWAWAVE64+4c34
Followup: MachineOwner
