LG xboom by will.i.am CES 2026: AI Audio, Up to 220W, 35h Battery
LG’s refreshed xboom by will.i.am lineup pushes hard on party power, AI audio smarts, and battery endurance — promising up to 220W of output, AI-powered vocal removal and tuning, and as much as 35 hours of playback on a single charge across four new portable models.
LG x BOOM: rugged, concert-ready portable speakers showcased at a live outdoor show.Background​
LG has steadily broadened the xboom range since partnering with will.i.am, and the CES 2026 refresh continues that strategy by combining hardware tweaks with software-driven experiences. The new family — xboom Stage 501, xboom Blast, xboom Mini, and xboom Rock — doubles down on three themes LG and its partners emphasize: AI-enhanced audio, long battery life (including swappable packs on larger models), and form-factor variety to match party, outdoor, and everyday scenarios. This feature unpacks the lineup model-by-model, verifies the major technical claims against LG’s materials and independent press coverage, and examines the practical trade-offs — from real-world runtimes to privacy and interoperability risks — that buyers should weigh before purchasing.
What’s new in the 2026 xboom lineup​
  • AI-driven features are now a central selling point, not just an add-on: AI Karaoke Master, AI Sound, AI Lighting, and Space Calibration Pro are built into multiple models.
  • Higher power envelopes for party-grade models: LG advertises up to 220W when plugged in for the Stage 501 and Blast, with the Stage dropping to a 160W ceiling on battery.
  • Battery strategy: swappable 99Wh packs on higher-tier units plus long-life tuning (claimed 25 hours for Stage 501 and 35 hours for Blast).
  • Greater attention to social-listening standards: LE Audio / Auracast support and multi-unit synchronization are included to enable broadcast-style group listening.
These developments are credible when compared to LG’s official newsroom materials and multiple trade outlets that covered the CES preview, but several vendor claims still require hands-on verification by independent reviews. Expect lab test variance in battery numbers, SPL performance, and AI fidelity.
Model deep dives​
xboom Stage 501 — the party wedge with karaoke ambitions​
The Stage 501 is the marquee unit and the most feature-packed speaker in the range. LG positions it as a central device for home parties and karaoke nights: it uses a five-sided cabinet (a physical wedge form that can be oriented several ways), dual woofers, full-range drivers, and Peerless tweeters to cover the spectrum. The company rates output at 220W when plugged in and 160W on battery, powered by a 99Wh swappable battery that it says delivers up to 25 hours of playback. The headlining software feature is AI Karaoke Master, a deep‑learning system LG says was trained on more than 10,000 songs to remove or reduce vocals and optionally adjust pitch — enabling users to sing solo, duet with the original artist, or leave vocals at a lower level without preparing special karaoke tracks. This is a clear product differentiation if it works reliably across genres and production styles. Early reports highlight the promise, but emphasize that fidelity and artifacting will be judged only after rigorous, controlled tests. Practical notes:
  • Multiple placement options (vertical, horizontal, tilted, tripod) help tailor coverage in different rooms.
  • Integrated multi‑color lighting and AI Lighting sync with playback to create party ambience, but these effects will reduce battery life.
  • On balance, Stage 501 trades portability for power and features — it’s best for buyers who need a party centerpiece rather than a pocketable speaker.
xboom Blast — the endurance-focused outdoor workhorse​
Blast is clearly aimed at outdoor gatherings and festival-style portability. LG claims it runs on a 99Wh battery and can reach up to 35 hours of playback on a single charge, while offering 220W of peak output and using three passive radiators to bolster bass. The enclosure is described as rugged, with edge bumpers and military‑standard durability testing. Design touches like a side rope handle and rubber top handle emphasize practical transport. Blast shares the Stage’s AI Sound and Space Calibration Pro systems, meaning it will attempt to adapt EQ and dispersion depending on whether it’s used indoors or in open air. That matters for outdoor use, where reflections are minimal and dispersion strategies must change to preserve perceived loudness. Independent reviews will need to test the claim that calibration keeps coverage even and intelligible in windy or noisy environments.
xboom Mini — everyday portability with IP67 protection​
Mini targets casual, everyday use. The compact cube form includes a Magic Strap, IP67 water/dust resistance, and a built‑in tripod mount. LG lists playback of around 10 hours, and the small footprint is balanced against the inevitable limitation in bass extension and SPL when compared with larger party units. The Mini focuses on portability, durability, and convenience rather than headline power.
xboom Rock — rugged, social, Auracast-ready trail companion​
Rock updates LG’s rugged speaker lineage. It’s lighter and more trail-ready, meeting several military standard tests, offering around 10 hours of runtime, and including LE Audio / Auracast support for broadcast-style group listening. LG notes an improved 6W output compared with earlier compact rugged models — enough for personal and small-group listening but not party volumes. Rock is pitched as a durable, social device for hikers and campers.
