rubyredvette
- Joined
- Mar 7, 2011
- Messages
- 6
- Thread Author
- #1
I bought and used PCMover to move from XP to Windows7. Read the instructions and moved a bunch of stuff. I was happy camper. Then two months later, I wanted to buy some new songs for my Ipod..... iTunes is corrupt, instructions say to download and install.
I tried that and..... It first uninstall itunes and get a message that says the installer is 32 bit and needs a 64 bit installer to unininstall current iTunes. I contacted LapLink (PCMover). Their solution is to somehow undo the move (from two months ago), install the 64 bit iTunes (will that install on XP? I doubt it) and redo the move. I was told that PCMover does not work with several other programs.
Is there a way to manually delete the software? I tried the packaged software uninstallers and the three that I tried use the manufactors uninstall package.
Apple support forum suggested using MS installer cleanup, but that does not address the problem with the apple uninstaller....
Any suggestions? Other than "you should not have used the move software"
