Windows 11 Intel wifi 6E AX210 wifi handshake 30 seconds delays
Anthonywkho
I got the problem with the AX210 wifi connection 30 seconds delay after restarting thw windows. Is there any solution you could provide and I appreciate it.
Thanks
Anthony
Hi Anthony,
A 30‑second delay after restart is usually caused by the Intel AX210 driver, Windows Fast Startup, or power-saving settings delaying the Wi‑Fi adapter initialization. Try these in order.
1. Install the latest Intel AX210 Wi‑Fi driver​
Intel’s current Windows 10/11 Wi‑Fi package supports the Intel Wi‑Fi 6E AX210 and is listed as version 24.40.0 on Intel’s download page.
  • Download the latest driver from Intel for Intel Wireless Wi‑Fi Drivers for Windows 10 and Windows 11.
  • Install it.
  • Restart the computer.
  • Test whether Wi‑Fi connects immediately after reboot.
If your PC is Dell/HP/Lenovo/ASUS/etc., also check your manufacturer’s support page because some laptops...
Hi Anthony,
  • Install it.
If your PC is Dell/HP/Lenovo/ASUS/etc., also check your manufacturer’s support page because some laptops need OEM-customized wireless drivers.
2. Disable Windows Fast Startup​
Fast Startup can sometimes leave the wireless adapter in a half-initialized state after shutdown/restart.
  • Open Control Panel.
  • Go to Power Options.
  • Click Choose what the power buttons do.
  • Click Change settings that are currently unavailable.
  • Uncheck Turn on fast startup.
  • Click Save changes.
  • Shut down fully, wait 10 seconds, then power on again.
Expected result: Wi‑Fi should begin connecting sooner after Windows loads.
3. Disable Wi‑Fi adapter power saving​
  • Right-click Start.
  • Open Device Manager.
  • Expand Network adapters.
  • Right-click Intel Wi‑Fi 6E AX210.
  • Choose Properties.
  • Go to the Power Management tab.
  • Uncheck Allow the computer to turn off this device to save power.
  • Click OK.
  • Restart Windows.
4. Reset the network stack​
This is safe, but it will remove saved network adapters and may require reconnecting to Wi‑Fi.
  • Open Command Prompt as Administrator.
  • Run these commands:
netsh winsock reset
netsh int ip reset
ipconfig /flushdns
  • Reconnect to your Wi‑Fi network.
5. Forget and re-add the Wi‑Fi network​
  • Go to Settings.
  • Open Network & Internet.
  • Go to Wi‑Fi.
  • Click Manage known networks.
  • Select your Wi‑Fi network.
  • Click Forget.
  • Reconnect and enter the Wi‑Fi password again.
6. Check router security settings​
The AX210 can sometimes delay association if the router is using mixed/legacy security.
Recommended router settings:
  • Security: WPA2-Personal AES or WPA3/WPA2 mixed
  • Avoid: WPA/WPA2 TKIP
  • Band: Test both 5 GHz and 6 GHz if available
  • Channel width: Try 80 MHz instead of 160 MHz for testing
7. If the problem started after a driver update​
Try rolling back the driver:
  • Go to Driver.
  • Click Roll Back Driver if available.
  • Restart the PC.
If it still delays​
Please reply with:
  • Your Windows version: Windows 10 or Windows 11, and version such as 23H2 / 24H2 / 25H2.
  • Your AX210 driver version from Device Manager → AX210 → Properties → Driver.
  • Your PC/laptop model.
  • Whether the delay happens after Restart only, or also after Shutdown → Power on.
  • Whether you are connecting to 2.4 GHz, 5 GHz, or 6 GHz Wi‑Fi.
The first things I would try are latest Intel driver, disable Fast Startup, and disable adapter power saving.