AI features: usefulness vs. risk​
The lineup’s most interesting pivot is toward AI as a primary user benefit rather than a marketing gloss. The core AI features are:
  • AI Karaoke Master — trained on 10,000+ songs to isolate or lower vocals and permit pitch-shifting for duets or solo performance.
  • AI Sound — automatic content analysis that emphasizes vocals, melody, or rhythm as appropriate.
  • Space Calibration Pro — environment-aware tuning for indoor vs. outdoor dispersion.
  • AI Lighting — audio-synced ambient lighting effects for party setups.
  • FYI.RAiDiO with AI Personas — a will.i.am–branded on-device/connected AI DJ and discovery layer, accessible with a dedicated MY Button or via the FYI app.
Strengths:
  • AI removes friction: no manual EQ fiddling or prep of karaoke stems.
  • Cultural positioning: will.i.am and persona-driven curation can drive differentiation in lifestyle-oriented segments.
Risks and open questions:
  • Artifacting and fidelity: vocal removal is an imperfect signal-processing task; the extent of artifacts, pitch warping, or loss of ambience must be validated in tests across genres and production styles. Early coverage flags the feature as promising but unproven in all conditions.
  • Latency and cloud dependence: LG’s materials avoid full technical detail on whether persona interactions are processed on-device or in the cloud. If cloud roundtrips are required, response times and offline usability will suffer.
  • Privacy: conversational features and persona interaction raise questions about voice capture, retention, and third‑party access. Buyers should expect LG and FYI to publish detailed privacy policies and opt-out options; absence of clarity is a reputational and regulatory risk.
Battery, power, and real-world runtime expectations​
LG’s headline figures are attractive: 25 hours for Stage 501 (99Wh swappable) and 35 hours for Blast (99Wh) are vendor-rated claims. The company also advertises 220W maximum output when plugged in for Stage 501 and Blast, with 160W available when Stage runs on battery. These numbers are repeated across LG’s newsroom and trade outlets. Practical caveats:
  • Vendor battery numbers are measured under specific, usually conservative playback conditions (moderate volume, lights off, calibration steady). Activating AI Lighting, running at higher SPLs, or enabling calibration features will reduce runtime substantially.
  • Swappable batteries are a real-world advantage for parties and outdoor use — but the availability of spare packs, shipping restrictions on airline travel, and replacement costs are important buying variables. Confirm regional regulations and MSRP for replacement batteries.
  • Power ratings (watts) tell part of the story: actual perceived loudness (SPL) depends on efficiency, cabinet design, and drivers. Two speakers with similar watt ratings can measure differently on an SPL meter. Independent lab SPL and distortion tests will be definitive.
Buyers should therefore treat LG’s runtime and wattage claims as vendor specifications to be validated by independent reviews that perform standardized playback and SPL tests.
Interoperability and standards: Auracast and LE Audio​
LG has embraced LE Audio / Auracast for social-listening scenarios on at least some models, most notably Rock and potentially across other units where multi-listener broadcast is relevant. Auracast promises low-latency group listening and potential battery savings via LC3 codecs, but ecosystem support is uneven: many phones and headsets require firmware updates or hardware support to fully use Auracast today. Key realities:
  • Auracast is early in adoption; confirm device compatibility before relying on it for shared-listening scenarios.
  • LG’s speaker-hosted synchronization feature (where a speaker can act as a master for non-Auracast devices) is useful, but interoperability and latency will depend on the receiving device’s Bluetooth stack.
Durability and outdoor readiness​
LG lists IP67 for Mini and military-grade test results for Rock and Blast. These claims are consistent across the product literature and trade reporting, but as with many consumer devices, final certification and regional SKU differences matter. Ruggedness can be operationally sensitive to input ports, battery doors, and accessory mounts — so buyers should inspect retail units and warranty terms for clarity. Practical guidance:
  • If you plan to use the Blast at beaches or near salt spray, verify whether LG tested for salt-fog or corrosion resistance.
