Windows Vista Intel 4965agn channels above 11 how can I use they?
tkmbe
Hello
I have win vista with an intel 4965agn wireless card.
I can use channels above 11 (12-13) in my country but cannot se how to set this
with win vista. In linux this is no problem ...
Any hints how to use this channels?
Do I have to install a japan driver? If so where can I get it?
Thanks for any help
Beat
Old Vista Driver
If the new one doesn't work, try a real old "Vista Driver" like from 2007. The guy using Win 7 said it worked for him....."Certain Drivers" may be interchangeable between Win Vista and Win 7.
have you tried the driver supplied by intel or are you just using the one windows installed
which can be found here Link Removed due to 404 Error
Hello
Thanks for any help
Beat
(This post is from 4 1/2 months ago off the Intel Community Forums) It doesn't say if there are any new updated drivers. You'll have to check with your manufacturer and Intel.
the link i gave above is for an driver dated 22-02-2010 also the OP states he's using Windows Vista not Windows 7
Same Problem
Funny, Win 7 and Vista - same problem.... I wonder if Intel put out some bad drivers or something.
Thanks I will try again with this driver. I think I have already tried this one but not anymore shure ... Have tried a lot of drivers :-( Will post later if it works ...
Old Vista Driver
