Windows 10 Keyboard hold key don't work.
Beppi
It happen today I was playing some counter strike when i done the round i play another but everytime i want to move it like you press that botton repeat over and over again holding don't work , Are there any possible way to fix this?
Keyboard : Nubwo NKM-300 Infarez
Graphic Card : GTX 1660 Ti
The issue you are experiencing with your keyboard where key presses are being registered repeatedly even when you're not holding down the key is known as key repeat or key chatter. Here are some steps you can take to address this problem: 1. Keyboard Firmware Update: Check if there is any firmware update available for your Nubwo NKM-300 keyboard. Updating the firmware can sometimes resolve keyboard-related issues. 2. Cleaning the Keyboard: Over time, dirt, dust, and debris can accumulate under the keys, leading to erratic behavior. Try cleaning the keyboard using compressed air or a keycap puller to remove the affected keys and clean underneath them. 3. Check Key Settings in Windows: Sometimes, the repeat delay and...
The issue you are experiencing with your keyboard where key presses are being registered repeatedly even when you're not holding down the key is known as key repeat or key chatter. Here are some steps you can take to address this problem: 1. Keyboard Firmware Update: Check if there is any firmware update available for your Nubwo NKM-300 keyboard. Updating the firmware can sometimes resolve keyboard-related issues. 2. Cleaning the Keyboard: Over time, dirt, dust, and debris can accumulate under the keys, leading to erratic behavior. Try cleaning the keyboard using compressed air or a keycap puller to remove the affected keys and clean underneath them. 3. Check Key Settings in Windows: Sometimes, the repeat delay and repeat rate settings in Windows can cause issues. Adjust these settings by going to Settings > Devices > Typing. 4. Key Chatter Software Fix: Some keyboard-specific software tools can help address key chatter issues. You can search for software that helps in debouncing keys or adjusting input. 5. Test the Keyboard: Connect your keyboard to a different computer to see if the issue persists. If it does, the problem likely lies with the keyboard itself. 6. Contact the Manufacturer: If the issue persists and the keyboard is still under warranty, consider contacting the manufacturer's support for further assistance. They may provide troubleshooting steps or offer a replacement if the keyboard is faulty. 7. Try Another Keyboard: If possible, test with a different keyboard to see if the issue is related to the keyboard or your computer's settings. By following these steps, you can troubleshoot and potentially resolve the key repeat issue you are facing with your Nubwo NKM-300 keyboard while playing games like Counter-Strike.