  • Confirm the waterproof rating for charging ports and battery access points; IP67 does not guarantee survivability in high-pressure washdowns or full submersion beyond rated depths/times.
Market positioning and competitors​
LG is positioning xboom to compete across multiple segments:
  • Against JBL PartyBox and Sony X-series, Stage 501 and Blast emphasize power + lighting + karaoke, aiming for buyers who want an all-in-one party centerpiece.
  • Against rugged speakers from Ultimate Ears, JBL, and others, Rock and Blast emphasize durability + battery life, while adding Auracast as a potential differentiator if the ecosystem catches up.
  • The AI and persona-based FYI.RAiDiO experience is a clear attempt to create platform lock-in: if users like the persona curation and DJ features, they may prefer xboom units for consistent UX across homes and events.
Whether LG displaces entrenched incumbents will depend on pricing, real-world performance, and how reliably AI features function without biasing fidelity.
Buying guidance — checklist before you purchase​
  • Confirm the exact SKU and regional model number: features like IP rating, Auracast support, and warranty terms can vary by market.
  • Test the AI Karaoke Master on sample tracks you care about — especially processed pop, EDM, and heavily engineered vocals — because vocal-removal performance can vary by genre.
  • Look for independent battery runtime and SPL tests that measure playback under conditions similar to your intended use (lights on/off, calibration active, volume levels).
  • Verify Auracast / LE Audio compatibility for your phones/headphones if you plan to use broadcast group-listening.
  • Review the privacy policy for FYI.RAiDiO and AI Persona features — check whether voice interactions are processed locally, what metadata is retained, and how to opt out.
Strengths, caveats, and final analysis​
Strengths:
  • The lineup is well-segmented with tangible value moves: swappable 99Wh batteries, durable Blast and Rock builds, and a party-grade Stage with multiple placement options.
  • AI features such as Karaoke Master and Space Calibration Pro, if they reliably perform, will reduce setup friction and open new use cases (impromptu karaoke, automatic room tuning).
  • The will.i.am partnership and FYI.RAiDiO persona layer provide cultural cachet and a differentiated content/interaction strategy.
Caveats and risks:
  • Vendor-rated battery and power figures should be treated as optimistic until independent labs confirm them under repeatable conditions. Lighting and AI features will reduce runtimes.
  • AI audio processing (vocal removal, automatic EQ) is inherently lossy and can introduce artifacts. Buyers with critical listening needs should test before purchase.
  • Privacy and latency around FYI.RAiDiO remains an open question; LG needs to publish clear processing and retention policies.
  • Auracast adoption across phones and headsets is incomplete; the social-listening promise depends on the broader ecosystem catching up.
Quick pro/con summary​
  • Pros:
  • Strong party and outdoor feature set with high advertised power and long battery claims.
  • Unique AI features (Karaoke Master, Space Calibration Pro) and will.i.am–backed persona curation.
  • Swappable 99Wh batteries on top-tier models for extended portable use.
  • Cons:
  • Manufacturer numbers need independent verification; expect runtime and SPL variance in real-world use.
  • AI features may introduce artifacts; privacy policy clarity is still needed.
  • Auracast-dependent features are constrained by the current device ecosystem.
LG’s latest xboom by will.i.am family is a bold, coherent attempt to fuse lifestyle branding with practical hardware upgrades and AI-driven features. The Stage 501 and Blast push the envelope on loudness and portability with swappable 99Wh batteries and high advertised output, while Mini and Rock round out the line for everyday and rugged use. The AI Karaoke Master and FYI.RAiDiO persona platform represent the clearest attempt to differentiate via software and content, rather than purely hardware specs. For buyers, the decision should hinge on two things: whether the AI features actually deliver useful, artifact-free experiences on the music you care about, and whether independent tests confirm LG’s runtime and SPL claims under conditions you’ll use. If both check out, LG has created a versatile and compelling set of options for party hosts, outdoor enthusiasts, and everyday listeners alike. If not, the lineup risks being another set of promising specs that fall short in practice — which is why waiting for hands-on reviews and clear privacy documentation is the prudent move before committing money.
Source: Notebookcheck LG's new Xboom Bluetooth speakers offer up to 220W of power and 35 hours of battery life
