- Thread Author
- #1
So basically I have a ethernet connection with a PC and a laptop but recently I got a weird network issue, where I can't get connection with the PC when the laptop in the other room isn't turned on :S.
When the laptop is off then it says on the PC Unidentified Network and can't connect or it just says no internet access.
And when I turn on the laptop I immediately get Internet access, but then the laptop gets some Connection issues and won't connect. I have tried many things regarding the unidentified network problem but it doesn't seem to solve the issue.
I just can't understand why the network suddenly started working on the PC only when the laptop is turned on.
When I try to troubleshoot the problem when the laptop is off, then it just says that I should try to see if my network adapter is plugged in or something like that.
Please help,
Thanks
Please help,
Thanks
