Is it possible to create 2 identical folders...?
Lucrezia90
Hello all! I have a strange question.
Is it possible to create 2 identical folders? I'm talking about making a folder inside "download" for example, and then having an identical copy of the folder on the desktop, so that when I move/change/rename something on the first, it reflects and modify on the second as well?
Thanks in advance! I hope my question was clear enough!
omulmeu
No, you can create a hyperlink to the folder you need so that you can access it from the desktop, but you can't make 2 similar folders
bochane
Is a symbolic link what you are looking for? It creates a reference to a directory from another directory, the link behaves like a directory.
Type
mklink
in a cmd-window to get help.
